Virtual Desktop Issues (Manjaro KDE)
Just received my Pinebook Pro yesterday and am excited to be using it! However, I am having two issues configuring Virtual Desktops on the stock Manjaro KDE build:
  1. I cannot create more than one row of desktops. I click the button, but either kwin crashes or it just doesn’t save properly.
  2. I cannot use the Meta + Ctrl + arrow keyboard shortcuts to navigate between desktops or the Meta + Shift + arrow key shortcut to move windows between desktops. The don’t work as the default shortcuts, and it seems like I cannot create any shortcuts using the arrow keys. I’ve tried manually creating the shortcuts and also imported my shortcuts from my desktop system (Kubuntu) and neither works.
Does anyone else experience the same thing? I have used KDE for a year or two on other distributions, but this is my first time using Manjaro, so please forgive me if this is a Manjaro issue instead of an ARM/PBP thing.
(06-05-2020, 02:30 PM)davemaps Wrote: Just received my Pinebook Pro yesterday and am excited to be using it! However, I am having two issues configuring Virtual Desktops on the stock Manjaro KDE build:
I have noticed the same thing regarding virtual desktops. I don't have this problem w/ Manjaro KDE x64 on my MacBook Air. I'm guessing maybe it's specific to the arm version
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 707 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 897 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 1,245 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 2,895 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 1,243 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 4,062 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 4,617 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 1,282 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 2,276 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,770 08-21-2023, 09:10 PM
Last Post: vanessadonald
