Boot from USB on PinePhone
Has this been done?
Someone else mentioned the ANX7688.  If that's the USB chip then this page: https://www.analogix.com/en/products/con...es/anx7688  says it's "Simultaneous USB 3.1 Gen1 (5.0Gbps) and DisplayPort Alternate Mode".
I'm after what they did with the PI ( https://hackaday.com/2020/05/25/boot-your-pi-over-usb/ ) to put the boot loader on emmc, use the rest of the emmc for data, and have a 5Gbs USB 3.1 to SD reader with a really fast SD card and multiboot all of the possible OS's from one SD card which also holds a nice swap file that again is much faster than the built in SD.
Opinions?
I'd like something similar, in order to boot from and play with various operating system images.
Some Raspberry Pi models will attempt to boot from USB if no SD card is present. However, they don't provide any way to select among multiple devices. What I'd like is a command in the "base" operating system (e.g., on eMMC or the microSD card) that causes a reboot from a specified file path. Ideally, this could be on any available file system (eMMC, microSD, USB).
Not going to work.  While PinePhone has a USB-C port and the chip you mention can indeed drive DisplayPort out of the connector, the SoC is only capable of USB2 so you won't like the performance if you try running mass storage off of the USB port.
  Movuan distribution for PinePhone merom 5 4,688 07-27-2025, 05:01 PM
Last Post: merom
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 3,040 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Latest firmware for PinePhone modem! Subsentient 105 199,645 02-02-2025, 08:47 PM
Last Post: bacydentir85
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 54,067 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 4,305 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 58,521 07-26-2024, 10:35 PM
  Why does Pine64 sabotage office on the Pinephone? Peter Gamma 5 5,604 07-04-2024, 07:34 AM
  Which word processor to choose for the Pinephone? Peter Gamma 16 14,890 06-22-2024, 07:28 AM
  Samba share on the Pinephone? Peter Gamma 0 3,790 06-16-2024, 10:26 PM
  Possible Free Backup Carrier for PinePhone PineFone 0 3,683 06-13-2024, 03:45 PM
Last Post: PineFone
