Exposed vias for RGMII Ethernet
I have not been able to find a board layout of the traces so far and I was wondering if there are vias for each the RK3399 balls are exposed on the under side pcb? If not would you consider making a future version of the PineBook Pro with Ethernet? Or at least breaking out the RGMII pins on a future board revision?
Ideally, the next version of the main board would include other things brought to the edge of the board.
Either as simple solder pads, or miniature connector solder pads.
Like:
- The other 2 USB 2.x ports, from an internal USB 2.x hub.
- Various power voltages, (5v, 3.3v, etc...)
- Possibly any un-used SPI channels
Arwen Evenstar
Princess of Rivendale
  Ethernet issue on USB-C Docking Deck Nongorre 2 2,594 02-19-2022, 10:18 PM
Last Post: angeloweb
  Pinebook Pro Docking Deck Ethernet Port MickTheGeek 1 2,446 06-16-2021, 07:49 PM
Last Post: Kuawi
  Port Adapters for PBP — Ethernet, HDMI, etc. zaius 18 23,091 01-19-2020, 03:52 PM
Last Post: Arwen
Information Working USB-C Adapter with HDMI, Ethernet and Power kito 0 2,723 01-08-2020, 08:01 AM
Last Post: kito
