WD NVMe not recognized
At first, I tried to install a Samsung NVME that kept crashing the PBP.  After reading about the power problems, I checked the compatibility chart and exchanged it  for a WD NVMe BLue SN550 1TB drive.  Now the system does not even recognize the drive is there.
Can anyone suggest why this is happening?
(04-19-2020, 02:24 PM)fbshilli Wrote: At first, I tried to install a Samsung NVME that kept crashing the PBP.  After reading about the power problems, I checked the compatibility chart and exchanged it  for a WD NVMe BLue SN550 1TB drive.  Now the system does not even recognize the drive is there.
According to the specs I just looked at that"s a SATA type drive and shouldn't work at all, only pcie type drives are supported. I don't know why it in the comparability table as working, maybe WD are using confusing part numbers? But that's probably what you should check first.
Sing confusing part numbers
Thank you!   Yes, this is a SATA drive.  I hope some can edit the compatibility chart so others won't be confused.
unfortunately this happen to me too!
I'll did a quick order based on the compatibility list ;(
i'll put the SSD in my desktop and order a better compatible one,
PS I added a WARNING in the compatibility list! If others agree set it to NOT compatible!
Regards Paul
I just bought a WD Blue SN550 250GB NVMe drive (product code WDS250G2B0C) and it works fine in my Pinebook Pro.
Maybe different sizes have different interfaces?
(04-19-2020, 06:39 PM)fbshilli Wrote: Thank you!   Yes, this is a SATA drive.  I hope some can edit  the compatibility chart so others won't be confused.
You actually can! Your forum login is also your login for the wiki.
Are you sure that is a WD SN550 1TB drive? I thought these were NVME and was looking at that personally as it looks like the best low power option.
edit: this one? https://shop.westerndigital.com/products...DS100T2B0C
  New Working nVME gilwood 0 204 02-12-2024, 08:46 AM
Last Post: gilwood
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,504 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 1,789 11-28-2022, 12:56 PM
Last Post: dachalife
  NVMe drives not detected mattpenn 12 10,305 03-05-2022, 04:53 AM
Last Post: mattpenn
  NVme intall usage? tkudog 2 2,872 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,842 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe-related crashes and instability, plus a solution simonsouth 13 14,622 12-10-2021, 07:47 PM
Last Post: josmo
  NVMe SSD testing methodology halogen 1 2,610 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,746 07-09-2021, 08:45 PM
Last Post: moonwalkers
  nvme drive disappears after about an hour of uptime codebreaker 25 31,951 02-09-2021, 11:32 PM
Last Post: dsimic
