OMV Rock64
I have a 3.5 inch HDD connected to ROCK64 via a powered dock. What is the proper way of turning off OMV installation ? Everytime I start, I get some error message, volume was not unmounted properly, could be corrupt message. How do i fix this ?
(02-20-2020, 10:16 AM)Nerevarine Wrote: Hi,
It's the dock, use one of these instead.
https://www.ebay.com/itm/USB-3-0-to-2-5-...fa|iid%3A1
https://www.amazon.in/ORICO-USB3-0-Clone...R7NRRXSDKG
I use this, can you tell me what I need to look for, to get a new dock ?
So, I downloaded and flashed the lasted "stable" version of OMV.
I've logged in and created a new password as prompted.
I followed the instructions to update and upgrade.
However, I can't seem to connect to the OMV via HTTP. I am missing something I believe...Please help?
(02-20-2020, 11:33 AM)Nerevarine Wrote: https://www.amazon.in/ORICO-USB3-0-Clone...R7NRRXSDKG
You need to get a sata to usb adapter that has power, since you are using a 3.5 inch drive. Or just replace the 3.5 inch drive with a 2.5 inch drive and an unpowered sata to usb adapter.  The rock64 doesn't have enough power to spin up a 3.5 inch drive but one or sometimes 2 2.5 inch drives aren't a problem.  A regular dock may also work, I have a single drive dock and don't get that error, but I'm not using it on a regular basis.  The ebay link i sent you is all you need, the offline clone feature on the dock you have is more than likely what is causing your issue.  That dock is more than just a sata to usb adapter.
Actually I'm aware that you need an external powered dock. The one I linked is externally powered, supports UASP and doesn't have electric backflow..
Please tell me what I should be looking for when buying new dock as eBay.com doesn't deliver here in my country
(02-20-2020, 10:25 PM)Nerevarine Wrote: Actually I'm aware that you need an external powered dock. The one I linked is externally powered, supports UASP and doesn't have electric backflow..
You should be looking for a basic adapter that has it's own power supply.
https://www.amazon.com/Benfei-Adapter-Co...WNrPXRydWU=
Okay, I checked the error logs and it is mmcblk1 refers to the memory card, not the HDD.
Can anyone tell me if you guys faced the same issue with your memory card ?
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 152 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,365 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 337 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 615 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 610 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,389 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,583 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 592 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 651 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,420 12-07-2022, 08:22 PM
Last Post: luminosity7
