No audio output with Manjaro Arm 20.04
SBC:    RockPro64 4Gb v2.1
OS:     Manjaro-ARM 20.04
            Linux rockpro64 5.6.0-1-MANJARO-ARM #1 SMP Tue Mar 31 12:35:20 CEST 2020 aarch64 GNU/Linux
Greetings Piners, any news on getting audio to work
on a RockPro64 running Manjaro Arm 20.04?
TIA,
/Faradn
~ Odroid N2 ~ Odroid XU4 ~ RockPro64 ~ Pi3B ~
(04-13-2020, 05:11 PM)Faradn Wrote: SBC:    RockPro64 4Gb v2.1
TIA,
/Faradn
Audio does work on HDMI output.
Jack does not, could not try SP/DIF.
Kernel dts and driver seems ok, I do not know what is wrong.
TIA,
/Faradn
Yeah, so I figured my RockPro64 was broken for months, because the audio out didn't work even though it looked like you switched the audio to the audio jack.
It appears it was not in fact broken, atleast the hardware was not.
You now have to 'force' enable it in Alsa manually to get it going:
https://forum.pine64.org/showthread.php?tid=9794
Also, you might additionally have to save the alsa configuration so that it gets restored after a reboot.
But with the above manual intervention, it works OK. It does remain a little low on volume though.
So, this means the dtb and the driver is not in fact OK. In fact, it is broken.
Otherwise alsa and pulseaudio would have found it and enabled it correctly.
And it doesn't, so it isn't.
Clearly it is way more fun to create watches and smartphones than it it so make your most premium top-of-the-line product work right. And so it doesn't, and support for the RockPro64 board is comparatively minimal... In fact, it feels all but abandoned. In fact, even the basics of just booting the RockPro64 remains difficult. The uboot / spi situation remains problematic, unofficial and untested. Which is a little sad, because it is in fact an awesome little machine with a lot of unrealized potential. So much potential...
  rk3399 and Visual Output Processor 2 (VOP2) swan 3 1,390 05-13-2023, 12:01 AM
Last Post: swan
  A fix for Bluetooth audio stuttering on the RockPro64 raph 2 1,666 01-03-2023, 06:53 PM
Last Post: raph
  SPDIF output audio gaps jssfr 2 1,736 07-24-2022, 06:26 AM
Last Post: jssfr
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 1,036 02-17-2022, 12:10 PM
Last Post: flounder
  CPU Fan Won’t Turn On in Manjaro publiclewdness 0 884 12-31-2021, 12:51 AM
Last Post: publiclewdness
  Manjaro ARM - Built-in ethernet was broken with kernel 5.14.1-1 (over now) Dendrocalamus64 2 2,297 09-11-2021, 08:58 PM
Last Post: t4_4t
  Headphone jack issues Manjaro Mangled 2 2,800 03-06-2021, 11:01 PM
Last Post: Mangled
Thumbs Up First Manjaro Mainline build! Luke 10 15,885 10-20-2020, 04:29 AM
Last Post: vfr400racer
  Wifi on Manjaro User 19517 0 1,890 09-14-2020, 06:53 PM
Last Post: User 19517
  RockPro64 Linux Manjaro HDMI 4K mkne 12 14,575 05-03-2020, 07:23 AM
Last Post: PakoSt
