Bluetooth issue, don't know what I'm doing wrong.
Default Debien installed, Mrfixit, touchpad, and Winevine updates done.
Sound works fine UNTIL I hook up a bluetooth Pioneer Ironman headphone. It connects just fine, shows as the output but it wont work. Netflix in Chromium stays buffering and the headphones stop working, cant even turn them off. I turn off bluetooth on the PBP and the headset and netflix start working just fine. Connect back to the headphones and it locks back up.
Has anyone experienced this and if so, is there a solution?
Thanks,
Michael
try this process with youtube or a local media file to separate netflix as the issue.
it has been a long while for me on the default os, but i tested a bluetooth speaker just fine.
make sure you are using the right bluetooth settings for your device - sink source and output.
  PineBook Pro - Did I buy the wrong computer? astral 8 4,330 05-04-2023, 05:47 AM
Last Post: korreckj328
  Newbie with immediate issue jasonumd 1 976 03-04-2023, 05:59 PM
Last Post: hacknix
  suckless surf on arch linux pinebook pro scrolling issue gehn5 0 975 04-16-2022, 07:41 PM
Last Post: gehn5
Question USB-C Video Out Issue dev 2 1,858 02-08-2022, 07:28 PM
Last Post: dev
Bug Wrong FN keys after keyboard FW update j4n3z 2 2,574 10-19-2021, 01:57 AM
Last Post: j4n3z
  pinebook pro wiki link on the website links to the wrong wiki entry Julius_GU 0 1,351 02-11-2021, 10:27 AM
Last Post: Julius_GU
Bug [Fixed] Issue with mesa-git (Manjaro ARM Stable Update 2020-09-22)) JasonG-FR 20 21,769 12-12-2020, 05:09 AM
Last Post: mogwai
  Pinebook Pro PCIe init issue R32Fanboy 4 5,303 11-05-2020, 09:59 AM
Last Post: vssz
  Boot issue (red light) pineitup 10 10,084 11-01-2020, 11:26 PM
  Boot issue DarrowAtreides 0 1,710 10-29-2020, 07:23 AM
Last Post: DarrowAtreides
