Tensorflow - Printable Version +- PINE64 (https://forum.pine64.org) +-- Forum: PINE A64(+) (https://forum.pine64.org/forumdisplay.php?fid=4) +--- Forum: Linux on Pine A64(+) (https://forum.pine64.org/forumdisplay.php?fid=6) +---- Forum: Ubuntu (https://forum.pine64.org/forumdisplay.php?fid=27) +---- Thread: Tensorflow (/showthread.php?tid=1839) Pages:
1
2
RE: Tensorflow - quantumfusion - 08-22-2016 please do the guide . i am interested RE: Tensorflow - dkryder - 08-22-2016 yes, i also think it would be interesting to read a document of your experience. not so much as i also want tensorflow but your processes i think with be generally helpful in other pip,python,build in general. i'm also interested in if the tensorflow program makes other programs compete heavy for resources of the board RE: Tensorflow - earlzero - 10-08-2016 Hi, I finally built tensorflow on pine64. I was using pine64-image-debianbase-310102bsp-2.img and guide from https://www.neotitans.net/install-tensorflow-on-odroid-c2.html. Guide worked for pine64 without significant changes (I also had to run "pip install wheel" to for final step to succeed) all patch files from this guide are located here - https://github.com/neo-titans/odroid/tree/master/build_tensorflow. Resulting file is available here - https://drive.google.com/file/d/0B3Xy0bk6f6YSQkFKRTlLWG9zdFU. RE: Tensorflow - dkryder - 10-08-2016 hopefully you will give us an update on the operational aspect of using tensorflow on the pine64. i was under the impression that it was a resource hog and so interested if it will run properly. good luck using it. RE: Tensorflow - tkg.rahul - 03-15-2018 (10-08-2016, 02:55 PM)dkryder Wrote: hopefully you will give us an update on the operational aspect of using tensorflow on the pine64. i was under the impression that it was a resource hog and so interested if it will run properly. good luck using it.Hi, any update here, I am facing difficulty in installing tensorflow. RE: Tensorflow - jrullan - 03-19-2019 Hello, I came across this post and I want to install Tensorflow to use the Pine64 A64+ for an image classification project. I went to the Tensorflow website, and there seems to be a Tensorflow Lite solution specifically created for embedded systems such as the Raspberry Pi and other ARM based SBC's. My question is first, **Do you guys compiled the whole Tensorflow package or the Tensorflow Lite?** They provide a guide to compile the Tensorflow Lite version for AARCH64 but it came up with lots of errors in my A64+. @pekapa, Did you prepare the guide you mentioned in your last post? |
