2020-02-20 Plasma Mobile image
#41
(03-02-2020, 05:53 AM)PureTryOut Wrote:
(03-01-2020, 05:38 PM)edge Wrote: The xsession error file contained only one line: "Error relocating /usr/bin/startplasma-wayland: _ZN22QDBusAbstractInterface6doCallEN5QDBus8CallModeERK7QStringPK8QVariantm: symbol not found".
Also, what is needed to be able to ssh to the device? The IP shows up when connected via USB, but a connection refused error message is the result of the ssh command.
I know you said you upgraded, but could you make absolutely sure? ;p That startup error just shouldn't happen with a fully upgraded system.
For ssh, are you sure you connect to the right IP? It works for everyone else.
Tried starting with the base image and upgrading again yesterday. Have the same error in .xsession-errors. There was a warning that tail was not able to find something, but the exit code of upgrade --available was apparently 0 as it proceeded to the chained reboot command. Huh
  Gnome mobile user641 1 478 01-06-2024, 11:06 AM
Last Post: Uturn
  NextCloud Gnome Mobile Uturn 4 1,014 12-03-2023, 07:54 AM
Last Post: Uturn
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 681 10-03-2023, 06:32 PM
Question Always Use Mobile Data DingDangDoong 4 1,739 04-20-2023, 06:18 AM
Last Post: DingDangDoong
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & No MMS X0X0X0X0X0 1 1,313 11-07-2022, 10:34 PM
Last Post: X0X0X0X0X0
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 1 1,088 11-06-2022, 06:41 PM
Last Post: Chief
  Disable mobile data auto-enable on boot 64_Tesseract 3 2,179 08-11-2022, 02:48 AM
Last Post: 64_Tesseract
  [PostmarketOS with Plasma Mobile] Angelfish adblock + wpa supplicant time out Egolep 0 1,963 03-23-2021, 10:25 AM
Last Post: Egolep
  Where is the original PM OS image for Pinephone? mw4jet 1 2,546 03-14-2021, 07:37 AM
Last Post: ludix
  PMOS test image: failed EG25 test broke modem fw MtnSk8 4 5,507 02-28-2021, 02:20 PM
Last Post: MtnSk8
