get battery status on the command line
Apologies for the newbie question, but I've been stymied on this so far-- what's a good way to get the PBP battery status (percentage or time remaining, plugged in or on battery, etc) on the command line?
If it matters, I'm on Manjaro 20.04.
(04-04-2020, 06:10 PM)rossk Wrote: Apologies for the newbie question, but I've been stymied on this so far-- what's a good way to get the PBP battery status (percentage or time remaining, plugged in or on battery, etc) on the command line?
On Manjaro,  you can use the tlp-stat  command: tlp-stat -b gives basic battery info.  tlp-stat --help gives further explanations/possibilities.
You can also cat some of the files in the /sys/class/power_supply/cw2015-battery directory.
There are other programs that will give battery  statistics if those ideas don't work for you.  Just web  search on something like
"linux battery statistics from console".
Yeah-- most of the answers I got from general searches like that, weren't giving me useful results (things like the acpi tools, which aren't helpful on the PBP).
but, /sys/class/power_supply/cw2015-battery/ is exactly what I was looking for. Thanks!
  Is the same DD command appropriate for writing EMMC and SD cards wpeckham 4 3,868 09-23-2021, 09:19 PM
  Enabling spekaer/Connecting to bluetooth from command line axisarm 1 1,888 08-06-2021, 04:29 PM
Last Post: nfms
  Battery gauge issue (mainline kernel) lfourquaux 4 4,851 05-22-2021, 02:43 PM
Last Post: jiyong
  eMMC frequently not found by Linux kernel (especially on low battery) v-man 14 16,175 05-14-2021, 01:18 PM
Last Post: djhnsn
  Battery charge threshold xNix 1 2,143 04-17-2021, 07:13 AM
Last Post: Damon
Question Manjaro arm + sway - battery indicator broken mfashby 6 6,585 02-20-2021, 04:07 AM
Last Post: mfashby
  Status stonepound 0 1,585 11-18-2020, 01:35 PM
Last Post: stonepound
  Possible battery and performance improvement xehartnort 4 5,486 11-09-2020, 12:26 AM
Last Post: rimaille
  Manjaro - No battery info after plugged in AlecM 4 5,943 09-16-2020, 08:34 PM
Last Post: zer0sig
  CPU Configuration and Status Scripts for PBP/Linux Syonyk 2 3,634 06-26-2020, 08:53 AM
Last Post: Syonyk
