128GB eMMC Preinstalled?
Am I correct in assuming that if I order the Pinebook Pro (ANSI, US) with the 128GB eMMC, I will get it with the 64GB eMMC installed and get a separate 128GB eMMC card that I would have to install myself?
I am not too afraid to open up the laptop and tinker inside, but it would be convenient to get the 128GB eMMC as a preinstalled option.
Thanks.
This has been discussed as desirable, but no confirmation yet that it will be offered in the future. I do believe that this would be a very welcome option. there are a lot of folks living in the gap of desiring >64GB and <NVME. 128GB or 256GB emmc would fit that gap nicely, and imho emmc is perfect for the pbp.
(03-30-2020, 07:58 AM)haziz Wrote: I am not too afraid to open up the laptop and tinker inside, but it would be convenient to get the 128GB eMMC as a preinstalled option.
Please vote in my poll. : D
Could you please add 128GB eMMC as a build option for this preorder?
Also I see that "Pre-installed eMMC: None" is emerging as a desirable build option.
- If you already have enough of them sitting around and you don't want to buy another one
- If you want a size other than the available build options
- If you want to go NVME only (in the future)
(03-30-2020, 10:30 AM)xmixahlx Wrote: This has been discussed as desirable, but no confirmation yet that it will be offered in the future. I do believe that this would be a very welcome option. there are a lot of folks living in the gap of desiring >64GB and <NVME. 128GB or 256GB emmc would fit that gap nicely, and imho emmc is perfect for the pbp.
I totally agree. In addition, if I'm not mistaken, an nvme memory currently does not correctly allow the suspend function. When you need a larger memory better use an external usb.
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 59,118 11-20-2023, 06:22 PM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,384 04-23-2023, 06:58 AM
Last Post: acruhl
  Doesn’t power on after flashing emmc badguru 3 1,138 02-25-2023, 09:00 PM
Last Post: badguru
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 1,615 02-21-2023, 01:49 AM
Last Post: repa
  Partial boot after installing Manjaro on emmc regivanx 11 2,957 02-06-2023, 09:11 AM
  Unable to Boot anything (emmc or SDcard) line72 5 1,895 01-17-2023, 12:07 PM
Last Post: nfms
  What OS have you recently flashed onto PBP eMMC? jcun4128 6 2,245 11-26-2022, 09:39 AM
  Unable to boot from emmc after flashing it rfm83 3 1,681 11-08-2022, 10:59 PM
Last Post: rfm83
  Pinebook picky about which EMMC will boot flatulent_piney 8 2,885 11-05-2022, 06:03 PM
Last Post: ajtravis
  After Flashing eMMC, Will Not Boot Mossbot 5 2,228 09-28-2022, 06:22 PM
