Manjaro
I have one of the early PBPs.  I just flashed Manjaro, and I noticed all the GUI effects seem REALLY slow.  I'm new to Manjaro.  Is there an easy way to see what the CPU settings are (Debian had CPU/power save settings on panel, Manjaro doesn't.)
Also, WiFi is much better.  The install seems to freeze unless you hit "Esc", but someone already mentioned that on here somewhere.
I think right now Manjaro defaults to Xrender backend for compositor, change it to OpenGL and reboot to redraw the UI, that should do it.
(03-26-2020, 04:06 AM)agurenko Wrote: I think right now Manjaro defaults to Xrender backend for compositor, change it to OpenGL and reboot to redraw the UI, that should do it.t
Wow!  That totally fixed it.  It's fast now.  Why isn't that he default on PBP Manjaro builds?
Oh, this is nice! Manjaro feels a lot better now! Good stuff!
Is there also a way to get rid of the low volume high pitched whining noise I hear when no audio is playing?
May I ask how to do that ? Thanks
System Settings -> Display and Monitor -> Compositor -> Rendering backend Change it to OpenGL and Scale Method to Accurate
  Manjaro versions bad and good gilwood 0 191 02-12-2024, 05:03 PM
Last Post: gilwood
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,001 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 563 12-13-2023, 08:17 PM
Last Post: trillobite
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 314,558 05-12-2023, 06:09 AM
Last Post: korreckj328
  Manjaro Plasma blinking cursor jcun4128 4 1,376 05-08-2023, 11:17 AM
  PBP blank screen after updating Manjaro Franko 6 1,878 04-01-2023, 07:55 AM
Last Post: hacknix
  Manjaro - which libdrm? hacknix 0 529 04-01-2023, 03:21 AM
Last Post: hacknix
  Partial boot after installing Manjaro on emmc regivanx 11 2,968 02-06-2023, 09:11 AM
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 4,525 01-22-2023, 10:05 PM
Last Post: rfm83
  No boot after Manjaro flash PBcurry 14 5,155 10-03-2022, 08:33 PM
