Audio 3.5mm Jack not working
I installed LibreElec on my new ROCKPRO64. I have a hi-fi stereo which I want to plug on the audio jack 3.5mm. It doesn't work, meaning I don't have any sound. I don't know from were the problem comes from and I don't know how to investigate.
I post in general forum because I don't know if it's an hardware or Linux issue.
Thanks in advance for your help Smile
(05-05-2020, 03:09 PM)clement Wrote: Hello,
   I am not using LibreElec but Debian. But in order to enable the jack plug, I have first to enable the headphone mixer :
amixer set 'Right Headphone Mixer Right DAC' on
amixer set 'Left Headphone Mixer Left DAC' on
best regards.
LMM
Sorry for the late answer, I didn't get notification by email.
# amixer set 'Right Headphone Mixer Right DAC' on
amixer: Unable to find simple control 'Right Headphone Mixer Right DAC',0
I have no idea how to adjust parameters.
If I understood properly, I can use
# amixer scontrols
# amixer scontents
to list the devices, but it doesn't return anything.
# amixer info
Card default 'HDMI'/'HDMI'
 Mixer name : ''
 Components : ''
 Controls      : 3
 Simple ctrls  : 0
(05-23-2020, 02:26 AM)clement Wrote: Hi,
# amixer scontrols
# amixer scontents
# amixer info
 Mixer name : ''
 Components : ''
 Controls      : 3
 Simple ctrls  : 0
for me, amixer returns :
Card default 'rockchiprk3399'/'rockchip,rk3399'
 Mixer name : ''
 Components : ''
 Controls      : 35
 Simple ctrls  : 35
It seems that you are using hdmi output, therefore you have to switch the card.
You can probably use alsamixer command or
amixer -c 0 set Headphone playback 100% unmute
0 should be rockship sound card
Unfortunately,
# amixer -c 0 set Headphone playback 100% unmute
amixer: Unable to find simple control 'Headphone',0
(05-24-2020, 01:25 AM)clement Wrote: Unfortunately,
what do you have with:
cat /proc/asound/cards
 and
amixer -c 0 scontrols
amixer -c 1 scontrols
It's odd:
# cat /proc/asound/cards
cat: can't open '/proc/asound/cards': No such file or directory
LibreELEC:~ # amixer -c 0 scontrols
LibreELEC:~ # amixer -c 1 scontrols
amixer: Mixer hw:1 load error: No such device or address
LibreELEC:~ #
(05-24-2020, 02:23 AM)clement Wrote: It's odd:
LibreELEC:~ #
May be a problem specific to LibeELEC kernel (sound card module not loaded ?
Some things to try to search the config :
aplay -l # list the cards
lsmod | grep snd # list the loadable module
alsamixer # for configuring the mixer F6 to change card
you will find many information in /proc/asound (kernel version, ...)
you could try to install a new version of libreElec (if it is not updated)
Sorry, I am don't know very well libreELEC, I rather use ubuntu or debian.
I am curious to know where the pb comes from. Try the chat room, you may have quick answers.
I have the last version of LibreElec. There is no update since I installed it. I also rather Ubuntu, however, video performance were terrible and each attempt to fix it lead to a broken system, and Kodi does pretty much everything I want.
The audio controller seems to be seen by the OS
# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: HDMI [HDMI], device 0: ff8a0000.i2s-i2s-hifi i2s-hifi-0 []
 Subdevices: 1/1
 Subdevice #0: subdevice #0
card 1: ES8316 [ES8316], device 0: ff890000.i2s-ES8316 HiFi ES8316 HiFi-0 []
 Subdevices: 1/1
No sound module loaded, but I don't know how the kernel is build, maybe the driver was not compiled as module
LibreELEC:~ # lsmod | grep snd
LibreELEC:~ #
alsamixer was not installed. I installed it and tried to change sound card but alsamixer crashed
# alsamixer
cannot load mixer controls: No such device or address
I tried to rebuild LibreElec to check driver support on Linux kernel.
$ grep ES8316 LibreELEC.tv/build.LibreELEC-RK3399.arm-9.2-devel/linux-aa8bacf821e5c8ae6dd8cae8d64011c741659945/.config
CONFIG_SND_SOC_ES8316=y
So it is no surprise that
lsmod | grep snd
didn't return anything.
  Cant get rockpro64 working brasilikum 3 1,703 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,521 02-06-2023, 10:10 AM
Last Post: diizzy
  After Power Loss feature working bdherouville 2 2,121 08-22-2022, 03:52 AM
Last Post: bdherouville
Music No success with audio crmcalls 2 3,046 04-15-2021, 11:17 PM
Last Post: crmcalls
  No sound from rockpro64 audio jack. rahulsharma 2 4,385 11-18-2020, 04:46 AM
Last Post: Wizzard
  When did the wifi module start working? stormchaser3000 1 3,007 11-12-2020, 08:59 AM
Last Post: Darren
  micro SD Card Slot Spring not working, Cant boot mjembd 1 3,052 04-16-2020, 12:30 AM
Last Post: mjembd
  board not working kardanadm 7 8,962 08-31-2019, 07:37 AM
Last Post: kardanadm
  board not working with EMMC RockPro64Newbie 1 2,857 05-10-2019, 02:22 AM
Last Post: Unkn0wn
  PCIe SSD drive still not working ?? dr_ju_ju 7 9,044 04-15-2019, 04:16 PM
