Manjaro and Arch repository with privacy oriented software
#81
(07-28-2021, 05:24 AM)llsf Wrote: Good news "annahellrothsparent": standardnotes-desktop is back in the repo again, thanks to some extra motivation from https://github.com/standardnotes/forum/issues/1241 ^^
You must remove the AT symbol from your post for it to display properly.  I expect that is being worked on, but there seems a minor bug in the forum software.
(02-18-2022, 02:53 PM)tallfrye Wrote: Just bought a pbp. Long time Arch user, not a fan of Manjaro, so looking to switch the OS. I made an SD following the instructions at https://github.com/SvenKiljan/archlinuxa...INSTALL.md
When I put the SD in my pbp and start it up, it boots into Manjaro. The SD shows up in Dolphin with BOOT_ALARM and ROOT_ALARM. I made another installation on another SD, same result.
The wrinkle I'm seeing is the file manager when I'm writing the SD card registers the card as mmcblk0 instead of sdX. I substituted the name in the instructions and followed them otherwise with apparent success. I'm using Gnome 40.4.0 on an Arch install.
Is the SD file naming scheme causing the boot loader to skip over it?
I used the images linked form this page https://wiki.pine64.org/wiki/Pinebook_Pr..._Downloads
I normally burn my SD cards using dd, but there are other tools.
Mine have all worked except one, and that was due to an SD card that did not perform to U3 (or even U1) standard.
Ancient teacher (Secondary Field Science/Math), Warrior (USARNG- RET SSG), and IT warrior (30+ years Coder, Network/Systems Administrator, general house geek).
Pinebook Pro user (Debian, Manjaro)
(02-19-2022, 01:07 PM)wpeckham Wrote: I used the images linked form this page https://wiki.pine64.org/wiki/Pinebook_Pr..._Downloads
The github image I linked to is where the pinewiki directs you to. The instructions there use dd to copy the image, but also include a number of instructions about structuring the partitions on the SD card before the copy. The result doesn't seem to be visible to the pbp system while booting. Where would I look to find more on boot criteria for the pbp?
What's with all the (many) deleted posts in this thread? It's just bizarre.
Cheers,
TRS-80
Protocols, not Platforms
(02-22-2022, 05:13 PM)TRS-80 Wrote: What's with all the (many) deleted posts in this thread?  It's just bizarre.
Very weird. Not uncommon around the web these days, but why would anyone here be criticizing public health policy?
I was going to try a different OS and noticed that the install directions for PostmarketOS claim you need to physically disable the SPI and eMMC memory to allow the SD card to boot. This seems to have changed at some point, but the documentation I'm seeing doesn't clearly state when they are talking about what version. Any recollection of what versions have what boot schedule?
I was about to take off the back and start flipping switches, but the third try with a restart suddenly went to the SD card and it booted into ArchARM finally...
Answering my own question, the missing posts are a forum-wide problem. Using an at sign (anywhere in a post) triggers it, apparently.
Cheers,
TRS-80
(07-28-2021, 05:24 AM)llsf Wrote: Good news @annahellrothsparent: standardnotes-desktop is back in the repo again, thanks to some extra motivation from https://github.com/standardnotes/forum/issues/1241 ^^
Wow I haven't logged in in quite some time, but this is really excellent news! Thanks for sharing!
  By the way, yay arch... KC9UDX 4 716 03-30-2024, 10:27 PM
  Manjaro Sway Theme Broken Eighty8 1 278 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,749 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 326 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,135 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,206 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 403 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 885 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,018 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,966 08-21-2023, 09:08 PM
