Link to the Official (from factory) manjaro image?
As Manjaro is now the default OS as shipped from the factory I'd like to flash my PBP to the "official" OS.
Can someone point me to the correct image?
I've looked on the Wiki and its still debian-centric and the Manjaro section has various different desktop options.
Looking in the forums there are versions 19 and 20 manjaro threads, so I'm not sure which is the correct one that will match the version flashed onto the PBP in the factory.
Cheers
Linux n00b trying to learn.
Brute force and ignorance sometimes works!
| Pinebook Pro + Toshiba OCZ RC100 240GB |
Go to the Manjaro Arm forums and look for the latest release (20.0X). For the OOTB build, choose the KDE variant.
(05-19-2020, 08:10 AM)tophneal Wrote: Go to the Manjaro Arm forums and look for the latest release (20.0X). For the OOTB build, choose the KDE variant.
So its 20.0x KDE, thank you.
I'll head over there and give it a go.
Cheers @tophneal
Cheers @tophneal
Glad I could help. Just in case it helps anyone down the road: Manjaro's versioning is just like Ubuntu's "YY.MM". So this month's (May 2020) release would be 20.05.
(05-19-2020, 07:28 AM)gandlers Wrote: As Manjaro is now the default OS as shipped from the factory I'd like to flash my PBP to the "official" OS.
Cheers
Here is the link for emmc installer, https://osdn.net/projects/manjaro-arm/st....04.img.xz
And here the thread with all info to install it correctly, https://forum.manjaro.org/t/manjaro-arm-...sed/133374
See on  https://forum.manjaro.org/c/manjaro-arm/78 to get lastest updates from manjaro.
  Manjaro Sway Theme Broken Eighty8 1 166 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 1,110 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,605 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 213 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 1,912 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 1,979 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 291 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 746 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 1,913 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,852 08-21-2023, 09:08 PM
