New IRC server
(05-06-2020, 06:12 PM)digitaldaz Wrote:
(05-06-2020, 04:39 PM)fire219 Wrote:
(05-06-2020, 04:23 PM)digitaldaz Wrote: The new IRC server is also not irc cloud friendly.
I don't want to have to install a separate irc client just for these couple of irc channels, I guess its affecting a lot of people.
I keep getting dumped from the server with the following.
Closing Link: DigiDaz[ealing.irccloud.com] (Too many connections from your IP)
I'd argue that it's not that common of a problem as this is the first time I've heard from anyone about it.
Regardless, I have significantly increased the connections per IP limit, and you should be able to connect via irccloud now.
Thanks but still no go for me:
<OperServThe session limit for your IP 192.184.9.110 has been exceeded.
2:10 AM Closing Link: DigiDaz[ealing.irccloud.com] (OperServ (Session limit exceeded))
And today I discovered that Anope Services has its own max user-per-IP setting...
That too has been increased now.
(05-06-2020, 08:43 PM)Dendrocalamus64 Wrote: Hexchat is preinstalled on the PBP, widely available in various distros, and the debian version is like 627 kB + 4256 kB disk space for hexchat + hexchat common, two packages & one apt-get command.  Not exactly dependency hell & and it's not complicated to configure.
That might be the case, but it doesn't solve one of the major issues one would use a service like irc cloud for, which is continuous presence across devices... although for that I used to use a ssh tunnel into a pine64 I left permanently logged into IRC, and later I instead used weechat as a IRC relay. But hexchat is a simple and light option, available for most OSs and architectures. As far as use case the digitaldaz hinted at, best fix would be to reinstate the web IRC chat, but I don't see that happening as it was already falling apart before the transition to the cluster.
I completely agree with this option : Not exactly dependency hell & and it's not complicated to configure.
I think the certificate problems with IRC may have reoccured.
My GUI client just says "no" but connecting with a terminal one gives a fairly clear summary
                            10:47:17  pine64  -- | irc: reconnecting to server...
                            10:47:17  pine64  -- | irc: connecting to server irc.pine64.org/6697 (SSL)...
                            10:47:17  pine64  -- | gnutls: connected using 2048-bit Diffie-Hellman shared
                                                 | secret exchange
                            10:47:17  pine64  -- | gnutls: receiving 2 certificates
                            10:47:17  pine64  -- | - certificate[1] info:
                            10:47:17  pine64  -- |   - subject `CN=irc.pine64.org', issuer `CN=Let's
                                                 | Encrypt Authority X3,O=Let's Encrypt,C=US', serial
                                                 | 0x032660adffb527ea2734bad591dffbc278d0, RSA key 2048
                                                 | bits, signed using RSA-SHA256, activated `2020-07-25
                                                 | 16:22:12 UTC', expires `2020-10-23 16:22:12 UTC',
                                                 | pin-sha256="NAycHHs3pSoeTiSSYtQS4tDf1qBk7NobV4LqQf61rZA="
                            10:47:17  pine64 =!= | gnutls: certificate has expired
                            10:47:17  pine64  -- | - certificate[2] info:
                            10:47:17  pine64  -- |   - subject `CN=Let's Encrypt Authority X3,O=Let's
                                                 | Encrypt,C=US', issuer `CN=DST Root CA X3,O=Digital
                                                 | Signature Trust Co.', serial
                                                 | 0x0a0141420000015385736a0b85eca708, RSA key 2048 bits,
                                                 | signed using RSA-SHA256, activated `2016-03-17 16:40:46
                                                 | UTC', expires `2021-03-17 16:40:46 UTC',
                                                 | pin-sha256="YLh1dUR9y6Kja30RrAn7JKnbQG/uEtLMkBgFF2Fuihg="
                            10:47:17  pine64 =!= | gnutls: peer's certificate is NOT trusted
                            10:47:17  pine64 =!= | irc: TLS handshake failed
                            10:47:17  pine64 =!= | irc: error: Error in the certificate.
                            10:47:17  pine64  -- | irc: reconnecting to server in 40 seconds
  Instructions to join IRC server: pine64.xyz Luke 12 26,459 05-23-2018, 09:57 PM
Last Post: pfeerick
