How to enable boot logs on PBP
Hello everyone,
I'd like to see the kernel boot messages instead of the splash screen when booting up my pinebook pro. I'm running on the default debian image.
In the wiki there is a section about it (https://wiki.pine64.org/index.php/Pinebo...e_messages) mentioning a u-boot config file at `/etc/default/u-boot/` and an update command (`u-boot-update`).
The problem is my filesystem has neither of those. The next best thing I could find is a config file at `/boot/extlinux/extlinux.conf`, suggesting the use of syslinux instead of u-boot.
Can someone clarify this for me? Is the wiki outdated or something is wrong with my installation?
Deceptive, nothing at all to do with syslinux
Just another, different interface to u-boot,, instead of boot.txt/boot.scr OR boot.cmd/boot.scr/uEnv.txt
So no use looking for the unicorn, a menu.c32 in ARM64, even if you found, wouldn't work
You could try,, copy extlinux to *.orig, edit removing bootsplash
Let us know
The simplest way to see the boot-time messages is change the file /boot/extlinux/extlinux.conf from "console=ttyS2,1500000n8" to "console=tty1". It doesn't log the messages, but at least you can see them.
  uboot wont boot to SD card after upgrade jbradley419 7 813 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 288 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,222 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 686 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 584 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,172 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,866 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 798 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 1,932 06-14-2023, 07:20 AM
Tongue Yet another Pinebook Pro won't boot thread pinemouth 4 2,426 05-20-2023, 01:02 AM
Last Post: jackwilson
