TP-Link ARCHER T2U PLUS AC600 unrecognized/build error
Greetings!
I wanted to use this wifi antenna, but it isn't recognized, so I tried to hunt some drivers for it.
I managed to find some drivers that could be good, maybe, but when I do the build process, I always get "(bad exit status: 2)"
What can be the problem?
I tried to install this:
https://github.com/aircrack-ng/rtl8812au
Tried to change the parameters (chose RPI - had no better idea) as in the guide...
Then I got this error:
"About to run dkms install steps...
Creating symlink /var/lib/dkms/rtl8812au/5.6.4.2/source ->
/usr/src/rtl8812au-5.6.4.2
DKMS: add completed.
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area...
ARCH=arm 'make' -j6 KVER=4.4.190-1233-rockchip-ayufan-gd3f1be0ed310 KSRC=/lib/modules/4.4.190-1233-rockchip-ayufan-gd3f1be0ed310/build.....(bad exit status: 2)
ERROR (dkms apport): binary package for rtl8812au: 5.6.4.2 not found
Error! Bad return status for module build on kernel: 4.4.190-1233-rockchip-ayufan-gd3f1be0ed310 (aarch64)
Consult /var/lib/dkms/rtl8812au/5.6.4.2/build/make.log for more information.
Building module:
ARCH=arm 'make' -j6 KVER=4.4.190-1233-rockchip-ayufan-gd3f1be0ed310 KSRC=/lib/modules/4.4.190-1233-rockchip-ayufan-gd3f1be0ed310/build....(bad exit status: 2)
Finished running dkms install steps."
What have I done wrong?
  interface error on OMV chengjianwen 0 1,826 03-27-2019, 08:19 AM
Last Post: chengjianwen
Exclamation physical disk properties Standby error Neo2018 0 1,946 03-16-2019, 11:41 AM
Last Post: Neo2018
