pmos plasma
after a run of apk upgrade.
the phone app will not open , the icon opens to full screen ,then goes off   ?
Yup, I know this issue already. I just pushed a fix, but it has to be build first. Please update your system again in an hour or so.
(03-30-2020, 08:47 AM)PureTryOut Wrote: Yup, I know this issue already. I just pushed a fix, but it has to be build first. Please update your system again in an hour or so.
pmbootstrap has quit working, on my Deepin OS :- so i tried the demo version and upgraded  that , this time ,no phone icon. but 293 upgades at once is probably a bit too much.
(03-31-2020, 11:38 AM)colin hodsdon Wrote: pmbootstrap has quit working, on my Deepin OS :-
Interesting, please report the errors you're having.
(012593) [14:01:04] % tail -f /home/colin/.local/var/pmbootstrap/log.txt -n 60
(012593) [14:01:04] *** output passed to pmbootstrap stdout, not to this log ***
i am using ubuntu 18:04 now , give it a try there
tried again same result,
 i flashed the last demo, and used (ssh) to apk update and apk upgrade ( 296) items , still lost the phone icon,  ( seems fine otherwise )
That is not the error... Please post the full thing.
  Fresh install pmos+phosh does not boot user641 1 486 10-08-2023, 04:04 AM
Last Post: user641
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 780 10-03-2023, 06:32 PM
  Boots To Shell After Dead Battery (PMOS) britelite 0 715 02-17-2023, 02:41 PM
Last Post: britelite
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & No MMS X0X0X0X0X0 1 1,391 11-07-2022, 10:34 PM
Last Post: X0X0X0X0X0
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 1 1,158 11-06-2022, 06:41 PM
Last Post: Chief
  No Application Data PMOS 21.12.1 Captain1ndustry 4 3,857 08-12-2022, 07:42 AM
Last Post: Gon
  pmos/phosh edge update and audio disappears robthebold 9 5,512 07-10-2022, 03:26 AM
Last Post: arkadione
  Application list PMOS-Phosh jmorris 6 6,122 12-04-2021, 02:26 AM
Last Post: Juergen
  [PostmarketOS with Plasma Mobile] Angelfish adblock + wpa supplicant time out Egolep 0 2,011 03-23-2021, 10:25 AM
Last Post: Egolep
  PMOS test image: failed EG25 test broke modem fw MtnSk8 4 5,681 02-28-2021, 02:20 PM
Last Post: MtnSk8
