New LCD Display for ROCK64Pro
There are lots of 1920x1200 MIPI LCD with CTP available on the market.
Their pinout can easily be connected to that of the ROCK64Pro MIPI connectors via a simple board that would connect the proper pins together so from a HW point of view it is pretty straightforward.
My question is would it work straight out of the box or is there a need to modify the kernel or some initialization files to get a specific MIPI LCD screen to display with the ROCK64Pro.
Any help guiding towards what should be done from a SW point of view would be greatly appreciated. Thank you!
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 549 04-23-2023, 11:02 PM
Last Post: Thisone
Bug Unreliable display in Armbian and Debian ksattic 3 3,151 11-17-2021, 05:42 AM
Last Post: PakoSt
  eDP and dual display StefanH 0 1,502 11-13-2019, 10:25 AM
Last Post: StefanH
  Rock64Pro and 4K resolution rrosenheim 1 3,148 06-16-2019, 04:53 PM
Last Post: Luke
Question NextCloud with Rock64Pro aj64 2 4,325 01-14-2019, 06:22 AM
Last Post: aj64
