Android 5.1.1 Image 20160505 wiki links
Thanks for the Android images suitable for 'dd' in varoius SD card sizes.  As I don't use Windows, the previous images were painfull.  Some of the download links on
for the various regular and rooted Android 5.1.1 Image Release 20160505 SD card images appear to be wrong.  For example, both of the 32GB microSD card links point to the same file:
21d720fa0aeaceedeef53492437539f2  android-rooted-ver5.1.1-20160505-pine64-32GB.zip
Thanks.
Couldnt find a bettr thread to post this in, så here we go...
Will it be possible to have the DD-images made for 128Gb microSD cards as well? (Especially the rooted ××0505 5.1.1 image)
(05-08-2016, 03:51 PM)kinbeowulf Wrote: Thanks for the Android images suitable for 'dd' in varoius SD card sizes.  As I don't use Windows, the previous images were painfull.  Some of the download links on
Thanks.
Thanks on pointing out the mistake due to cut and paste. Now already corrected.
(05-08-2016, 08:47 PM)Tarjei85 Wrote: Couldnt find a bettr thread to post this in, så here we go...
Surprise to get the request on 128GB DD. I am currently traveling and my notebook cannot handles 128GB build, archive 128GB file takes about 4 hours. Once I back in Bay Area on Saturday, I will build and post up.
Tried to write android-ver5.1.1-20160505-pine64-16GB.img on Verbatim MicroSD 16Gb
Got the error that not enough space on my new, formatted card....
(05-11-2016, 02:15 AM)garg Wrote: Tried to write android-ver5.1.1-20160505-pine64-16GB.img on Verbatim MicroSD 16Gb
So you tried out one of the DD images made by Pine64 folks with a 16 GB SD card that is slightly larger (maybe just one single block!) than your 16 GB card. Everything as expected. Smile
You could either use an 8 GB DD image and drop 8 GB of useable space or you look through the (still not existing) appropriate documentation to get an idea how to deal with PhoenixCard without hassles and wasting time.
If I were you I would first look through the 'recommended SD cards' threads to get the idea why you should better throw away your card NOW and start over with something else and PhoenixCard.
Thank you for quick reply.
Honestly, I used this card for 8gb, just was curious what the differences between 8gb and 16gb versions.
When I'll have little more free time I try PhoenixCard Wink
Thank you, again.
Thank you, again.
The only difference is the amount of space available for Android to use. Other than that, everything else is identical.
Donate BTC: 3Eav9uqXi8Nx1axb7QjK6xV4km4K9YGv9a
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 388,261 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,657 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,819 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 6,987 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,051 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,614 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,340 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 258,518 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,548 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,185 02-10-2019, 07:44 PM
Last Post: mmmarcus
