Earlyoom: kill process before freezing
After installing zram, my PBP still froze due to lack of memory, which required reboot.
So I installed Earlyoom, which kills the process it estimates abuse when memory is full.
Installation is very easy: just follow the download and compilation instructions.
You must install the git package to download and the base-devel meta-package to compile.
You can install go and cppcheck if you want to run the built-in self-tests. I don't know if it's usefull.
Earlyoom tries to guess what is the "right" process to kill. For me, this is always the youtube.com tab process of Chromium, which is a good decision because this page can use more than 1go (!) of memory. At the same time, it is not an important tab.
I also tested several memory limits before letting earlyoom go into action.
By default, earlyoom kills a process if available memory and free swap is less than 10%. I lowered this value to 2% for both without preventing earlyoom from working properly. For values less than 1%, the computer freezes before the intervention of earlyoom.
2% may be too low ( <=> 80 Mo for memory, 20 Mo for swap), but for now, earlyoom kill nasty process without problem with this value. If the computer freezes again, I will increase this value.
Pinebook Pro, standard config (Manjaro)
  Boot process bero 14 16,219 10-27-2020, 09:29 AM
  Repeatedly Freezing then Rebooting Dreamwalker 2 3,582 02-18-2020, 12:41 PM
Last Post: Dreamwalker
