Battery life and ways to improve - request for official statement
Hello folks,
so far I didn't see any official statement why the battery life is so poor and whether there's anything to try/test to improve it. This should be the top priority imho! Observations:
- it's always top of the phone which gets hot (where the modem is located).
- touching the uncovered modem my guess would be between 55-65C all the time. This higher heat from the modem can be felt also on the screen side
- pmOS with plasma-mobile is way cooler based on my tests today than the Phosh image (tested today with latest images, no SIM)
- checking the CPU frequencies seems to be ok, however the lowest frequency seems to be high imho, is this due to hw limitations ? Trying to set the available frequencies to be lower didn't do the trick
  current CPU frequency is 648 MHz (asserted by call to hardware).
  cpufreq stats: 648 MHz:73.58%, 816 MHz:3.03%, 912 MHz:0.67%, 960 MHz:0.54%, 1.01 GHz:0.60%, 1.06 GHz:0.57%, 1.10 GHz:0.84%, 1.15 GHz:20.17%  (4271)
- is there any way to exactly track what is eating up the battery ?
- is the a known method to reduce power usage siginificantly ?
- is there any supported way to measure the temperature of various components in alpine linux ?
- why is the modem so hot even though I have no SIM inside the phone ?
Cheers!
  Battery issues user641 3 1,099 07-17-2023, 10:43 AM
Last Post: alaraajavamma
  Boots To Shell After Dead Battery (PMOS) britelite 0 667 02-17-2023, 02:41 PM
Last Post: britelite
  Pinephone 64 PostMarketOS edition Battery Issues, Not Hardware Issue X0X0X0X0X0 1 1,304 02-11-2023, 08:19 AM
Last Post: acid andy
  Pinephone 64 PostMarketOS edition Battery problem Alejandro.SU 9 8,334 12-22-2020, 04:33 PM
Last Post: Alejandro.SU
  unable to boot the phone with PM OS after battery has completely discharged nieral 1 2,943 08-24-2020, 06:34 AM
Last Post: PureTryOut
  Charging issues and battery life realrichardsharpe@gmail.com 6 6,746 03-11-2020, 09:03 AM
Last Post: MartijnBraam
