Help with recovering PBP which doesn't turn on
something weird happened with my PBP. I've had an issue with Manjaro repositories which I wanted to solve by reflashing it. I've plugged in SD card with the stock debian, and happily dd-ed a compressed file instead of using Etcher or something. After a reboot attempt, PBP didn't turn on. To be more precise: there's a total lack of reaction for pressing the "Power on" button. No LED blinking/turning on, nothing.
What I've tried:
- booting from SD card with said Debian
- charging it up a bit
- turning eMMc off
- pressing the reset&recovery buttons located next to eMMc
- reflashing the eMMc with various images
Nothing changed. I press the button, LED's don't turn on.
Any advice?
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,156 12-15-2023, 02:11 PM
  Doesn’t power on after flashing emmc badguru 3 1,216 02-25-2023, 09:00 PM
Last Post: badguru
  Pinebook Pro won't turn on after flashing image Idaho 2 1,082 02-21-2023, 02:31 PM
Last Post: Idaho
  Pinebook Pro not turn carbo29 11 6,408 03-12-2022, 12:42 PM
Last Post: carbo29
  Pinebook Pro won't turn on when unplugged decisivedove 7 8,025 02-28-2021, 09:44 AM
Last Post: mattpenn
  Forgot my Pinebook password. Booting from MIcroSD doesn't work. ksfoodforest 0 1,743 01-30-2021, 11:08 AM
Last Post: ksfoodforest
  NVMe doesn't show up Seferi 19 17,126 10-30-2020, 07:08 AM
Last Post: ReddestDream
  Pinebook Pro doesn't boot most of the time unless connected via USB-serial! nib0 16 13,186 09-29-2020, 10:24 PM
  Soft restart doesn't work dgkPBP 9 8,653 09-19-2020, 09:40 AM
  Trackpad doesn't pick up small movements dieselnutjob 3 4,395 07-15-2020, 06:18 AM
Last Post: dieselnutjob
