Mobian stuck in bootloop
Hey all,
I flashed the 16/06 build (and later the nightly) on a 32GB SanDisk microSD card. Sadly, in both cases Mobian is stuck during the plymouth boot screen (circle keeps circling indefinitely).
PostmarketOS works with this card, so I guess the microSD is not the problem. UBports is on the internal flash.
Any clue what the problem might be? Thanks.
(06-25-2020, 04:04 AM)The_Bolder Wrote: Hey all,
Hi!,
Maybe you can try another version in case that build you used is not working fine.
Also it could be the SD card was not created properly, what is your method to create the write the image onto the SD?
I used dd and made sure the card was unmounted.
I dug through the issue tracker and found that, apparently, there is some kind of problem with partition checking during boot. So maybe that's what causes the bootloop.
Update: using JumpDrive to flash it on the internal mmc worked! No clue what's going on with the microSD cards....
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 77 41,745 10-27-2025, 10:19 AM
  cryptocurrency on mobian/pinephone biketool 35 57,765 10-08-2025, 06:21 AM
  Mobian MMS/SMS text problem bcnaz 16 26,766 09-15-2025, 02:42 AM
Last Post: georgegohl888
  XLibre for Mobian Hiraghm 1 2,130 06-30-2025, 01:38 AM
Last Post: Haroldkent
  Axolotl on PinePhone / Mobian arno_nuehm 223 273,041 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 1,906 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 2,438 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 2,856 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 2,852 04-29-2025, 02:10 PM
Last Post: mdk
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 2,962 01-15-2025, 08:08 PM
