OpenBSD 6.7 on Pinebook Pro
#21
(05-24-2020, 01:45 PM)signaryk Wrote:
(05-23-2020, 01:16 PM)Lumat Wrote: Got display but no mouse or keyboard. Tricky.
Would you mind sharing how you wrote the image to the SD card? I tried to do it earlier this week but I wasn't able to get the display to come up.
The key for me to get display working was using this u-boot with NVMe support
https://github.com/pcm720/rockchip-u-boot/releases/
Then following excellent OpenBSD install instructions.
I tried later u-boot releases and they didn't work as well.
I still need to get USB working which I think will also solve keyboard and mouse not working.
I think it's mostly u-boot related since with later u-boot releases USB was working but no display.
(05-25-2020, 04:21 AM)Lumat Wrote: The key for me to get display working was using this u-boot with NVMe support https://github.com/pcm720/rockchip-u-boot/releases/ Then following excellent OpenBSD install instructions. I tried later u-boot releases and they didn't work as well.I still need to get USB working which I think will also solve keyboard and mouse not working. I think it's mostly u-boot related since with later u-boot releases USB was working but no display.
Damned, so the trick would be to find a u-boot release that has display and USB working.
So I don't even need to try before that solution is found, because I don't have a serial console cable at hands?
https://xosc.org/pinebookpro.html
The author said that X11 works now and the article will be updated tomorrow
via https://www.reddit.com/r/openbsd/comment...ebook_pro/
Enviado desde mi ONEPLUS A5010 mediante Tapatalk
(06-05-2020, 10:21 PM)e-minguez Wrote: https://xosc.org/pinebookpro.html
That's great news! Will keep an eye on it.
let's hope that someone gets it together to make an image
And flashing to emmc, live dangerously!!!!
doas dd if=miniroot67.img of=/dev/rsd2c bs=1m
Err, I have no way to make unix type partiitions,, sd2c
Is this big frog in little pond syndrome?
The article on xosc.org is missing some crucial details. I can get the OpenBSD installer to work, and I can install OpenBSD on the eMMC of my PBP, but it will not boot. It finds nothing to boot, and falls back to trying PXE boot, and then just stops at its firmware console. The author must've flashed a different u-boot version or so to his eMMC to make it all work, probably the same set used to get the installer working.
(05-15-2020, 11:29 AM)nohandlebars Wrote: I boot this with the serial cable connected however it always stops at the following two lines:
rkclock0 at mainbus0
rkclock1 at mainbus0
It's been a while since this was reported, but I was encountering this, so I'll just post my solution for the sake of anyone else who might be struggling with this.
My Pinebook Pro is from January when it was still shipping with Debian, which was still on my eMMC. After installing Manjaro 20.06 to the eMMC and making sure everything was up to date, I no longer have this problem and my OpenBSD SD card boots into the installer. I guess there is some problem with the version of U-Boot installed with Debian on Pinebook Pros made before the switch to Manjaro. There's probably a quicker way to accomplish that fix, but I'm still getting acquainted with this architecture, so this was easier for me.
(07-04-2020, 12:49 AM)I\ll assume your using cu ? bail out and change baud rate 1500000 to 115200. my nanopc-t4 uses 1500000 to boot then over to 115200 baud, works for me Wrote:
  How to install OpenBSD on the PBP? BenniTec 2 3,769 10-29-2022, 02:41 PM
Last Post: evantaylor
  NetBSD on the Pinebook Pro in August 2022 - or not? KC9UDX 6 3,663 08-24-2022, 01:49 AM
  OpenBSD 6.9 install StickyPine 18 20,079 02-02-2022, 04:34 PM
Last Post: mfashby
  NetBSD and pinebook keyboard/trackpad firmware updater mrgtwentythree 5 9,858 05-16-2021, 07:37 PM
Last Post: mrgtwentythree
  OpenBSD on the pinebook pro e-minguez 5 11,106 04-27-2021, 04:06 AM
Last Post: dreamer_
  PINEBOOK Pro USB-C Docking Deck on FreeBSD S199pWa1k9r 2 4,482 03-04-2021, 01:53 PM
Last Post: Arwen
Question Issues Installing NetBSD on a PineBook Pro ReleaseTheGeese 14 14,929 01-31-2021, 11:20 AM
Thumbs Up My NetBSD on Pinebook Pro journey KC9UDX 11 18,654 12-06-2020, 08:26 PM
