10-01-2016, 06:25 PM
Earlier post deleted ..... I inadvertently put it on the wrong thread....
Howto run Linux with resolution other than 1080p
01-13-2018, 01:38 AM
(05-07-2016, 06:21 PM)baryluk Wrote: Is it possible to output 16:10, 4:3, 5:4, 1:1 resolutions? Something like 2560x1600, 1920x1200, 1600x1200, 1024x768, 1280x1024, 1920x1920, etc I'm looking for a solution to drive 1280x1024 - is the aforementioned a limitation of this specific tool in its current guise or a wider issue (some kind of inability to output that specific resolution or 4:3 at above 800x600)? Please forgive my n00bn3ss, this is new territory for me.
01-15-2018, 11:09 PM
Please try out anarsoul mainline arch linux build which may able to support other displayresolution than typical HDMI standard one (720p or 1080p).
Here is the link: https://github.com/anarsoul/linux-build/releases/
01-16-2018, 03:05 AM
(01-15-2018, 11:09 PM)tllim Wrote: Please try out anarsoul mainline arch linux build which may able to support other displayresolution than typical HDMI standard one (720p or 1080p). I must apologise, I neglected to note that this was the Pine64 forum (I'm using a Rock64) - is this build of the same modernity with that platform? I'm keen to try it out if it offers some options.
09-30-2018, 12:01 PM
I tried the Arch distro and I can confirm that 1366x768 is supported just fine ... would that implies it's not a hw issue and a little massaging would allow it on Ubuntu Mate ?
That would be great to add a little more flexibility !! Thanks anyhow for the hard work. Lorenzo
10-04-2018, 12:21 AM
(09-30-2018, 12:01 PM)oxomoxo Wrote: I tried the Arch distro and I can confirm that 1366x768 is supported just fine ... would that implies it's not a hw issue and a little massaging would allow it on Ubuntu Mate ? Anarsoul's Arch distro is mainline Linux which can support wider range of resolution and also dual display (LCD + HDMI). The Ubuntu Mate using BSP Linux and only support 720P and 1080P output on HDMI port. In near future, developer plan to update Ubuntu Mate to mainline Linux.
10-21-2018, 01:48 PM
It seems that no matter what I do that with 1080p the top, bottom and sides always get cut off with overscan.
10-21-2018, 05:17 PM
I found the problem. It doesn't like monitors that do 1920x1200.
NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) | Baldnerd | 4 | 9,182 |
03-28-2020, 06:20 PM Last Post: ty1911 |
NEMS Linux for Pine A64 (+) | Luke | 1 | 5,080 |
05-09-2019, 05:42 PM Last Post: pineadmin |
Pine Board using linux stuck during boot sequence | ktaragorn | 4 | 8,166 |
03-30-2019, 06:48 AM Last Post: ktaragorn |
Gentoo Linux test image | xalius | 23 | 48,281 |
01-28-2019, 11:05 PM Last Post: necrose99 |
Real-time linux kernel | Artyom | 45 | 71,882 |
09-11-2018, 01:08 AM Last Post: zzwpine |
linux distribution | hazerty | 3 | 6,086 |
04-01-2018, 02:48 PM Last Post: dkryder |
Linux Web Server OS | harcrow | 2 | 5,775 |
01-30-2018, 10:26 AM Last Post: Rustproof |
eta linux image?? | firosiro | 1 | 4,031 |
08-03-2017, 10:05 PM Last Post: pfeerick |
Can I run Alpine Linux on Pine64? | douglasmiranda | 3 | 8,337 |
08-01-2017, 07:20 AM Last Post: cztian |
HOWTO: jackd on Pine64 | mauritslamers | 1 | 4,076 |
06-15-2017, 01:21 PM Last Post: xalius |
