Booting from microSD
I have Ubuntu on my card. I testeed it on my Linux laptop, and in Windows; it works there. On PBP the first time I tried it, it seemed to recognize it as bootable, but hung up. Since then it merely mounts it. How do I get it to boot from the card?
PineBook Pro has an ARM compatible CPU. That's not Intel compatible code. It's incompatible with Intel/AMD programming.
(04-12-2020, 07:46 PM)evj Wrote: I have Ubuntu on my card. I testeed it on my Linux laptop, and in Windows; it works there. On PBP the first time I tried it, it seemed to recognize it as bootable, but hung up. Since then it merely mounts it. How do I get it to boot from the card?
go to the wiki, read it a little and this page lists in a detail, what the images you can get that work.
ANT - my hobby OS for x86 and ARM.
(04-12-2020, 08:04 PM)Samurai_Crow Wrote: PineBook Pro has an ARM compatible CPU.  That's not Intel compatible code.  It's incompatible with Intel/AMD programming.
Oh, thanks. I am old to computing (started in 1957), have used Unix, and have Linux (Ubuntu) on my portable, but I am a novice at computer hardware and Linux administration.
When you look at the wiki,  there is a fairly good selection of distributions to choose from.
    ( NO straight Ubuntu yet, but some similar )
   Please do notice most are available for your choice of SD card installation or eMMC installation.
Especially if you want to install a particular OS to the eMMC,  **   but keep the ability to boot from the SD card. ?
TONS of good information in the wiki.
I "SUGGEST" trying it from the SD card first before installing to your eMMC.
It runs 'ok' from an SD card just a little slower.
But you can "SEE" if you like a particular OS before permanently installing it.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  Followed the blog post to install Fedora: PBP not booting anymore koenigs 6 1,854 06-01-2023, 10:58 AM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,471 04-23-2023, 06:58 AM
Last Post: acruhl
Exclamation PineBook Pro shuts down immediately after booting zogkarndon 5 1,954 01-10-2023, 10:16 AM
Last Post: Perl6_user
  Total Noob. Need help booting from SD Mattchublean 18 13,332 07-23-2022, 11:54 PM
Last Post: LivingLinux
Wink Booting Windows on bare-metal rk3399 SBC (no linux involved) strongtz 9 10,432 05-26-2022, 11:36 PM
Last Post: strongtz
  PInebook not booting with eMMC enabled aragaer 4 4,206 10-25-2021, 09:11 PM
  Manjaro i3 Edition not booting mtndew 0 1,567 08-23-2021, 06:21 PM
Last Post: mtndew
Video Problem Booting from SD card ezryder324r 0 1,452 05-19-2021, 02:42 PM
Last Post: ezryder324r
  Forgot my Pinebook password. Booting from MIcroSD doesn't work. ksfoodforest 0 1,748 01-30-2021, 11:08 AM
Last Post: ksfoodforest
  Booting to sdcard stopped working after emmc flash techiedog 3 3,904 12-31-2020, 06:30 PM
Last Post: Anarethos
