Building a new SD card
I'm trying to get my RockPro64 onto a new SD card. Under Linux, as root I run:
7z x ./Armbian_20.02.1_Rockpro64_buster_legacy_4.4.213.7z
./balenaEtcher-1.5.70-x64.AppImage ./Armbian_20.02.1_Rockpro64_buster_legacy_4.4.213.img
When done, my SD looks like this:
root@mozart:/home/njc/dev/taz# fdisk -l /dev/sdc
Disk /dev/sdc: 14.9 GiB, 15931539456 bytes, 31116288 sectors
Disk model: Card  Reader
Disklabel type: dos
Disk identifier: 0x019a33bc
Device     Boot Start     End Sectors  Size Id Type
/dev/sdc1       32768 2899967 2867200  1.4G 83 Linux
I then put it into the RockPro64, power it up and I see nothing. I have no WiFi and the console doesn't spit out anything.
The old SD card that still boots (but with an OS that is very unstable) has:
njc@taz:~$ df -h
Filesystem      Size  Used Avail Use% Mounted on
udev            1.9G     0  1.9G   0% /dev
tmpfs           388M  5.4M  383M   2% /run
/dev/sda2       1.8T   35G  1.7T   2% /
tmpfs           1.9G     0  1.9G   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
/dev/mmcblk0p6  112M  4.0K  112M   1% /boot/efi
tmpfs           388M     0  388M   0% /run/user/1001
njc@taz:~$
Is this enough information to figure out what is wrong?
I've upgraded SDs with x86, Pi and Toradex but the RockPro64 is giving me no end of fits.
are you sure your new SD ist not broken.
Why not make a copy using dd or ddrescue of
The good SD to a file for backup purpose and
copy the new OS on that SD, maybe that works.
M
(04-26-2020, 11:12 PM)mabs Wrote: Hi,
M
Nope, 100% positive, SD is good, computer is also good.
I was poking around the site when I noticed on the front page (who read that ... ;-) ) and found that there is an official version of Debian. So I followed the links, zcat'd the images together and etcher'd the image to the same SD card. Not only did it boot, I now have serial port access at 1500000 (1.5Mbaud - sure beat the 110 baud I started out with decades ago).
Official Debian support
https://forum.pine64.org/showthread.php?tid=9744
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 989 02-17-2022, 12:10 PM
Last Post: flounder
  HBA Card working on Aufan's builds but not in debian, armbian or dietpi charsi 1 1,822 10-29-2021, 11:15 AM
Last Post: TRS-80
  Power supply underpowered for Rockpro64, deficient PCIe SATA card, or something else? daffy 8 6,650 05-20-2021, 10:04 PM
Last Post: t4_4t
  Best way to avoid SMP internal errors when building RAID? kuleszdl 1 1,852 02-26-2021, 07:23 PM
Last Post: kuleszdl
  Building a custom kernel on @mrfixit's Debian distro? Tim Jones 1 2,819 06-14-2019, 11:21 PM
  Marvell 88SE9235 PCI SATA card in LibreELEC StefanRvO 6 7,118 05-18-2019, 04:21 AM
Last Post: p1x3l3d
  issues loading firmware and missing pci card rich0 7 8,604 04-06-2019, 03:34 PM
Last Post: rich0
  Is PINE64 building a Custom Linux for RockPro64? Ben Hayat 3 5,782 06-03-2018, 08:33 PM
Last Post: elatllat
