eMMC on Pinebook Pro
(03-11-2020, 10:24 AM)decisivedove Wrote:
(03-11-2020, 06:11 AM)tophneal Wrote:
(03-10-2020, 10:06 PM)decisivedove Wrote:
(03-10-2020, 06:00 PM)wdt Wrote: >Is there anyway to use GRUB on ARM?
Did you not check the odroid link?
Like  I said,, let us know
I have not checked it out yet. Will check it out. I think I might start another post for GRUB on PBP.
Please do a search instead. There is already at least one thread about running GRUB with u-boot on the PBP.
Ok I will. The UI on mobile is not intuitive to use e.g. the search. Maybe that is something which should be worked on while maintaining the website. Nothing much, just add like a search textbox and button on the top of the page for search in the mobile interface.
That is actually something that's already been discussed with the mods and Pine staff. A simple search box has been approved to be added, we're just waiting for the site admin to add it. Until then, the Tapatalk app works pretty well to browse the forums on mobile (better than the normal site.)
In regards to larger sized eMMC devices, Samsung makes a 256GB model;
https://www.samsung.com/semiconductor/estorage/emmc/
Note that it won't work as is. The Pinebook Pro uses a carrier board with tiny connector. Schematics & board layout are available on the Wiki.
On the subject why you might want to use a larger eMMC, is power. The existing 128GB model, SanDisk iNAND 7232, runs at 1.35 watts peak. And generally less than half for most things.
I'd be interested in a dual eMMC slot, PCIe card. It can be shorter than NVMe carrier boards, so properly designed, it would not interfer with the trackpad.
Arwen Evenstar
Princess of Rivendale
  Pinebook Pro Initial Impressions kunger 443 587,479 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,276 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 392 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 297 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 284 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 217 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 661 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 730 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,586 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,214 12-15-2023, 02:11 PM
