Broken power key or keyboard, can I still turn it on?
Since I spilled water on my keyboard, I have with the help of a 2nd pinebook narrowed down the issue of its nonfunction to the power button itself. I simply can't find an alternative way to turn it on. How do?
What happened to the active community for this thing?
It's still cool, where are you?
I'll reverse engineer the keyboard my own self.
(03-15-2020, 12:58 PM)aaspectre Wrote: What happened to the active community for this thing?
You shouldn't have to reverse engineer anything. There are schemattics (although it is also useful to take a look at the device tree to see how the power key is specially handled):
https://wiki.pine64.org/index.php/Pinebo...ifications
Based on the schematic and devicetree, I'm pretty certain the power key is a simple physical button and it bypasses the keyboard controller entirely. There's a signal running directly from the 30 pin connector to the PMIC PWRON pin, I think this is the power key.
Yeah, it appears stuck in the on position. So I just put the ribbon cable in, then removed it before it turned off again. It's a place to start.
(03-16-2020, 12:32 AM)aaspectre Wrote: Yeah, it appears stuck in the on position. So I just put the ribbon cable in, then removed it before it turned off again. It's a place to start.
If you needs replacement, please contact sales@pine64.org and they are quote you accordingly.
  Lockable-until-power-cycle persistent storage Melab 0 706 09-17-2023, 08:51 PM
Last Post: Melab
  Dead Pinebook Pro Keyboard Keys calinb 2 1,034 09-02-2023, 12:31 PM
Last Post: calinb
  power on Pinebook Pro mainboard without keyboard? papable 0 827 07-20-2023, 11:06 PM
Last Post: papable
  When does Pinebook Pro power LED go on? Bram 0 621 03-14-2023, 09:53 AM
Last Post: Bram
  Doesn’t power on after flashing emmc badguru 3 1,232 02-25-2023, 09:00 PM
Last Post: badguru
  Pinebook Pro won't turn on after flashing image Idaho 2 1,092 02-21-2023, 02:31 PM
Last Post: Idaho
  Broken usb-c to hdmi with kernel 5.18+ rfm83 6 2,824 01-22-2023, 09:55 PM
Last Post: rfm83
  ISO keyboard Pinebook pro for sale tgrauss 3 3,586 11-01-2022, 04:45 AM
Last Post: tgrauss
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 1,926 10-08-2022, 06:22 PM
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 3,269 09-14-2022, 03:56 AM
Last Post: Carl
