Failure to boot
Hi all,
I'm looking for some assistance please, I received my RockPro64 (+NAS case, fan, heat sink, 2xSATA board, Pine power supply) and set everything up, using ayufan's OMV images, and everything worked great. Up and running in about 1 hour (including putting the fan in the wrong place/orientation 3 times).
However, after shutting down in linux, moving it to my server cab and trying to boot again, I am no longer able to get my device to run. I don't get into Linux, I get a stack trace, after which the device reboots, but then does not power on again (I have to remove the power in order to then boot again).
I have removed all devices, so I'm running with just the board, USB keyboard and DVI connected to my display (I've just tried removing the network connection) but get the same results each time.
I've used both the armhf and the arm64 variants on the same SD card.
I am a programmer, but my embedded days were limited and a long time ago.. Can anyone offer advice on how to investigate further? Do I need to go the UART route, or am I best trying to return my board?
(05-10-2020, 01:34 PM)atcwells Wrote: ...
Incredibly poor res image: https://imgur.com/a/VuxkxgB
  enble boot after power loss/restore dkebler 18 9,324 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 118,973 09-25-2023, 12:46 AM
Last Post: ChriChri
Bug Broken boot: What am I missing? mkosarek 1 656 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 4,220 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 4,279 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 1,533 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 8,109 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 1,144 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 2,769 07-02-2022, 09:24 AM
Last Post: dkebler
  ROCKPRO64 PCI SSD SD-boot Install pspgarret 0 1,157 06-09-2022, 10:56 AM
Last Post: pspgarret
