Can't boot android 9 on rock64. I tried sdtools and etcher methods. And tried different sd cards. How to solve this problem?
log from serial console
03-05-2020, 06:01 PM
(03-04-2020, 04:19 PM)maks2204 Wrote: Can't boot android 9 on rock64. I tried sdtools and etcher methods. And tried different sd cards. How to solve this problem? which build, please name or link.
03-05-2020, 07:58 PM
(03-05-2020, 06:01 PM)tllim Wrote:(03-04-2020, 04:19 PM)maks2204 Wrote: Can't boot android 9 on rock64. I tried sdtools and etcher methods. And tried different sd cards. How to solve this problem? I tried Android 9.0 Stock Rooted Image [microSD Boot] using ROCKChip SDDisk tools method [20190621] and Android 9.0 Stock Rooted Image [microSD Boot] using DD method [20190621].
I have tried to install Android without success with my sd tools, which work fine for Debian versions.
I tried Pine64 installer, which proposes only the installation on eMMC, it fails because "no more space on disk". It is noticeable that the eMMC sold by Pine64 are 31GB and not 32. It may be the reason but I am not sure. To be able to try the same installation (Android 9.0 Stock Rooted Image [microSD Boot] using DD method ) on a microSD card, I used again the Pine64 installer, and dropped the proper file directly into it, instead of using the menu. https://wiki.pine64.org/index.php/ROCK64...0190621.5D Installation was successful. But the process is suprising. Flashing until 84% is fast (less than 2 minutes). From 84% to 94% the process is slower (once again less than two minutes). From 94% to the end, will require an hour or more. Be patient, and even if nothing seems to move, it is still doing something. After installing the microSD card, I had to reboot several times, but the reason may be the Rock64 card which was defective, as I noticed later. Once installed on a good Rock64, Android worked fine.
Now that Android Stock 9 is installed, I must get access to the console.
How can I enable SSH ? I tried to install Termux, and not yet succeeded. In my google account, the new Android is visible, but when I try ton install an application, the list of devices shows only my Nexus 5.
09-09-2020, 08:44 AM
I found some cards are just REALLY slow, and the first boot can take quite a while.
Ive found so far if you get a spinning rainbow circle within 20 seconds thats the first good sign, and then if you dont get any display after a minute from that you didnt get a good flash. I have 2 indicators, first i s the spinning rainbow donyt thing then ill get either a pine logo or the android logo within a minute, i i dont see those 2 things i start over. Ive downloaded every android file on the wiki an dim trying everything before i decide what to stick with. |
broken android microsd images | jbach50 | 1 | 496 |
01-16-2021, 09:57 PM Last Post: jimsurvak |
Android on Rock64 SD Problem | ElBoluTony | 3 | 1,067 |
10-07-2020, 12:10 PM Last Post: ElBoluTony |
Error! Android Rockchip tools method | BowerR64 | 0 | 466 |
09-18-2020, 08:12 PM Last Post: BowerR64 |
Any older versions of Android for the Rock64? | BowerR64 | 2 | 991 |
09-18-2020, 07:58 PM Last Post: BowerR64 |
Boot Android from USB? | Max_H | 3 | 1,757 |
09-09-2020, 08:26 AM Last Post: BowerR64 |
Regular Android build for Rock64? | fender90 | 18 | 7,079 |
09-09-2020, 08:04 AM Last Post: BowerR64 |
Cannot flash android 9 rockchip tool | totalgaara | 2 | 1,369 |
09-09-2020, 07:05 AM Last Post: BowerR64 |
Utility to make Android SDCard image | jonsmirl | 2 | 1,452 |
09-09-2020, 06:59 AM Last Post: BowerR64 |
Android Images (ROCK64) | pineadmin | 72 | 70,406 |
09-02-2020, 09:52 PM Last Post: BowerR64 |
Ir codes for Android 9 | Redwid | 3 | 1,319 |
07-15-2020, 04:43 AM Last Post: Redwid |
