Problem booting Pinebook Pro
Hi!
I'd installed Manjaro 20.04 in my PBP; I did all the mirrorlist change stuff, and I shut it down 2 days ago. Today when I was going to boot it, a red light has shown and it is not opening or doing anything else.
When I try to reinstall the Manjaro 20.04 I pressed ES after 15-20 seconds and there is a black window with blank letters that say:
"[5.102225] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:84Big Grinetected aborted journal
[5.103046] EXT4-fs (mmcblk1p2): Remounting filesystem read-only"
Today I tried to disable eMMc and installing Manjaro again but the problem persists. I have only been able to mount the Default Debian image from an SD card, but I don't know how to reinstall it to the eMMc or try to boot the eMMc another way... Any ideas?
Thanks very much!
(05-03-2020, 09:47 AM)gimy16 Wrote: Hi!
"[5.102225] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:84: Detected aborted journal
Thanks very much!
Did you check the integrity of the image you downloaded? Maybe using another SD-card might help too.
Besides quoting it, you can check the "Disable Smilies" checkbox when posting or editing the post to stop it from turning :D :P &c into emoji.
(05-18-2020, 04:55 PM)waweic Wrote: Did you check the integrity of the image you downloaded? Maybe using another SD-card might help too.
I tried to use another image and using another SD-card, the result was the same.
Then I contacted with the Pine64 support, and finally they said that it could be problem of the motherboard and that I had to change it.
Finally I got an USB to eMMC adapter from Pine64, I connect thee eMMC of my PBP to my PC and it was empty! So I downloaded the Manjaro image again, and I installed it into the eMMC using etcher; probably I did something wrong in order to erase all the data froom the eMMc; but now it's solved!
Thanks to all the community for the support!
  Pinebook Pro Initial Impressions kunger 443 585,329 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,244 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 379 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 283 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 276 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 208 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 641 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 713 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,488 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,177 12-15-2023, 02:11 PM
