CrOS debugging request
The partition errors are red herrings, CrOS just uses an unusual partitioning scheme that some tools think is wrong. Plus if you dd the image onto a smaller disk, the backup GPT is in the wrong position, but it doesn't break anything.
What you probably need to look at are the UI/chrome logs under /var/log, if you've swapped in a mainline kernel you'll also need mesa compiled with panfrost support.
  CrOS boot from sd, now pinebook doesn't boot anymore qdoy55d9wkn8zw 7 10,937 06-22-2020, 06:23 AM
  Panfrost and CrOS tophneal 2 4,466 04-20-2020, 12:23 PM
