CrOS debugging request
Hi all
I have been working on a CrOS79 image with the mainline kernel. I have built an image, and it can be found here: https://drive.google.com/open?id=1-72xu8...s7ka5HoLd9
However, the image doesn't boot and does not give any output to the screen. Is there anyone out there with a debugging console cable that can help me out here? Smile I'm stumbling in the dark right now
Help appreciated!
Posted the link in the IRC, also: BUMP.
Edit: just in case, I've found and added a 3.3v UART cable to my Amazon cart, so if no one joins in, I'll try my hand at debugging the boot.
Had to wait a little bit to get a UART cable for myself, but it arrived, and I've got the output from trying to boot up this image:
DDR Version 1.20 20190314
In
channel 0
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x81
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
change freq to 800MHz 1,0
Channel 0: LPDDR4,800MHz
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x2020
ch 1 ddrconfig = 0x101, ddrsize = 0x2020
pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 250
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=119276MB
FwPartOffset=2000 , 100000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30528MB
FwPartOffset=2000 , 0
StorageInit ok = 245691
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT part:  0, name:            STATE, start:0x44e000, size:0x40006d
GPT part:  1, name:           KERN-A, start:0x5000, size:0x8000
GPT part:  2, name:           ROOT-A, start:0x4e000, size:0x400000
GPT part:  3, name:           KERN-B, start:0xd000, size:0x8000
GPT part:  4, name:           ROOT-B, start:0x4d000, size:0x1000
GPT part:  5, name:           KERN-C, start:0x4040, size:0x1
GPT part:  6, name:           ROOT-C, start:0x4041, size:0x1
GPT part:  7, name:              OEM, start:0x15000, size:0x8000
GPT part:  8, name:         reserved, start:0x4042, size:0x1
GPT part:  9, name:         reserved, start:0x4043, size:0x1
GPT part: 10, name:             RWFW, start:0x40, size:0x4000
GPT part: 11, name:       EFI-SYSTEM, start:0x3d000, size:0x10000
no find partition:uboot.
LoadTrust Addr:0x4000
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xe65c0
RunBL31 0x40000
NOTICE:  BL31: v1.3(release):57824cc
NOTICE:  BL31: Built : 10:59:12, Jan  6 2020
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    If lpddr4 need support multi frequency,
INFO:    please update loader!
INFO:    Current ctl index[0] freq=400MHz
INFO:    Current ctl index[1] freq=800MHz
INFO:    plat_rockchip_pmu_init(1190): pd status 3e
INFO:    BL31: Initializing runtime services
INFO:    BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-230-g6c76e8a9 #191 Mon Nov 18 07:00:24 UTC 2019 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.2
INF [0x0] TEE-CORE:init_teecore:83: teecore inits done
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
fdtdec_get_addr_size_fixed: reg: addr=ff770000, size=10000
fdtdec_get_addr_size_fixed: reg: addr=ff320000, size=1000
U-Boot 2017.09 (Feb 16 2020 - 17:42:34 +0100)
Model: Pine64 RK3399 Pinebook Pro
PreSerial: 2
DRAM:  3.8 GiB
Sysmem: init
Relocation Offset: f5be6000, fdt: f3dd1238
I2c0 speed: 400000Hz
PMIC:  RK808
vdd_center 900000 uV
vdd_log init 900000 uV
rk_board_init PWM2 pinctrl init fail!
rk_board_init: vcc3v0_sdio cannot set regulator value -38
                DCDC_REG1@     vdd_center:  750000uV <-> 1400000uV, set  900000uV, enabling | suspend     -61uV, disabled
                DCDC_REG4@        vcc_1v8: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling
                 LDO_REG1@     vcc1v8_dvp: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling
                 LDO_REG4@         vcc_sd: 3300000uV <-> 3300000uV, set 3300000uV, enabling | suspend 3300000uV, enabling
                 LDO_REG5@  vcca3v0_codec: 3000000uV <-> 3000000uV, set 3000000uV, enabling | suspend 3000000uV, enabling
                 LDO_REG7@  vcca1v8_codec: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling
                 LDO_REG8@        vcc_3v0: 3000000uV <-> 3000000uV, set 3000000uV, enabling | suspend 3000000uV, enabling
              SWITCH_REG2@      vcc3v3_s0:     -61uV <->     -61uV, set       0uV, enabling | suspend     -61uV, disabled
                   dc-12v@         dc_12v: 12000000uV <-> 12000000uV, set 12000000uV, enabling | suspend     -61uV, enabling (ret: -38)
                  vcc-sys@        vcc_sys: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend     -61uV, enabling (ret: -38)
               vcc3v3-sys@     vcc3v3_sys: 3300000uV <-> 3300000uV, set 3300000uV, enabling | suspend     -61uV, enabling (ret: -38)
        vcc-phy-regulator@        vcc_phy:     -61uV <->     -61uV, set     -61uV, enabling | suspend     -61uV, enabling
            led-regulator@  led_regulator:     -61uV <->     -61uV, set     -61uV, enabling | suspend     -61uV, enabling
           vcc5v0-host-en@    vcc5v0_host: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend     -61uV, enabling (ret: -38)
vcc5v0-usb3-host-regulator@vcc5v0_usb3_host:     -61uV <->     -61uV, set     -61uV, enabling | suspend     -61uV, enabling
         vcc5v0-typec0-en@  vcc5v0_typec0:     -61uV <->     -61uV, set     -61uV, enabling | suspend     -61uV, enabling
    vcc3v3-pcie-regulator@    vcc3v3_pcie: 3300000uV <-> 3300000uV, set 3300000uV, disabled | suspend     -61uV, enabling
              vcc1v8-sdio@    vcc1v8_sdio: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend     -61uV, enabling (ret: -38)
              vcc3v0-sdio@    vcc3v0_sdio: 3000000uV <-> 3000000uV, set 3000000uV, enabling | suspend     -61uV, enabling ; init 3000000uV (ret: -38)
                  vdd_log@        vdd_log:  800000uV <-> 1400000uV, set  900000uV, enabling | suspend     -61uV, enabling ; init  900000uV
MMC:   dwmmc@fe310000: 2, sdhci@fe330000: 0, dwmmc@fe320000: 1
Invalid bus 0 (err=-19)
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
In:    serial
Out:   serial
Err:   serial
switch to partitions #0, OK
mmc1 is current device
Found IDB in SDcard
Bootdev(atags): mmc 1
PartType: EFI
rockchip_get_boot_mode: Could not found misc partition
boot mode: None
init_resource_list: failed to get resource part, ret=-1
Can't find file:logo.bmp
failed to display uboot logo
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
  aplll 816000 KHz
  apllb 816000 KHz
  dpll 800000 KHz
  cpll 24000 KHz
  gpll 800000 KHz
  npll 600000 KHz
  vpll 24000 KHz
  aclk_perihp 133333 KHz
  hclk_perihp 66666 KHz
  pclk_perihp 33333 KHz
  aclk_perilp0 266666 KHz
  hclk_perilp0 88888 KHz
  pclk_perilp0 44444 KHz
  hclk_perilp1 100000 KHz
  pclk_perilp1 50000 KHz
Net:   No ethernet found.
Hit key to stop autoboot('CTRL+C'):  0
do_boot_rockchip: Could not find EFI-SYSTEM part
Checking for mmc dev 1...
Scanning mmc 1 for bootable partitions...
Scanning mmc 1:c for extlinux or boot scripts...
Found U-Boot script /boot.scr
reading /boot.scr
1117 bytes read in 2 ms (544.9 KiB/s)
## Executing script at 00500000
Setting bus to 4
I2c4 speed: 100000Hz
Valid chip addresses: 62
Detected i2c4@62 charger circuit.
It seems to be Pinebook Pro.
FDT: rockchip/rk3399-pinebook-pro.dtb
Bootdevice: mmcblk0
Retrieving file: /boot/extlinux/extlinux.conf
2087 bytes read in 22 ms (91.8 KiB/s)
Boot Menu
1:      dev-5.5.0-rockchip-dev
2:      rockchip-5.5.0-MANJARO-ARM+-debug
3:      rockchip-5.5.0-MANJARO-ARM+
Enter choice: 1:        dev-5.5.0-rockchip-dev
Retrieving file: /boot/vmlinuz-5.5.0-rockchip-dev
** File not found /boot/vmlinuz-5.5.0-rockchip-dev **
Skipping dev-5.5.0-rockchip-dev for failure retrieving kernel
Retrieving file: /boot/vmlinuz-5.5.0-MANJARO-ARM+
21699072 bytes read in 936 ms (22.1 MiB/s)
append: earlyprintk console=ttyS2,1500000n8 rw root=/dev/mmcblk0p3 rootfstype=ext4 init=/sbin/init rootwait cros_debug loglevel=7 dm_verity.error_behavior=3 dm_verity.max_bios=-1 dm_verity.dev_wait=0 dm="1 vroot none ro 1,0 2539520 verity payload=/dev/mmcblk0p3 hashtree=HASH_DEV hashstart=2539520 alg=sha1 root_hexdigest=a1910fbe4a24a30d19a49b85d2889776251e54e3 salt=c520b38f1057e5bef0aa64c00cd0d2e50662e22bf19771278921f90a35fd616d" vt.global_cursor_default=0 ethaddr=b6:02:ba:f2:9c:f8 serial=d25c0363e6a5f5f
Retrieving file: /boot/dtbs/5.5.0-MANJARO-ARM+/rockchip/rk3399-pinebook-pro.dtb
62426 bytes read in 66 ms (922.9 KiB/s)
## Flattened Device Tree blob at 08300000
   Booting using the fdt blob at 0x8300000
fdtdec_get_addr_size_fixed: reg: addr=00000000, size=0
   Loading Device Tree to 00000000f3dbb000, end 00000000f3dcd3d9 ... OK
Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000)
Adding bank: 0x0a200000 - 0xf8000000 (size: 0xede00000)
Total: 4208.872 ms
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.5.0-MANJARO-ARM+ (brent@brent-pc) (gcc version 4.9.x 20150123 (prerelease) (4.9.2_cos_gg_4.9.2-r223-ac6128e0a17a52f011797f33ac3e7d6273a9368d_4.9.2-r223)) #3 SMP Mon Feb 17 00:45:01 CET 2020
[    0.000000] Machine model: Pine64 Pinebook Pro
[    0.000000] earlycon: uart8250 at MMIO32 0x00000000ff1a0000 (options '')
[    0.000000] printk: bootconsole [uart8250] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB
[    0.000000] cma: Reserved 64 MiB at 0x00000000f4000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 34 pages/cpu s101400 r8192 d29672 u139264
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 991752
[    0.000000] Kernel command line: earlyprintk console=ttyS2,1500000n8 rw root=/dev/mmcblk0p3 rootfstype=ext4 init=/sbin/init rootwait cros_debug loglevel=7 dm_verity.error_behavior=3 dm_verity.max_bios=-1 dm_verity.dev_wait=0 dm="1 vroot none ro 1,0 2539520 verity payload=/dev/mmcblk0p3 hashtree=HASH_DEV hashstart=2539520 alg=sha1 root_hexdigest=a1910fbe4a24a30d19a49b85d2889776251e54e3 salt=c520b38f1057e5bef0aa64c00cd0d2e50662e22bf19771278921f90a35fd616d" vt.global_cursor_default=0 ethaddr=b6:02:ba:f2:9c:f8 serial=d25c0363e6a5f5f earlycon=uart8250,mmio32,0xff1a0000 mem_sleep_default=s2idle
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
[    0.000000] Memory: 3788516K/4030464K available (13628K kernel code, 838K rwdata, 5448K rodata, 1216K init, 8475K bss, 176412K reserved, 65536K cma-reserved)
[    0.000000] random: get_random_u64 called from cache_random_seq_create+0x78/0x130 with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: no VLPI support, no direct LPI support, no RVPEID support
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] ITS [mem 0xfee20000-0xfee3ffff]
[    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @eec80000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000000eec40000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000eec50000
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001984] Console: colour dummy device 80x25
[    0.002429] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.003373] pid_max: default: 32768 minimum: 301
[    0.003948] LSM: Security Framework initializing
[    0.004383] Yama: becoming mindful.
[    0.004779] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.005471] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.006236] *** VALIDATE tmpfs ***
[    0.007037] *** VALIDATE proc ***
[    0.007587] *** VALIDATE cgroup1 ***
[    0.007919] *** VALIDATE cgroup2 ***
[    0.009197] ASID allocator initialised with 65536 entries
[    0.009770] rcu: Hierarchical SRCU implementation.
[    0.010455] Platform MSI: interrupt-controller@fee20000 domain created
[    0.011442] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.012885] EFI services will not be available.
[    0.013716] smp: Bringing up secondary CPUs ...
[    0.014607] Detected VIPT I-cache on CPU1
[    0.014641] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.014654] GICv3: CPU1: using allocated LPI pending table @0x00000000eec60000
[    0.014698] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.015259] Detected VIPT I-cache on CPU2
[    0.015283] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.015293] GICv3: CPU2: using allocated LPI pending table @0x00000000eec70000
[    0.015318] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.015815] Detected VIPT I-cache on CPU3
[    0.015836] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.015847] GICv3: CPU3: using allocated LPI pending table @0x00000000eed00000
[    0.015869] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.016366] CPU features: detected: EL2 vector hardening
[    0.016374] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
[    0.016378] CPU features: detected: ARM erratum 1319367
[    0.016382] Detected PIPT I-cache on CPU4
[    0.016407] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.016418] GICv3: CPU4: using allocated LPI pending table @0x00000000eed10000
[    0.016445] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[    0.016973] Detected PIPT I-cache on CPU5
[    0.016993] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.017003] GICv3: CPU5: using allocated LPI pending table @0x00000000eed20000
[    0.017024] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[    0.017108] smp: Brought up 1 node, 6 CPUs
[    0.030197] SMP: Total of 6 processors activated.
[    0.030629] CPU features: detected: 32-bit EL0 Support
[    0.031100] CPU features: detected: CRC32 instructions
[    0.058685] CPU: All CPU(s) started at EL2
[    0.059140] alternatives: patching kernel code
[    0.061991] devtmpfs: initialized
[    0.071051] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.071958] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.075197] pinctrl core: initialized pinctrl subsystem
[    0.076604] thermal_sys: Registered thermal governor 'fair_share'
[    0.076607] thermal_sys: Registered thermal governor 'bang_bang'
[    0.077196] thermal_sys: Registered thermal governor 'step_wise'
[    0.077773] thermal_sys: Registered thermal governor 'user_space'
[    0.078753] DMI not present or invalid.
[    0.080063] NET: Registered protocol family 16
[    0.082200] DMA: preallocated 256 KiB pool for atomic allocations
[    0.083744] cpuidle: using governor ladder
[    0.084162] cpuidle: using governor menu
[    0.084949] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.085817] Serial: AMBA PL011 UART driver
[    0.112460] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.113109] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.113753] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.114397] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.126360] cryptd: max_cpu_qlen set to 1000
[    0.152926] ACPI: Interpreter disabled.
[    0.153708] vcc_12v: supplied by vcc_sysin
[    0.154292] vcc3v3_sys: supplied by vcc_sysin
[    0.155012] vcc5v0_usb: supplied by vcc_sysin
[    0.155631] vcc_0v9: supplied by vcc3v3_sys
[    0.156211] vcca1v8_s3: supplied by vcc3v3_sys
[    0.156873] vcc3v0_sd: supplied by vcc3v3_sys
[    0.157584] vcc3v3_panel: supplied by vcc3v3_sys
[    0.277516] vcc3v3_ssd: supplied by vcc3v3_sys
[    0.278202] vcc5v0_otg: supplied by vcc5v0_usb
[    0.278891] vbus_5vout: supplied by vcc5v0_usb
[    0.279820] iommu: Default domain type: Translated
[    0.282311] vgaarb: loaded
[    0.283147] SCSI subsystem initialized
[    0.283790] usbcore: registered new interface driver usbfs
[    0.284340] usbcore: registered new interface driver hub
[    0.284908] usbcore: registered new device driver usb
[    0.285762] mc: Linux media interface: v0.10
[    0.286188] videodev: Linux video capture interface: v2.00
[    0.286735] pps_core: LinuxPPS API ver. 1 registered
[    0.287211] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.288107] PTP clock support registered
[    0.288652] EDAC MC: Ver: 3.0.0
[    0.289469] Advanced Linux Sound Architecture Driver Initialized.
[    0.290391] NetLabel: Initializing
[    0.290719] NetLabel:  domain hash size = 128
[    0.291137] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.291714] NetLabel:  unlabeled traffic allowed by default
[    0.292709] clocksource: Switched to clocksource arch_sys_counter
[    0.293299] *** VALIDATE bpf ***
[    0.293760] VFS: Disk quotas dquot_6.6.0
[    0.294182] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.294891] *** VALIDATE ramfs ***
[    0.295229] *** VALIDATE hugetlbfs ***
[    0.295858] pnp: PnP ACPI: disabled
[    0.300942] NET: Registered protocol family 2
[    0.301824] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.302697] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.303736] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    0.304921] TCP: Hash tables configured (established 32768 bind 32768)
[    0.305649] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.306387] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.307297] NET: Registered protocol family 1
[    0.308240] RPC: Registered named UNIX socket transport module.
[    0.308786] RPC: Registered udp transport module.
[    0.309214] RPC: Registered tcp transport module.
[    0.309644] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.310236] PCI: CLS 0 bytes, default 64
[    0.311986] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.313074] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.314246] kvm [1]: IPA Size Limit: 40bits
[    0.315967] kvm [1]: vgic-v2@fff20000
[    0.316338] kvm [1]: GIC system register CPU interface enabled
[    0.317045] kvm [1]: vgic interrupt IRQ10
[    0.317603] kvm [1]: Hyp mode initialized successfully
[    0.367298] Initialise system trusted keyrings
[    0.367848] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.371457] zbud: loaded
[    0.373043] NFS: Registering the id_resolver key type
[    0.373541] Key type id_resolver registered
[    0.373944] Key type id_legacy registered
[    0.374336] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.375000] ntfs: driver 2.1.32 [Flags: R/W].
[    0.375633] fuse: init (API version 7.31)
[    0.376064] *** VALIDATE fuse ***
[    0.376387] *** VALIDATE fuse ***
[    0.376899] SGI XFS with ACLs, security attributes, quota, no debug enabled
[    0.378506] *** VALIDATE xfs ***
[    0.396297] NET: Registered protocol family 38
[    0.396731] Key type asymmetric registered
[    0.397127] Asymmetric key parser 'x509' registered
[    0.397619] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    0.398445] io scheduler mq-deadline registered
[    0.398882] io scheduler kyber registered
[    0.399343] io scheduler bfq registered
[    0.406662] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[    0.407336] rockchip-pcie f8000000.pcie: f8000000.pcie supply vpcie1v8 not found, using dummy regulator
[    0.408279] rockchip-pcie f8000000.pcie: f8000000.pcie supply vpcie0v9 not found, using dummy regulator
[    0.982759] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    0.983681] rockchip-pcie: probe of f8000000.pcie failed with error -110
[    0.985190] IPMI message handler: version 39.2
[    0.987106] dma-pl330 ff6d0000.dma-controller: WARN: Device release is not defined so it is not safe to unbind this driver while in use
[    0.988872] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.989567] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    0.990621] dma-pl330 ff6e0000.dma-controller: WARN: Device release is not defined so it is not safe to unbind this driver while in use
[    0.992833] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.993527] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    0.996046] pwm-regulator: supplied by regulator-dummy
[    0.997367] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.999705] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
[    1.000654] serial serial0: tty port ttyS0 registered
[    1.001576] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 39, base_baud = 1500000) is a 16550A
[    1.002580] printk: console [ttyS2] enabled
[    1.003360] printk: bootconsole [uart8250] disabled
[    1.006249] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    1.010285] spi-nor spi0.0: gd25q128 (16384 Kbytes)
[    1.012524] libphy: Fixed MDIO Bus: probed
[    1.013015] usbcore: registered new interface driver asix
[    1.021919] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.022501] ehci-pci: EHCI PCI platform driver
[    1.022959] ehci-platform: EHCI generic platform driver
[    1.025641] ehci-platform fe380000.usb: EHCI Host Controller
[    1.026313] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[    1.027103] ehci-platform fe380000.usb: irq 30, io mem 0xfe380000
[    1.052735] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    1.053434] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
[    1.054161] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.054795] usb usb1: Product: EHCI Host Controller
[    1.055226] usb usb1: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ehci_hcd
[    1.055792] usb usb1: SerialNumber: fe380000.usb
[    1.056658] hub 1-0:1.0: USB hub found
[    1.057017] hub 1-0:1.0: 1 port detected
[    1.059854] ehci-platform fe3c0000.usb: EHCI Host Controller
[    1.060484] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[    1.061266] ehci-platform fe3c0000.usb: irq 32, io mem 0xfe3c0000
[    1.082736] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    1.083415] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
[    1.084141] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.084774] usb usb2: Product: EHCI Host Controller
[    1.085205] usb usb2: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ehci_hcd
[    1.085770] usb usb2: SerialNumber: fe3c0000.usb
[    1.086558] hub 2-0:1.0: USB hub found
[    1.086917] hub 2-0:1.0: 1 port detected
[    1.087870] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.088428] ohci-pci: OHCI PCI platform driver
[    1.088889] ohci-platform: OHCI generic platform driver
[    1.089545] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    1.090266] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[    1.091045] ohci-platform fe3a0000.usb: irq 31, io mem 0xfe3a0000
[    1.156930] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.05
[    1.157657] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.158290] usb usb3: Product: Generic Platform OHCI controller
[    1.158811] usb usb3: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ohci_hcd
[    1.159376] usb usb3: SerialNumber: fe3a0000.usb
[    1.160186] hub 3-0:1.0: USB hub found
[    1.160543] hub 3-0:1.0: 1 port detected
[    1.161327] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    1.162044] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[    1.162921] ohci-platform fe3e0000.usb: irq 33, io mem 0xfe3e0000
[    1.236958] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.05
[    1.237685] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.238319] usb usb4: Product: Generic Platform OHCI controller
[    1.238840] usb usb4: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ohci_hcd
[    1.239405] usb usb4: SerialNumber: fe3e0000.usb
[    1.240203] hub 4-0:1.0: USB hub found
[    1.240560] hub 4-0:1.0: 1 port detected
[    1.241486] uhci_hcd: USB Universal Host Controller Interface driver
[    1.242928] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.243564] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
[    1.244366] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    1.245230] xhci-hcd xhci-hcd.0.auto: irq 226, io mem 0xfe900000
[    1.246050] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
[    1.246776] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.247410] usb usb5: Product: xHCI Host Controller
[    1.247840] usb usb5: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd
[    1.248405] usb usb5: SerialNumber: xhci-hcd.0.auto
[    1.249239] hub 5-0:1.0: USB hub found
[    1.249598] hub 5-0:1.0: 1 port detected
[    1.250258] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.250861] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6
[    1.251543] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    1.252169] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.252991] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
[    1.253718] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.254351] usb usb6: Product: xHCI Host Controller
[    1.254782] usb usb6: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd
[    1.255347] usb usb6: SerialNumber: xhci-hcd.0.auto
[    1.256159] hub 6-0:1.0: USB hub found
[    1.256515] hub 6-0:1.0: 1 port detected
[    1.257276] usbcore: registered new interface driver uas
[    1.257856] usbcore: registered new interface driver usb-storage
[    1.258413] usbcore: registered new interface driver ums-alauda
[    1.258964] usbcore: registered new interface driver ums-cypress
[    1.259521] usbcore: registered new interface driver ums-datafab
[    1.260075] usbcore: registered new interface driver ums_eneub6250
[    1.260646] usbcore: registered new interface driver ums-freecom
[    1.261201] usbcore: registered new interface driver ums-isd200
[    1.261748] usbcore: registered new interface driver ums-jumpshot
[    1.262313] usbcore: registered new interface driver ums-karma
[    1.262986] usbcore: registered new interface driver ums-onetouch
[    1.263563] usbcore: registered new interface driver ums-realtek
[    1.264120] usbcore: registered new interface driver ums-sddr09
[    1.264668] usbcore: registered new interface driver ums-sddr55
[    1.265217] usbcore: registered new interface driver ums-usbat
[    1.265814] usbcore: registered new interface driver usbserial_generic
[    1.266404] usbserial: USB Serial support registered for generic
[    1.269245] mousedev: PS/2 mouse device common for all mice
[    1.272609] rk808 0-001b: chip id: 0x0
[    1.276970] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    1.277538] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    1.278143] DCDC_REG1: supplied by vcc_sysin
[    1.279384] DCDC_REG2: supplied by vcc_sysin
[    1.280305] DCDC_REG3: supplied by vcc_sysin
[    1.280867] DCDC_REG4: supplied by vcc_sysin
[    1.281697] LDO_REG1: supplied by vcc_sysin
[    1.283287] LDO_REG2: supplied by vcc_sysin
[    1.283824] vcc3v0_touch: Bringing 1800000uV into 3000000-3000000uV
[    1.285372] LDO_REG3: supplied by vcc_sysin
[    1.286826] LDO_REG4: supplied by vcc_sysin
[    1.287377] vcc_sdio: Bringing 3300000uV into 3000000-3000000uV
[    1.288935] LDO_REG5: supplied by vcc_sysin
[    1.290260] LDO_REG6: supplied by vcc_sysin
[    1.291711] LDO_REG7: supplied by vcc_sysin
[    1.293084] LDO_REG8: supplied by vcc_sysin
[    1.294534] SWITCH_REG1: supplied by vcc3v3_sys
[    1.295230] SWITCH_REG2: supplied by vcc3v3_sys
[    1.298950] rk808-rtc rk808-rtc: registered as rtc0
[    1.300025] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    1.300651] fan53555-reg: supplied by vcc_1v8
[    1.301428] random: fast init done
[    1.303177] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    1.303802] fan53555-reg: supplied by vcc_1v8
[    1.306530] OF: graph: no port node found in /i2c@ff3d0000/fusb30x@22
[    1.321382] device-mapper: uevent: version 1.0.3
[    1.322091] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com
[    1.326884] sdhci: Secure Digital Host Controller Interface driver
[    1.327432] sdhci: Copyright(c) Pierre Ossman
[    1.328323] Synopsys Designware Multimedia Card Interface Driver
[    1.329663] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    1.330309] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    1.330907] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    1.331444] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 27,32 bit host data width,256 deep fifo
[    1.332385] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[    1.332933] mmc_host mmc0: card is non-removable.
[    1.463051] usb 2-1: new high-speed USB device number 2 using ehci-platform
[    1.463528] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    1.477984] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[    1.478646] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[    1.479245] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[    1.479792] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 28,32 bit host data width,256 deep fifo
[    1.480808] dwmmc_rockchip fe320000.dwmmc: Got CD GPIO
[    1.481401] vcc_sdio: unsupportable voltage range: 3300000-3000000uV
[    1.494920] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    1.509942] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.512474] mmc2: CQHCI version 5.10
[    1.512793] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.515182] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.515806] usb 2-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
[    1.516526] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.517151] usb 2-1: Product: USB2.0 Hub
[    1.517317] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.518351] hub 2-1:1.0: USB hub found
[    1.519123] hub 2-1:1.0: 4 ports detected
[    1.520855] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.524853] mmc0: queuing unknown CIS tuple 0x81 (9 bytes)
[    1.538954] mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    1.542908] ledtrig-cpu: registered to indicate activity on CPUs
[    1.544099] hid: raw HID events driver (C) Jiri Kosina
[    1.544776] usbcore: registered new interface driver usbhid
[    1.545266] usbhid: USB HID core driver
[    1.548623] Initializing XFRM netlink socket
[    1.549347] NET: Registered protocol family 10
[    1.553688] Segment Routing with IPv6
[    1.554100] mip6: Mobile IPv6
[    1.554368] NET: Registered protocol family 17
[    1.555105] Key type dns_resolver registered
[    1.556143] registered taskstats version 1
[    1.556508] Loading compiled-in X.509 certificates
[    1.557036] zswap: loaded using pool lzo/zbud
[    1.557532] Key type ._fscrypt registered
[    1.557884] Key type .fscrypt registered
[    1.558239] Key type fscrypt-provisioning registered
[    1.558755] Key type big_key registered
[    1.560478] Key type encrypted registered
[    1.563470] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[    1.580189] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[    1.582598] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    1.583278] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 7
[    1.584044] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    1.584900] xhci-hcd xhci-hcd.2.auto: irq 225, io mem 0xfe800000
[    1.585588] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
[    1.586309] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.586939] usb usb7: Product: xHCI Host Controller
[    1.587365] usb usb7: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd
[    1.587925] usb usb7: SerialNumber: xhci-hcd.2.auto
[    1.588679] hub 7-0:1.0: USB hub found
[    1.589017] hub 7-0:1.0: 1 port detected
[    1.589473] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    1.590008] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 8
[    1.590677] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[    1.591263] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.591998] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
[    1.592725] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.593353] usb usb8: Product: xHCI Host Controller
[    1.593778] usb usb8: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd
[    1.594339] usb usb8: SerialNumber: xhci-hcd.2.auto
[    1.594916] hub 8-0:1.0: USB hub found
[    1.595252] hub 8-0:1.0: 1 port detected
[    1.597638] rk808-rtc rk808-rtc: setting system clock to 2020-03-09T13:16:06 UTC (1583759766)
[    1.599127] ALSA device list:
[    1.599395]   No soundcards found.
[    1.599905] ttyS2 - failed to request DMA
[    1.600344] md: Waiting for all devices to be available before autodetect
[    1.600937] md: If you don't use raid, use raid=noautodetect
[    1.602105] md: Autodetecting RAID arrays.
[    1.602471] md: autorun ...
[    1.602738] md: ... autorun DONE.
[    1.603080] Waiting for root device /dev/mmcblk0p3...
[    1.623917] mmc2: Command Queue Engine enabled
[    1.624330] mmc2: new HS200 MMC card at address 0001
[    1.625609] mmcblk2: mmc2:0001 DA4128 116 GiB
[    1.626146] mmcblk2boot0: mmc2:0001 DA4128 partition 1 4.00 MiB
[    1.626797] mmcblk2boot1: mmc2:0001 DA4128 partition 2 4.00 MiB
[    1.627495] mmcblk2rpmb: mmc2:0001 DA4128 partition 3 16.0 MiB, chardev (238:0)
[    1.630901]  mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[    1.793159] usb 3-1: new low-speed USB device number 2 using ohci-platform
[    1.843034] usb 2-1.2: new high-speed USB device number 3 using ehci-platform
[    1.954454] usb 2-1.2: New USB device found, idVendor=0c45, idProduct=6321, bcdDevice= 0.00
[    1.955212] usb 2-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[    1.955861] usb 2-1.2: Product: USB Camera
[    1.956233] usb 2-1.2: Manufacturer: Sonix Technology Co., Ltd.
[    2.069098] usb 3-1: New USB device found, idVendor=258a, idProduct=001e, bcdDevice= 1.00
[    2.069854] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.070490] usb 3-1: Product: USB KEYBOARD
[    2.070862] usb 3-1: Manufacturer: HAILUCK CO.,LTD
[    2.080761] input: HAILUCK CO.,LTD USB KEYBOARD as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.0/0003:258A:001E.0001/input/input0
[    2.127716] dwmmc_rockchip fe320000.dwmmc: Successfully tuned phase to 73
[    2.128367] mmc1: new ultra high speed SDR104 SDHC card at address 0001
[    2.130295] mmcblk1: mmc1:0001 GB1QT 29.8 GiB
[    2.136782] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    2.137443] GPT:8708252 != 62521343
[    2.137752] GPT:Alternate GPT header not at the end of the disk.
[    2.138279] GPT:8708252 != 62521343
[    2.138587] GPT: Use GNU Parted to correct GPT errors.
[    2.139114]  mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[    2.143323] hid-generic 0003:258A:001E.0001: input,hidraw0: USB HID v1.10 Keyboard [HAILUCK CO.,LTD USB KEYBOARD] on usb-fe3a0000.usb-1/input0
[    2.168800] input: HAILUCK CO.,LTD USB KEYBOARD Mouse as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input1
[    2.170662] input: HAILUCK CO.,LTD USB KEYBOARD Touchpad as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input2
[    2.172317] input: HAILUCK CO.,LTD USB KEYBOARD System Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input3
[    2.243814] input: HAILUCK CO.,LTD USB KEYBOARD Consumer Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input4
[    2.245586] input: HAILUCK CO.,LTD USB KEYBOARD Wireless Radio Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input5
[    2.247954] hid-generic 0003:258A:001E.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse [HAILUCK CO.,LTD USB KEYBOARD] on usb-fe3a0000.usb-1/input1
[    2.433910] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 47
[    2.437087] mmc0: new ultra high speed SDR104 SDIO card at address 0001
[   31.833067] vcc3v3_ssd: disabling
[   31.833389] vbus_5vout: disabling
[   99.573796] random: crng init done
EDIT: in case anyone's looking for their own UART cable, this. is the one I used: https://www.amazon.com/dp/B00XSPECIA?ref...b_ap_share
So this seems to be a partitioning error?
I'll see if I have the time to look into this.
Hi Brent,
I would be happy to debug your image on a Rock Pi 4! (RK3399 like the Pinebook Pro)
Could you please compress the image (tar.xz or 7z) and upload? Where I live there is 1.5 Gb data cap per day.
Thanks.
(03-11-2020, 01:25 AM)aaditya Wrote: Hi Brent,
Thanks.
I know Brent's pretty busy lately, so I'm tarring my local copy of the .bin right now, and will update the post with a download link as soon as its uploaded.
Link: https://mega.nz/#!eg80CQKC!lkFKcymh92BaZ...98aE02Ml5Q
(03-11-2020, 07:18 AM)tophneal Wrote: I know Brent's pretty busy lately, so I'm tarring my local copy of the .bin right now, and will update the post with a download link as soon as its uploaded.
Thanks @tophneal!
Here is the output from serial console running off a Rock Pi 4:
In
channel 0
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
OUT
CPUId = 0x0
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=29600MB
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 68548
SecureMode = 0
No find bl30.bin
RunBL31 0x40000
INFO:    SPSR = 0x3c9
PreSerial: 2
DRAM:  3.8 GiB
Sysmem: init
PMIC:  RK808
In:    serial
Out:   serial
Err:   serial
Bootdev(atags): mmc 0
PartType: EFI
boot mode: None
 aplll 816000 KHz
 apllb 816000 KHz
 dpll 800000 KHz
 cpll 24000 KHz
 gpll 800000 KHz
 npll 600000 KHz
 vpll 24000 KHz
Card did not respond to voltage select!
mmc_init: -95, time 9
Checking for nvme dev 0...
Device 0: unknown device
starting USB...
Bus usb@fe380000: USB EHCI 1.00
Bus usb@fe3a0000: USB OHCI 1.0
Bus usb@fe3c0000: USB EHCI 1.00
Bus usb@fe3e0000: USB OHCI 1.0
Bus usb@fe800000: device name usb@fe800000
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus usb@fe900000: device name usb@fe900000
USB XHCI 1.10
scanning bus usb@fe380000 for devices... ERROR: Invalid USB EP length (9)
4 USB Device(s) found
scanning bus usb@fe3a0000 for devices... 1 USB Device(s) found
scanning bus usb@fe3c0000 for devices... 1 USB Device(s) found
scanning bus usb@fe3e0000 for devices... ERROR:  USB-error: DEVICENOTRESPONDING: Device did not respond to token (IN) or did
not provide a handshake (OUT) (5)
unable to get device descriptor (error=-1)
scanning bus usb@fe800000 for devices... 1 USB Device(s) found
scanning bus usb@fe900000 for devices... 4 USB Device(s) found
      scanning usb for storage devices... 0 Storage Device(s) found
Checking for usb dev 0...
Checking for mmc dev 0...
mmc0(part 0) is current device
Scanning mmc 0 for bootable partitions...
Scanning mmc 0:c for extlinux or boot scripts...
reading /boot.scr
1117 bytes read in 11 ms (98.6 KiB/s)
Setting bus to 4
Did not detect i2c4@62 charger circuit.
It seems to be RockPro64.
FDT: rockchip/rk3399-rockpro64.dtb
Bootdevice: mmcblk1
2087 bytes read in 106 ms (18.6 KiB/s)
Boot Menu
21699072 bytes read in 1061 ms (19.5 MiB/s)
append: earlyprintk console=ttyS2,1500000n8 rw root=/dev/mmcblk1p3 rootfstype=ext4 init=/sbin/init rootwait cros_debug loglevel=7 dm_verity.error_behavior=3 dm_verd
Retrieving file: /boot/dtbs/5.5.0-MANJARO-ARM+/rockchip/rk3399-rockpro64.dtb
55062 bytes read in 156 ms (343.8 KiB/s)
  Loading Device Tree to 00000000f3dbc000, end 00000000f3dcc715 ... OK
Total: 13589.367 ms
Starting kernel ...
[    0.000000] Linux version 5.5.0-MANJARO-ARM+ (brent@brent-pc) (gcc version 4.9.x 20150123 (prerelease) (4.9.2_cos_gg_4.9.2-r223-ac6128e0a17a52f011797f33ac3e7d620
[    0.000000] Machine model: Pine64 RockPro64
[    0.000000] Kernel command line: earlyprintk console=ttyS2,1500000n8 rw root=/dev/mmcblk1p3 rootfstype=ext4 init=/sbin/init rootwait cros_debug loglevel=7 dm_ved
[    0.000000] Memory: 3788560K/4030464K available (13628K kernel code, 838K rwdata, 5448K rodata, 1216K init, 8475K bss, 176368K reserved, 65536K cma-reserved)
[    0.001134] Console: colour dummy device 80x25
[    0.001178] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.001190] pid_max: default: 32768 minimum: 301
[    0.001354] LSM: Security Framework initializing
[    0.001373] Yama: becoming mindful.
[    0.001453] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.001477] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.001535] *** VALIDATE tmpfs ***
[    0.002034] *** VALIDATE proc ***
[    0.002279] *** VALIDATE cgroup1 ***
[    0.002288] *** VALIDATE cgroup2 ***
[    0.003193] ASID allocator initialised with 65536 entries
[    0.003280] rcu: Hierarchical SRCU implementation.
[    0.003521] Platform MSI: interrupt-controller@fee20000 domain created
[    0.003878] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.004448] EFI services will not be available.
[    0.004855] smp: Bringing up secondary CPUs ...
[    0.005339] Detected VIPT I-cache on CPU1
[    0.005372] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.005386] GICv3: CPU1: using allocated LPI pending table @0x00000000eec60000
[    0.005429] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.005981] Detected VIPT I-cache on CPU2
[    0.006006] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.006017] GICv3: CPU2: using allocated LPI pending table @0x00000000eec70000
[    0.006042] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.006539] Detected VIPT I-cache on CPU3
[    0.006560] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.006571] GICv3: CPU3: using allocated LPI pending table @0x00000000eed00000
[    0.006593] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.007090] CPU features: detected: EL2 vector hardening
[    0.007097] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
[    0.007102] CPU features: detected: ARM erratum 1319367
[    0.007106] Detected PIPT I-cache on CPU4
[    0.007130] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.007141] GICv3: CPU4: using allocated LPI pending table @0x00000000eed10000
[    0.007169] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[    0.007695] Detected PIPT I-cache on CPU5
[    0.007715] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.007725] GICv3: CPU5: using allocated LPI pending table @0x00000000eed20000
[    0.007746] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[    0.007829] smp: Brought up 1 node, 6 CPUs
[    0.007881] SMP: Total of 6 processors activated.
[    0.007888] CPU features: detected: 32-bit EL0 Support
[    0.007895] CPU features: detected: CRC32 instructions
[    0.035030] CPU: All CPU(s) started at EL2
[    0.035113] alternatives: patching kernel code
[    0.037559] devtmpfs: initialized
[    0.045502] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.045522] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.048078] pinctrl core: initialized pinctrl subsystem
[    0.048920] thermal_sys: Registered thermal governor 'fair_share'
[    0.048923] thermal_sys: Registered thermal governor 'bang_bang'
[    0.048932] thermal_sys: Registered thermal governor 'step_wise'
[    0.048937] thermal_sys: Registered thermal governor 'user_space'
[    0.049396] DMI not present or invalid.
[    0.049879] NET: Registered protocol family 16
[    0.051835] DMA: preallocated 256 KiB pool for atomic allocations
[    0.052786] cpuidle: using governor ladder
[    0.052803] cpuidle: using governor menu
[    0.053176] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.053407] Serial: AMBA PL011 UART driver
[    0.079067] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.079077] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.079083] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.079090] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.090133] cryptd: max_cpu_qlen set to 1000
[    0.115489] ACPI: Interpreter disabled.
[    0.116150] vcc3v3_pcie: supplied by vcc12v_dcin
[    0.116996] vcc5v0_sys: supplied by vcc12v_dcin
[    0.117205] vcc5v0_usb: supplied by vcc12v_dcin
[    0.117321] vcc3v3_sys: supplied by vcc5v0_sys
[    0.117707] iommu: Default domain type: Translated
[    0.119181] vgaarb: loaded
[    0.119826] SCSI subsystem initialized
[    0.120123] usbcore: registered new interface driver usbfs
[    0.120152] usbcore: registered new interface driver hub
[    0.120213] usbcore: registered new device driver usb
[    0.120610] mc: Linux media interface: v0.10
[    0.120630] videodev: Linux video capture interface: v2.00
[    0.120656] pps_core: LinuxPPS API ver. 1 registered
[    0.120661] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.120671] PTP clock support registered
[    0.120834] EDAC MC: Ver: 3.0.0
[    0.121411] Advanced Linux Sound Architecture Driver Initialized.
[    0.121753] NetLabel: Initializing
[    0.121759] NetLabel:  domain hash size = 128
[    0.121764] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.121809] NetLabel:  unlabeled traffic allowed by default
[    0.122251] clocksource: Switched to clocksource arch_sys_counter
[    0.122262] *** VALIDATE bpf ***
[    0.122418] VFS: Disk quotas dquot_6.6.0
[    0.122467] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.122522] *** VALIDATE ramfs ***
[    0.122536] *** VALIDATE hugetlbfs ***
[    0.122826] pnp: PnP ACPI: disabled
[    0.127399] NET: Registered protocol family 2
[    0.127895] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.127956] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.128215] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    0.128705] TCP: Hash tables configured (established 32768 bind 32768)
[    0.128811] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.128910] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.129133] NET: Registered protocol family 1
[    0.129578] RPC: Registered named UNIX socket transport module.
[    0.129585] RPC: Registered udp transport module.
[    0.129590] RPC: Registered tcp transport module.
[    0.129595] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.129605] PCI: CLS 0 bytes, default 64
[    0.130535] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.130768] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.131119] kvm [1]: IPA Size Limit: 40bits
[    0.132480] kvm [1]: vgic-v2@fff20000
[    0.132502] kvm [1]: GIC system register CPU interface enabled
[    0.132645] kvm [1]: vgic interrupt IRQ10
[    0.132804] kvm [1]: Hyp mode initialized successfully
[    0.180728] Initialise system trusted keyrings
[    0.180895] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.185636] zbud: loaded
[    0.187497] NFS: Registering the id_resolver key type
[    0.187521] Key type id_resolver registered
[    0.187527] Key type id_legacy registered
[    0.187540] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.187570] ntfs: driver 2.1.32 [Flags: R/W].
[    0.187875] fuse: init (API version 7.31)
[    0.187945] *** VALIDATE fuse ***
[    0.187956] *** VALIDATE fuse ***
[    0.188215] SGI XFS with ACLs, security attributes, quota, no debug enabled
[    0.189501] *** VALIDATE xfs ***
[    0.209703] NET: Registered protocol family 38
[    0.209716] Key type asymmetric registered
[    0.209721] Asymmetric key parser 'x509' registered
[    0.209757] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    0.209877] io scheduler mq-deadline registered
[    0.209885] io scheduler kyber registered
[    0.209984] io scheduler bfq registered
[    0.211834] vcc5v0_host: supplied by vcc5v0_usb
[    0.217136] rockchip-pcie f8000000.pcie: f8000000.pcie supply vpcie1v8 not found, using dummy regulator
[    0.217186] rockchip-pcie f8000000.pcie: f8000000.pcie supply vpcie0v9 not found, using dummy regulator
[    0.762315] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    0.762672] rockchip-pcie: probe of f8000000.pcie failed with error -110
[    0.763531] IPMI message handler: version 39.2
[    0.765021] dma-pl330 ff6d0000.dma-controller: WARN: Device release is not defined so it is not safe to unbind this driver while in use
[    0.765681] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.765692] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    0.765914] dma-pl330 ff6e0000.dma-controller: WARN: Device release is not defined so it is not safe to unbind this driver while in use
[    0.766980] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.766992] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    0.768508] pwm-regulator: supplied by regulator-dummy
[    0.768699] vcc5v0_typec: supplied by vcc5v0_usb
[    0.769410] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.771147] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
[    0.771866] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 38, base_baud = 1500000) is a 16550A
[    0.877017] printk: console [ttyS2] enabled
[    0.879302] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.882481] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    0.883097] spi-nor: probe of spi0.0 failed with error -2
[    0.884214] libphy: Fixed MDIO Bus: probed
[    0.884638] usbcore: registered new interface driver asix
[    0.891470] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/otg-port
[    0.899191] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.899766] ehci-pci: EHCI PCI platform driver
[    0.900181] ehci-platform: EHCI generic platform driver
[    0.902799] ehci-platform fe380000.usb: EHCI Host Controller
[    0.903403] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[    0.904169] ehci-platform fe380000.usb: irq 30, io mem 0xfe380000
[    0.932277] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    0.932927] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
[    0.933651] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.934283] usb usb1: Product: EHCI Host Controller
[    0.934712] usb usb1: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ehci_hcd
[    0.935276] usb usb1: SerialNumber: fe380000.usb
[    0.935987] hub 1-0:1.0: USB hub found
[    0.936339] hub 1-0:1.0: 1 port detected
[    0.939040] ehci-platform fe3c0000.usb: EHCI Host Controller
[    0.939631] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[    0.940382] ehci-platform fe3c0000.usb: irq 32, io mem 0xfe3c0000
[    0.962274] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    0.962909] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
[    0.963634] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.964267] usb usb2: Product: EHCI Host Controller
[    0.964697] usb usb2: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ehci_hcd
[    0.965260] usb usb2: SerialNumber: fe3c0000.usb
[    0.965940] hub 2-0:1.0: USB hub found
[    0.966290] hub 2-0:1.0: 1 port detected
[    0.967034] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.967586] ohci-pci: OHCI PCI platform driver
[    0.968015] ohci-platform: OHCI generic platform driver
[    0.968618] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    0.969323] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[    0.970073] ohci-platform fe3a0000.usb: irq 31, io mem 0xfe3a0000
[    1.036390] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.05
[    1.037114] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.037746] usb usb3: Product: Generic Platform OHCI controller
[    1.038265] usb usb3: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ohci_hcd
[    1.038828] usb usb3: SerialNumber: fe3a0000.usb
[    1.039531] hub 3-0:1.0: USB hub found
[    1.039882] hub 3-0:1.0: 1 port detected
[    1.040548] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    1.041226] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[    1.041968] ohci-platform fe3e0000.usb: irq 33, io mem 0xfe3e0000
[    1.116480] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.05
[    1.117208] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.117842] usb usb4: Product: Generic Platform OHCI controller
[    1.118363] usb usb4: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ohci_hcd
[    1.118929] usb usb4: SerialNumber: fe3e0000.usb
[    1.119801] hub 4-0:1.0: USB hub found
[    1.120160] hub 4-0:1.0: 1 port detected
[    1.121090] uhci_hcd: USB Universal Host Controller Interface driver
[    1.122497] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.123132] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
[    1.123931] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    1.124774] xhci-hcd xhci-hcd.0.auto: irq 227, io mem 0xfe800000
[    1.125579] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
[    1.126306] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.126939] usb usb5: Product: xHCI Host Controller
[    1.127369] usb usb5: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd
[    1.127934] usb usb5: SerialNumber: xhci-hcd.0.auto
[    1.128761] hub 5-0:1.0: USB hub found
[    1.129120] hub 5-0:1.0: 1 port detected
[    1.129757] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.130363] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6
[    1.131042] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    1.131668] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.132497] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
[    1.133223] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.133857] usb usb6: Product: xHCI Host Controller
[    1.134288] usb usb6: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd
[    1.134853] usb usb6: SerialNumber: xhci-hcd.0.auto
[    1.135661] hub 6-0:1.0: USB hub found
[    1.136017] hub 6-0:1.0: 1 port detected
[    1.136799] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    1.137409] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 7
[    1.138204] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    1.139070] xhci-hcd xhci-hcd.1.auto: irq 228, io mem 0xfe900000
[    1.139872] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
[    1.140599] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.141232] usb usb7: Product: xHCI Host Controller
[    1.141664] usb usb7: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd
[    1.142229] usb usb7: SerialNumber: xhci-hcd.1.auto
[    1.143063] hub 7-0:1.0: USB hub found
[    1.143420] hub 7-0:1.0: 1 port detected
[    1.144046] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    1.144646] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 8
[    1.145327] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    1.145951] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.146755] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
[    1.147481] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.148114] usb usb8: Product: xHCI Host Controller
[    1.148545] usb usb8: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd
[    1.149110] usb usb8: SerialNumber: xhci-hcd.1.auto
[    1.149917] hub 8-0:1.0: USB hub found
[    1.150272] hub 8-0:1.0: 1 port detected
[    1.151030] usbcore: registered new interface driver uas
[    1.151630] usbcore: registered new interface driver usb-storage
[    1.152191] usbcore: registered new interface driver ums-alauda
[    1.152766] usbcore: registered new interface driver ums-cypress
[    1.153326] usbcore: registered new interface driver ums-datafab
[    1.153883] usbcore: registered new interface driver ums_eneub6250
[    1.154455] usbcore: registered new interface driver ums-freecom
[    1.155013] usbcore: registered new interface driver ums-isd200
[    1.155562] usbcore: registered new interface driver ums-jumpshot
[    1.156126] usbcore: registered new interface driver ums-karma
[    1.156667] usbcore: registered new interface driver ums-onetouch
[    1.157246] usbcore: registered new interface driver ums-realtek
[    1.157806] usbcore: registered new interface driver ums-sddr09
[    1.158355] usbcore: registered new interface driver ums-sddr55
[    1.158905] usbcore: registered new interface driver ums-usbat
[    1.159493] usbcore: registered new interface driver usbserial_generic
[    1.160082] usbserial: USB Serial support registered for generic
[    1.162823] mousedev: PS/2 mouse device common for all mice
[    1.165439] rk808 0-001b: chip id: 0x0
[    1.169034] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    1.169592] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    1.170175] DCDC_REG1: supplied by vcc5v0_sys
[    1.171369] DCDC_REG2: supplied by vcc5v0_sys
[    1.172294] DCDC_REG3: supplied by vcc5v0_sys
[    1.172826] DCDC_REG4: supplied by vcc5v0_sys
[    1.173643] LDO_REG1: supplied by vcc5v0_sys
[    1.175213] LDO_REG2: supplied by vcc5v0_sys
[    1.175750] vcc3v0_touch: Bringing 1800000uV into 3000000-3000000uV
[    1.177264] LDO_REG3: supplied by vcc5v0_sys
[    1.178682] LDO_REG4: supplied by vcc5v0_sys
[    1.179215] vcc_sdio: Bringing 3300000uV into 3000000-3000000uV
[    1.180751] LDO_REG5: supplied by vcc5v0_sys
[    1.182039] LDO_REG6: supplied by vcc5v0_sys
[    1.183552] LDO_REG7: supplied by vcc5v0_sys
[    1.184859] LDO_REG8: supplied by vcc5v0_sys
[    1.186302] SWITCH_REG1: supplied by vcc3v3_sys
[    1.186992] SWITCH_REG2: supplied by vcc3v3_sys
[    1.190664] rk808-rtc rk808-rtc: registered as rtc0
[    1.191643] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    1.192277] fan53555-reg: supplied by vcc5v0_sys
[    1.193581] random: fast init done
[    1.194165] vcc1v8_s3: supplied by vcc_1v8
[    1.195046] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    1.195659] fan53555-reg: supplied by vcc5v0_sys
[    1.198012] typec_fusb302 4-0022: No cable types defined, using default cables
[    1.198706] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22
[    1.202715] device-mapper: uevent: version 1.0.3
[    1.203310] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com
[    1.207771] sdhci: Secure Digital Host Controller Interface driver
[    1.208315] sdhci: Copyright(c) Pierre Ossman
[    1.209280] Synopsys Designware Multimedia Card Interface Driver
[    1.210806] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[    1.211455] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[    1.212058] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[    1.212588] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 28,32 bit host data width,256 deep fifo
[    1.213498] dwmmc_rockchip fe320000.dwmmc: Got CD GPIO
[    1.226613] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    1.240550] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.241747] mmc1: CQHCI version 5.10
[    1.267598] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    1.269753] ledtrig-cpu: registered to indicate activity on CPUs
[    1.270570] hid: raw HID events driver (C) Jiri Kosina
[    1.271129] usbcore: registered new interface driver usbhid
[    1.271616] usbhid: USB HID core driver
[    1.275774] Initializing XFRM netlink socket
[    1.276401] NET: Registered protocol family 10
[    1.282121] Segment Routing with IPv6
[    1.282532] mip6: Mobile IPv6
[    1.282798] NET: Registered protocol family 17
[    1.283562] Key type dns_resolver registered
[    1.284779] registered taskstats version 1
[    1.285141] Loading compiled-in X.509 certificates
[    1.285612] zswap: loaded using pool lzo/zbud
[    1.286052] Key type ._fscrypt registered
[    1.286403] Key type .fscrypt registered
[    1.286745] Key type fscrypt-provisioning registered
[    1.287213] Key type big_key registered
[    1.288801] Key type encrypted registered
[    1.304489] rk808-rtc rk808-rtc: setting system clock to 2013-01-18T08:50:16 UTC (1358499016)
[    1.306190] ALSA device list:
[    1.306455]   No soundcards found.
[    1.306954] ttyS2 - failed to request DMA
[    1.307386] md: Waiting for all devices to be available before autodetect
[    1.307978] md: If you don't use raid, use raid=noautodetect
[    1.308959] md: Autodetecting RAID arrays.
[    1.309320] md: autorun ...
[    1.309566] md: ... autorun DONE.
[    1.309886] Waiting for root device /dev/mmcblk1p3...
[    1.322757] usb 1-1: new high-speed USB device number 2 using ehci-platform
[    1.367034] mmc1: Command Queue Engine enabled
[    1.367446] mmc1: new HS200 MMC card at address 0001
[    1.368507] mmcblk1: mmc1:0001 SLD32G 28.9 GiB
[    1.369117] mmcblk1boot0: mmc1:0001 SLD32G partition 1 4.00 MiB
[    1.369842] mmcblk1boot1: mmc1:0001 SLD32G partition 2 4.00 MiB
[    1.370589] mmcblk1rpmb: mmc1:0001 SLD32G partition 3 4.00 MiB, chardev (238:0)
[    1.374028] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[    1.374750] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.375375] usb 1-1: Product: USB 2.0 Hub
[    1.375549] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    1.376231] hub 1-1:1.0: USB hub found
[    1.376376] GPT:8708252 != 60620799
[    1.376834] hub 1-1:1.0: 4 ports detected
[    1.377010] GPT:Alternate GPT header not at the end of the disk.
[    1.377884] GPT:8708252 != 60620799
[    1.378191] GPT: Use GNU Parted to correct GPT errors.
[    1.378684]  mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[    1.453997] EXT4-fs (mmcblk1p3): mounted filesystem without journal. Opts: (null)
[    1.454719] VFS: Mounted root (ext4 filesystem) on device 179:3.
[    1.457760] devtmpfs: mounted
[    1.458404] Freeing unused kernel memory: 1216K
[    1.458859] Run /sbin/init as init process
[    1.512557] usb 8-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[    1.548005] usb 8-1: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.54
[    1.548734] usb 8-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.549360] usb 8-1: Product: USB3.1 Hub
[    1.549706] usb 8-1: Manufacturer: GenesysLogic
[    1.578726] hub 8-1:1.0: USB hub found
[    1.579421] hub 8-1:1.0: 4 ports detected
[    1.584201] random: init: uninitialized urandom read (12 bytes read)
[    1.692383] usb 7-1: new high-speed USB device number 2 using xhci-hcd
[    1.725403] usb 7-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.54
[    1.726130] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.726756] usb 7-1: Product: USB2.1 Hub
[    1.727102] usb 7-1: Manufacturer: GenesysLogic
[    1.752402] usb 4-1: new full-speed USB device number 2 using ohci-platform
[    1.786931] hub 7-1:1.0: USB hub found
[    1.787733] hub 7-1:1.0: 4 ports detected
[    1.802532] usb 1-1.1: new low-speed USB device number 3 using ehci-platform
[    1.841435] configfs: Unknown parameter 'mode'
[    1.842904] udevd[428]: starting version 225
[    1.857233] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.857878] random: udevadm: uninitialized urandom read (16 bytes read)
[    2.017350] usb 4-1: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice= 1.34
[    2.018126] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.029477] frecon[486]: No monitor available, running headless!
[    2.032691] frecon[486]: No monitor available, running headless!
[    2.035080] frecon[486]: No monitor available, running headless!
[    2.037729] frecon[486]: No monitor available, running headless!
[    2.069259] usb 1-1.1: New USB device found, idVendor=413c, idProduct=2113, bcdDevice= 1.08
[    2.069993] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    2.070632] usb 1-1.1: Product: Dell KB216 Wired Keyboard
[    2.075262] input: Dell KB216 Wired Keyboard as /devices/platform/fe380000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:413C:2113.0001/input/input0
[    2.122309] usb 7-1.3: new low-speed USB device number 3 using xhci-hcd
[    2.144113] hid-generic 0003:413C:2113.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-fe380000.usb-1.1/input0
[    2.151809] input: Dell KB216 Wired Keyboard System Control as /devices/platform/fe380000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:413C:2113.0002/input/input1
[    2.223198] input: Dell KB216 Wired Keyboard Consumer Control as /devices/platform/fe380000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:413C:2113.0002/input/input2
[    2.225210] hid-generic 0003:413C:2113.0002: input,hidraw1: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-fe380000.usb-1.1/input1
[    2.277036] usb 7-1.3: New USB device found, idVendor=03f0, idProduct=0941, bcdDevice= 1.00
[    2.277780] usb 7-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.278422] usb 7-1.3: Product: HP X500 USB Optical Mouse
[    2.278897] usb 7-1.3: Manufacturer: PixArt
[    2.316577] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: commit=600
[    2.324883] EXT4-fs (mmcblk1p8): mounted filesystem with ordered data mode. Opts: (null)
[    2.333301] input: PixArt HP X500 USB Optical Mouse as /devices/platform/usb@fe900000/fe900000.dwc3/xhci-hcd.1.auto/usb7/7-1/7-1.3/7-1.3:1.0/0003:03F0:0941.00033
[    2.335911] hid-generic 0003:03F0:0941.0003: input,hidraw2: USB HID v1.11 Mouse [PixArt HP X500 USB Optical Mouse] on usb-xhci-hcd.1.auto-1.3/input0
[    2.348541] Bluetooth: Core ver 2.22
[    2.348893] NET: Registered protocol family 31
[    2.349282] Bluetooth: HCI device and connection manager initialized
[    2.349843] Bluetooth: HCI socket layer initialized
[    2.350271] Bluetooth: L2CAP socket layer initialized
[    2.350717] Bluetooth: SCO socket layer initialized
[    2.358653] usbcore: registered new interface driver btusb
[    2.422316] usb 1-1.2: new full-speed USB device number 4 using ehci-platform
[    2.426837] loop: module loaded
[    2.462466] usb 7-1.4: new high-speed USB device number 4 using xhci-hcd
[    2.493465] usb 7-1.4: New USB device found, idVendor=0bda, idProduct=8179, bcdDevice= 0.00
[    2.494204] usb 7-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.494842] usb 7-1.4: Product: 802.11n NIC
[    2.495209] usb 7-1.4: Manufacturer: Realtek
[    2.495583] usb 7-1.4: SerialNumber: 00E04C0001
[    2.676319] usb 1-1.2: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[    2.677054] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.677693] usb 1-1.2: Product: USB Audio Device
[    2.678097] usb 1-1.2: Manufacturer: C-Media Electronics Inc.
[    2.680569] input: C-Media Electronics Inc. USB Audio Device as /devices/platform/fe380000.usb/usb1/1-1/1-1.2/1-1.2:1.3/0003:0D8C:0014.0004/input/input4
[    2.744142] hid-generic 0003:0D8C:0014.0004: input,hidraw3: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-fe380000.usb-1.2/input3
[    2.920672] usbcore: registered new interface driver snd-usb-audio
[    3.023625] lib80211: common routines for IEEE802.11 drivers
[    3.049599] r8188eu: module is from the staging directory, the quality is unknown, you have been warned.
[    3.062528] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
[    3.086552] usbcore: registered new interface driver r8188eu
[    4.859697] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: discard,commit=600
[    4.867508] EXT4-fs (dm-0): resizing filesystem from 4096 to 149900 blocks
[    4.870966] EXT4-fs (dm-0): resized filesystem to 149900
[    5.113122] EXT4-fs (mmcblk1p1): re-mounted. Opts: resgid=20119,commit=600
[    5.237740] init: ureadahead main process (663) terminated with status 5
[    5.304608] systemd-journald[757]: Running without systemd.
[    5.306503] zram: Added device: zram0
[    5.317920] zram0: detected capacity change from 0 to 3855314944
[    5.338466] systemd-journald[757]: Received request to flush runtime journal from PID 813
[    5.352371] init: vpd-log main process (672) terminated with status 1
[    5.530220] init: platform-cpusets main process (894) terminated with status 2
[    5.636683] init: tcsd main process (1012) terminated with status 137
[    5.637284] init: tcsd main process ended, respawning
[    5.677151] init: machine-info pre-start process (910) terminated with status 1
[    5.816319] init: daisydog pre-start process (896) terminated with status 1
[    6.402624] Adding 3764952k swap on /dev/zram0.  Priority:-2 extents:1 across:3764952k SSFS
Developer Console
To return to the browser, press:
 [ Ctrl ] and [ Alt ] and [ <- ]  (F1)
To use this console, the developer mode switch must be engaged.
Doing so will destroy any saved data on the system.
In developer mode, it is possible to
- login and sudo as user 'chronos'
- require a password for sudo and login(*)
- disable power management behavior (screen dimming):
 sudo initctl stop powerd
- install your own operating system image!
* To set a password for 'chronos', run the following as root:
chromeos-setdevpasswd
If you are having trouble booting a self-signed kernel, you may need to
enable USB booting.  To do so, run the following as root:
enable_dev_usb_boot
Have fun and send patches!
(none) login: [    7.548165] ttyS0 - failed to request DMA
[    8.222467] phy phy-ff770000.syscon:usb2-phy@e450.2: charger = USB_DCP_CHARGER
[    9.882274] random: crng init done
[    9.882577] random: 7 urandom warning(s) missed due to ratelimiting
[   12.466276] init: ui main process (1135) terminated with status 2
[   12.875065] init: machine-info pre-start process (1522) terminated with status 1
[   14.793602] init: ui main process (1615) terminated with status 2
[   15.195987] init: machine-info pre-start process (1775) terminated with status 1
[   17.186482] init: ui main process (1872) terminated with status 2
[   17.610288] init: machine-info pre-start process (2032) terminated with status 1
[   17.622996] init: sdio-hciattach main process (900) terminated with status 1
[   19.485718] init: ui main process (2125) terminated with status 2
[   19.924661] init: machine-info pre-start process (2287) terminated with status 1
[   21.802552] init: ui main process (2380) terminated with status 2
[   22.214531] init: machine-info pre-start process (2547) terminated with status 1
[   24.100347] init: ui main process (2640) terminated with status 2
[   24.509680] init: machine-info pre-start process (2798) terminated with status 1
[   26.540113] init: ui main process (2891) terminated with status 2
[   35.640485] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
[   35.641069] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
[   35.642167] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
[   35.643008] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[   35.643625] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[   35.644119] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11).
[   35.644616] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[   35.645178] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[   35.645784] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[   35.651322] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[   35.653096] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[   35.653725] rk_gmac-dwmac fe300000.ethernet:         DWMAC1000
[   35.654181] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
[   35.654833] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
[   35.655482] rk_gmac-dwmac fe300000.ethernet: COE Type 2
[   35.655937] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
[   35.656550] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
[   35.657137] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
[   35.657652] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
[   35.658161] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[   35.728133] es8316 1-0011: Failed to get IRQ 0: -22
[   35.830415] libphy: stmmac: probed
[   35.830725] RTL8211E Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[   35.831815] RTL8211E Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[   35.847450] rockchip-vop ff8f0000.vop: Adding to iommu group 1
[   35.848576] rockchip-vop ff900000.vop: Adding to iommu group 2
[   35.854512] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm])
[   35.857202] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm])
[   35.858187] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[   35.859721] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm])
[   35.860552] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   35.861128] [drm] No driver support for vblank timestamp query.
[   35.861695] [drm] Cannot find any crtc or sizes
[   35.862621] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
[   35.933669] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
[   35.935417] rockchip-rga ff680000.rga: HW Version: 0x03.02
[   35.936292] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
[   35.937128] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211E Gigabit Ethernet] (irq=POLL)
[   35.943117] panfrost ff9a0000.gpu: clock rate = 500000000
[   35.943504] hantro-vpu ff650000.video-codec: Adding to iommu group 0
[   35.948635] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video1
[   35.949642] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video2
[   35.950152] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found
[   35.951067] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW
[   35.951664] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode
[   35.955898] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
[   35.956696] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
[   35.957512] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
[   35.958685] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
[   35.965780] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 1
[   35.980666] input: gpio-keys as /devices/platform/gpio-keys/input/input5
[   36.060414] asoc-audio-graph-card sound: ES8316 HiFi <-> ff890000.i2s mapping ok
[   36.061109] asoc-audio-graph-card sound: ASoC: no DMI vendor name!
[   36.077529] asoc-simple-card hdmi-sound: i2s-hifi <-> ff8a0000.i2s mapping ok
[   36.078195] asoc-simple-card hdmi-sound: ASoC: no DMI vendor name!
[   36.082459] Registered IR keymap rc-cec
[   36.082978] rc rc0: dw_hdmi as /devices/platform/ff940000.hdmi/rc/rc0
[   36.083768] input: dw_hdmi as /devices/platform/ff940000.hdmi/rc/rc0/input6
[   36.166406] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   36.181286] Console: switching to colour frame buffer device 240x67
[   36.221709] rockchip-drm display-subsystem: fb0: rockchipdrmfb frame buffer device
[   37.004427] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   37.844574] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   38.690685] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   39.530399] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   40.376052] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   41.220474] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   42.060487] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   42.905584] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   43.746209] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   44.590604] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   45.436533] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   46.276535] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   47.121836] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   47.961761] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   48.806530] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   49.652324] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   50.492506] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   51.338095] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   52.177650] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   53.022484] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
[   53.868216] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
It booted, but screen didnt light up, likely due to HDMI errors above.
However via serial console, its responsive!
Developer Console
enable_dev_usb_boot
(none) login: chronos
chronos@(none) ~ $
chronos@(none) ~ $ ls -la
total 8
drwxr-xr-x 2 chronos chronos 4096 Jan  1 16:00 .
drwxr-xr-x 5 chronos chronos 4096 Jan  1 16:00 ..
chronos@(none) ~ $ uname -a
Linux (none) 5.5.0-MANJARO-ARM+ #3 SMP Mon Feb 17 00:45:01 CET 2020 aarch64 GNU/Linux
chronos@(none) ~ $
Happy to investiage further as needed.
Thanks!
Noticing that u-boot was applying dtb file for RockPro64, I moved the RockPro64 dtb file and replaced it with dtb file for my device (Rock-Pi-4).
Result: it does not reach developer console, similar to output posted by @tophneal earlier:
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Machine model: Radxa ROCK Pi 4
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 64 MiB at 0x00000000f4000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 34 pages/cpu s101400 r8192 d29672 u139264
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 991752
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
[    0.000000] Memory: 3788564K/4030464K available (13628K kernel code, 838K rwdata, 5448K rodata, 1216K init, 8475K bss, 176364K reserved, 65536K cma-reserved)
[    0.000000] random: get_random_u64 called from cache_random_seq_create+0x78/0x130 with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: no VLPI support, no direct LPI support, no RVPEID support
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] ITS [mem 0xfee20000-0xfee3ffff]
[    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @eec80000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000000eec40000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000eec50000
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001054] Console: colour dummy device 80x25
[    0.001098] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.001109] pid_max: default: 32768 minimum: 301
[    0.001267] LSM: Security Framework initializing
[    0.001285] Yama: becoming mindful.
[    0.001367] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.001391] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.001450] *** VALIDATE tmpfs ***
[    0.001947] *** VALIDATE proc ***
[    0.002203] *** VALIDATE cgroup1 ***
[    0.002212] *** VALIDATE cgroup2 ***
[    0.003123] ASID allocator initialised with 65536 entries
[    0.003210] rcu: Hierarchical SRCU implementation.
[    0.003447] Platform MSI: interrupt-controller@fee20000 domain created
[    0.003782] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.004310] EFI services will not be available.
[    0.004714] smp: Bringing up secondary CPUs ...
[    0.005198] Detected VIPT I-cache on CPU1
[    0.005231] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.005246] GICv3: CPU1: using allocated LPI pending table @0x00000000eec60000
[    0.005289] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.005838] Detected VIPT I-cache on CPU2
[    0.005862] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.005873] GICv3: CPU2: using allocated LPI pending table @0x00000000eec70000
[    0.005898] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.006394] Detected VIPT I-cache on CPU3
[    0.006416] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.006426] GICv3: CPU3: using allocated LPI pending table @0x00000000eed00000
[    0.006449] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.006948] CPU features: detected: EL2 vector hardening
[    0.006954] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
[    0.006959] CPU features: detected: ARM erratum 1319367
[    0.006963] Detected PIPT I-cache on CPU4
[    0.006988] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.006999] GICv3: CPU4: using allocated LPI pending table @0x00000000eed10000
[    0.007026] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[    0.007549] Detected PIPT I-cache on CPU5
[    0.007570] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.007579] GICv3: CPU5: using allocated LPI pending table @0x00000000eed20000
[    0.007601] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[    0.007684] smp: Brought up 1 node, 6 CPUs
[    0.007736] SMP: Total of 6 processors activated.
[    0.007744] CPU features: detected: 32-bit EL0 Support
[    0.007751] CPU features: detected: CRC32 instructions
[    0.034793] CPU: All CPU(s) started at EL2
[    0.034879] alternatives: patching kernel code
[    0.037317] devtmpfs: initialized
[    0.045316] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.045336] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.047905] pinctrl core: initialized pinctrl subsystem
[    0.048732] thermal_sys: Registered thermal governor 'fair_share'
[    0.048735] thermal_sys: Registered thermal governor 'bang_bang'
[    0.048744] thermal_sys: Registered thermal governor 'step_wise'
[    0.048750] thermal_sys: Registered thermal governor 'user_space'
[    0.049205] DMI not present or invalid.
[    0.049687] NET: Registered protocol family 16
[    0.051630] DMA: preallocated 256 KiB pool for atomic allocations
[    0.052551] cpuidle: using governor ladder
[    0.052568] cpuidle: using governor menu
[    0.052937] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.053167] Serial: AMBA PL011 UART driver
[    0.077926] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.077935] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.077942] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.077948] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.088968] cryptd: max_cpu_qlen set to 1000
[    0.114115] ACPI: Interpreter disabled.
[    0.114509] vcc5v0_sys: supplied by vcc12v_dcin
[    0.114801] vcc3v3_pcie: supplied by vcc5v0_sys
[    0.114995] vcc3v3_sys: supplied by vcc5v0_sys
[    0.115257] vcc5v0_host: supplied by vcc5v0_sys
[    0.115495] vcc5v0_typec: supplied by vcc5v0_sys
[    0.116078] iommu: Default domain type: Translated
[    0.117650] vgaarb: loaded
[    0.118281] SCSI subsystem initialized
[    0.118570] usbcore: registered new interface driver usbfs
[    0.118599] usbcore: registered new interface driver hub
[    0.118662] usbcore: registered new device driver usb
[    0.119014] mc: Linux media interface: v0.10
[    0.119036] videodev: Linux video capture interface: v2.00
[    0.119066] pps_core: LinuxPPS API ver. 1 registered
[    0.119070] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.119093] PTP clock support registered
[    0.119245] EDAC MC: Ver: 3.0.0
[    0.119747] Advanced Linux Sound Architecture Driver Initialized.
[    0.120088] NetLabel: Initializing
[    0.120094] NetLabel:  domain hash size = 128
[    0.120099] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.120154] NetLabel:  unlabeled traffic allowed by default
[    0.120589] clocksource: Switched to clocksource arch_sys_counter
[    0.120599] *** VALIDATE bpf ***
[    0.120750] VFS: Disk quotas dquot_6.6.0
[    0.120799] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.120851] *** VALIDATE ramfs ***
[    0.120865] *** VALIDATE hugetlbfs ***
[    0.121140] pnp: PnP ACPI: disabled
[    0.125704] NET: Registered protocol family 2
[    0.126197] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.126257] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.126516] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    0.127006] TCP: Hash tables configured (established 32768 bind 32768)
[    0.127114] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.127214] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.127447] NET: Registered protocol family 1
[    0.127886] RPC: Registered named UNIX socket transport module.
[    0.127893] RPC: Registered udp transport module.
[    0.127897] RPC: Registered tcp transport module.
[    0.127902] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.127911] PCI: CLS 0 bytes, default 64
[    0.128847] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.129074] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.129382] kvm [1]: IPA Size Limit: 40bits
[    0.130732] kvm [1]: vgic-v2@fff20000
[    0.130755] kvm [1]: GIC system register CPU interface enabled
[    0.130899] kvm [1]: vgic interrupt IRQ10
[    0.131057] kvm [1]: Hyp mode initialized successfully
[    0.177207] Initialise system trusted keyrings
[    0.177338] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.182107] zbud: loaded
[    0.183979] NFS: Registering the id_resolver key type
[    0.184004] Key type id_resolver registered
[    0.184010] Key type id_legacy registered
[    0.184023] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.184057] ntfs: driver 2.1.32 [Flags: R/W].
[    0.184358] fuse: init (API version 7.31)
[    0.184428] *** VALIDATE fuse ***
[    0.184439] *** VALIDATE fuse ***
[    0.184696] SGI XFS with ACLs, security attributes, quota, no debug enabled
[    0.186022] *** VALIDATE xfs ***
[    0.206043] NET: Registered protocol family 38
[    0.206058] Key type asymmetric registered
[    0.206064] Asymmetric key parser 'x509' registered
[    0.206104] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    0.206226] io scheduler mq-deadline registered
[    0.206232] io scheduler kyber registered
[    0.206330] io scheduler bfq registered
[    0.212669] IPMI message handler: version 39.2
[    0.213822] dma-pl330 ff6d0000.dma-controller: WARN: Device release is not defined so it is not safe to unbind this driver while in use
[    0.214243] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.214252] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    0.214408] dma-pl330 ff6e0000.dma-controller: WARN: Device release is not defined so it is not safe to unbind this driver while in use
[    0.215090] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.215099] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    0.216132] pwm-regulator: supplied by regulator-dummy
[    0.216777] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.218042] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[    0.218148] serial serial0: tty port ttyS0 registered
[    0.218492] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 36, base_baud = 1500000) is a 16550A
[    0.320700] printk: console [ttyS2] enabled
[    0.322763] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.325616] libphy: Fixed MDIO Bus: probed
[    0.326038] usbcore: registered new interface driver asix
[    0.331734] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/otg-port
[    0.338948] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.339522] ehci-pci: EHCI PCI platform driver
[    0.339936] ehci-platform: EHCI generic platform driver
[    0.342550] ehci-platform fe380000.usb: EHCI Host Controller
[    0.343150] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[    0.343917] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[    0.370602] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    0.371252] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
[    0.371977] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.372610] usb usb1: Product: EHCI Host Controller
[    0.373039] usb usb1: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ehci_hcd
[    0.373602] usb usb1: SerialNumber: fe380000.usb
[    0.374330] hub 1-0:1.0: USB hub found
[    0.374685] hub 1-0:1.0: 1 port detected
[    0.377383] ehci-platform fe3c0000.usb: EHCI Host Controller
[    0.377977] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[    0.378730] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[    0.400605] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    0.401256] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
[    0.401980] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.402614] usb usb2: Product: EHCI Host Controller
[    0.403042] usb usb2: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ehci_hcd
[    0.403607] usb usb2: SerialNumber: fe3c0000.usb
[    0.404298] hub 2-0:1.0: USB hub found
[    0.404647] hub 2-0:1.0: 1 port detected
[    0.405380] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.405930] ohci-pci: OHCI PCI platform driver
[    0.406362] ohci-platform: OHCI generic platform driver
[    0.406973] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    0.407657] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[    0.408409] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[    0.474745] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.05
[    0.475470] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.476103] usb usb3: Product: Generic Platform OHCI controller
[    0.476623] usb usb3: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ohci_hcd
[    0.477187] usb usb3: SerialNumber: fe3a0000.usb
[    0.477883] hub 3-0:1.0: USB hub found
[    0.478238] hub 3-0:1.0: 1 port detected
[    0.478896] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    0.479582] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[    0.480329] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[    0.554838] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.05
[    0.555567] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.556201] usb usb4: Product: Generic Platform OHCI controller
[    0.556722] usb usb4: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ohci_hcd
[    0.557288] usb usb4: SerialNumber: fe3e0000.usb
[    0.558201] hub 4-0:1.0: USB hub found
[    0.558560] hub 4-0:1.0: 1 port detected
[    0.559470] uhci_hcd: USB Universal Host Controller Interface driver
[    0.560771] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    0.561402] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
[    0.562203] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    0.563045] xhci-hcd xhci-hcd.0.auto: irq 224, io mem 0xfe800000
[    0.563852] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
[    0.564579] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.565212] usb usb5: Product: xHCI Host Controller
[    0.565644] usb usb5: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd
[    0.566209] usb usb5: SerialNumber: xhci-hcd.0.auto
[    0.567045] hub 5-0:1.0: USB hub found
[    0.567403] hub 5-0:1.0: 1 port detected
[    0.568036] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    0.568640] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6
[    0.569320] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    0.569946] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.570774] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
[    0.571500] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.572134] usb usb6: Product: xHCI Host Controller
[    0.572565] usb usb6: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd
[    0.573130] usb usb6: SerialNumber: xhci-hcd.0.auto
[    0.573946] hub 6-0:1.0: USB hub found
[    0.574302] hub 6-0:1.0: 1 port detected
[    0.575072] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    0.575686] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 7
[    0.576496] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    0.577366] xhci-hcd xhci-hcd.1.auto: irq 225, io mem 0xfe900000
[    0.578164] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
[    0.578889] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.579522] usb usb7: Product: xHCI Host Controller
[    0.579954] usb usb7: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd
[    0.580519] usb usb7: SerialNumber: xhci-hcd.1.auto
[    0.581353] hub 7-0:1.0: USB hub found
[    0.581710] hub 7-0:1.0: 1 port detected
[    0.582342] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    0.582940] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 8
[    0.583626] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    0.584271] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.585074] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
[    0.585800] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.586433] usb usb8: Product: xHCI Host Controller
[    0.586865] usb usb8: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd
[    0.587430] usb usb8: SerialNumber: xhci-hcd.1.auto
[    0.588242] hub 8-0:1.0: USB hub found
[    0.588598] hub 8-0:1.0: 1 port detected
[    0.589346] usbcore: registered new interface driver uas
[    0.589950] usbcore: registered new interface driver usb-storage
[    0.590508] usbcore: registered new interface driver ums-alauda
[    0.591126] usbcore: registered new interface driver ums-cypress
[    0.591688] usbcore: registered new interface driver ums-datafab
[    0.592243] usbcore: registered new interface driver ums_eneub6250
[    0.592813] usbcore: registered new interface driver ums-freecom
[    0.593375] usbcore: registered new interface driver ums-isd200
[    0.593924] usbcore: registered new interface driver ums-jumpshot
[    0.594487] usbcore: registered new interface driver ums-karma
[    0.595027] usbcore: registered new interface driver ums-onetouch
[    0.595603] usbcore: registered new interface driver ums-realtek
[    0.596163] usbcore: registered new interface driver ums-sddr09
[    0.596713] usbcore: registered new interface driver ums-sddr55
[    0.597262] usbcore: registered new interface driver ums-usbat
[    0.597860] usbcore: registered new interface driver usbserial_generic
[    0.598450] usbserial: USB Serial support registered for generic
[    0.600912] mousedev: PS/2 mouse device common for all mice
[    0.603439] rk808 0-001b: chip id: 0x0
[    0.606672] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    0.607228] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    0.607815] DCDC_REG1: supplied by vcc5v0_sys
[    0.608916] DCDC_REG2: supplied by vcc5v0_sys
[    0.609689] DCDC_REG3: supplied by vcc5v0_sys
[    0.610220] DCDC_REG4: supplied by vcc5v0_sys
[    0.611061] LDO_REG1: supplied by vcc5v0_sys
[    0.612502] LDO_REG2: supplied by vcc5v0_sys
[    0.613035] vcc1v8_hdmi: Bringing 3000000uV into 1800000-1800000uV
[    0.614324] LDO_REG3: supplied by vcc5v0_sys
[    0.615653] LDO_REG4: supplied by vcc5v0_sys
[    0.616187] vcc_sdio: Bringing 3300000uV into 3000000-3000000uV
[    0.617593] LDO_REG5: supplied by vcc5v0_sys
[    0.618778] LDO_REG6: supplied by vcc5v0_sys
[    0.620105] LDO_REG7: supplied by vcc5v0_sys
[    0.620645] vcc0v9_hdmi: Bringing 1800000uV into 900000-900000uV
[    0.621961] LDO_REG8: supplied by vcc5v0_sys
[    0.623314] SWITCH_REG1: supplied by vcc3v3_sys
[    0.623871] SWITCH_REG2: supplied by vcc3v3_sys
[    0.627301] rk808-rtc rk808-rtc: registered as rtc0
[    0.628274] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    0.628887] fan53555-reg: supplied by vcc5v0_sys
[    0.630746] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    0.631357] fan53555-reg: supplied by vcc5v0_sys
[    0.635234] device-mapper: uevent: version 1.0.3
[    0.635834] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com
[    0.639894] sdhci: Secure Digital Host Controller Interface driver
[    0.640436] sdhci: Copyright(c) Pierre Ossman
[    0.641085] Synopsys Designware Multimedia Card Interface Driver
[    0.642105] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    0.642744] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    0.643343] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    0.643865] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    0.644770] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[    0.645288] mmc_host mmc0: card is non-removable.
[    0.646052] random: fast init done
[    0.658980] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    0.671049] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[    0.671688] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[    0.672290] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[    0.672821] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[    0.673741] dwmmc_rockchip fe320000.dwmmc: Got CD GPIO
[    0.686910] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    0.701026] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.703197] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
[    0.703284] mmc2: CQHCI version 5.10
[    0.705239] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[    0.707446] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[    0.710930] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
[    0.716582] mmc0: queuing unknown CIS tuple 0x81 (9 bytes)
[    0.730107] mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    0.732165] ledtrig-cpu: registered to indicate activity on CPUs
[    0.733310] hid: raw HID events driver (C) Jiri Kosina
[    0.733956] usbcore: registered new interface driver usbhid
[    0.734450] usbhid: USB HID core driver
[    0.740730] usb 1-1: new high-speed USB device number 2 using ehci-platform
[    0.742045] Initializing XFRM netlink socket
[    0.742866] NET: Registered protocol family 10
[    0.748346] Segment Routing with IPv6
[    0.748742] mip6: Mobile IPv6
[    0.749011] NET: Registered protocol family 17
[    0.749609] Key type dns_resolver registered
[    0.750733] registered taskstats version 1
[    0.751098] Loading compiled-in X.509 certificates
[    0.751639] zswap: loaded using pool lzo/zbud
[    0.752129] Key type ._fscrypt registered
[    0.752484] Key type .fscrypt registered
[    0.752828] Key type fscrypt-provisioning registered
[    0.753346] Key type big_key registered
[    0.755534] Key type encrypted registered
[    0.775605] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[    0.778112] rk808-rtc rk808-rtc: setting system clock to 2013-01-18T08:54:33 UTC (1358499273)
[    0.779347] ALSA device list:
[    0.779613]   No soundcards found.
[    0.780063] ttyS2 - failed to request DMA
[    0.780478] md: Waiting for all devices to be available before autodetect
[    0.781085] md: If you don't use raid, use raid=noautodetect
[    0.781975] md: Autodetecting RAID arrays.
[    0.782336] md: autorun ...
[    0.782582] md: ... autorun DONE.
[    0.782898] Waiting for root device /dev/mmcblk1p3...
[    0.791904] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[    0.792623] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    0.793248] usb 1-1: Product: USB 2.0 Hub
[    0.794111] hub 1-1:1.0: USB hub found
[    0.794648] hub 1-1:1.0: 4 ports detected
[    0.827562] mmc2: Command Queue Engine enabled
[    0.827977] mmc2: new HS400 Enhanced strobe MMC card at address 0001
[    0.829172] mmcblk2: mmc2:0001 SLD32G 28.9 GiB
[    0.829771] mmcblk2boot0: mmc2:0001 SLD32G partition 1 4.00 MiB
[    0.830489] mmcblk2boot1: mmc2:0001 SLD32G partition 2 4.00 MiB
[    0.831288] mmcblk2rpmb: mmc2:0001 SLD32G partition 3 4.00 MiB, chardev (238:0)
[    0.835833] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    0.836484] GPT:8708252 != 60620799
[    0.836791] GPT:Alternate GPT header not at the end of the disk.
[    0.837317] GPT:8708252 != 60620799
[    0.837625] GPT: Use GNU Parted to correct GPT errors.
[    0.838117]  mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[    0.922262] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 223
[    0.931807] mmc0: new ultra high speed SDR104 SDIO card at address 0001
[    0.960838] usb 7-1: new high-speed USB device number 2 using xhci-hcd
[    1.005384] usb 7-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.54
[    1.006114] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.006741] usb 7-1: Product: USB2.1 Hub
[    1.007089] usb 7-1: Manufacturer: GenesysLogic
[    1.065065] hub 7-1:1.0: USB hub found
[    1.065725] hub 7-1:1.0: 4 ports detected
[    1.151632] usb 8-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[    1.185000] usb 8-1: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.54
[    1.185744] usb 8-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.186380] usb 8-1: Product: USB3.1 Hub
[    1.186736] usb 8-1: Manufacturer: GenesysLogic
[    1.209314] hub 8-1:1.0: USB hub found
[    1.210021] hub 8-1:1.0: 4 ports detected
[    1.210715] usb 4-1: new full-speed USB device number 2 using ohci-platform
[    1.210900] usb 1-1.1: new low-speed USB device number 3 using ehci-platform
[    1.400901] usb 7-1.3: new low-speed USB device number 3 using xhci-hcd
[    1.468993] usb 1-1.1: New USB device found, idVendor=413c, idProduct=2113, bcdDevice= 1.08
[    1.469742] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    1.470389] usb 1-1.1: Product: Dell KB216 Wired Keyboard
[    1.475747] usb 4-1: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice= 1.34
[    1.476565] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.478371] input: Dell KB216 Wired Keyboard as /devices/platform/fe380000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:413C:2113.0001/input/input0
[    1.542843] hid-generic 0003:413C:2113.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-fe380000.usb-1.1/input0
[    1.550574] input: Dell KB216 Wired Keyboard System Control as /devices/platform/fe380000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:413C:2113.0002/input/input1
[    1.555736] usb 7-1.3: New USB device found, idVendor=03f0, idProduct=0941, bcdDevice= 1.00
[    1.556494] usb 7-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.557144] usb 7-1.3: Product: HP X500 USB Optical Mouse
[    1.557628] usb 7-1.3: Manufacturer: PixArt
[    1.613374] input: PixArt HP X500 USB Optical Mouse as /devices/platform/usb@fe900000/fe900000.dwc3/xhci-hcd.1.auto/usb7/7-1/7-1.3/7-1.3:1.0/0003:03F0:0941.00033
[    1.622065] input: Dell KB216 Wired Keyboard Consumer Control as /devices/platform/fe380000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:413C:2113.0002/input/input2
[    1.623308] hid-generic 0003:03F0:0941.0003: input,hidraw1: USB HID v1.11 Mouse [PixArt HP X500 USB Optical Mouse] on usb-xhci-hcd.1.auto-1.3/input0
[    1.624641] hid-generic 0003:413C:2113.0002: input,hidraw2: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-fe380000.usb-1.1/input1
[    1.741027] usb 7-1.4: new high-speed USB device number 4 using xhci-hcd
[    1.771688] usb 7-1.4: New USB device found, idVendor=0bda, idProduct=8179, bcdDevice= 0.00
[    1.772446] usb 7-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.773097] usb 7-1.4: Product: 802.11n NIC
[    1.773476] usb 7-1.4: Manufacturer: Realtek
[    1.773861] usb 7-1.4: SerialNumber: 00E04C0001
[    1.820856] usb 1-1.2: new full-speed USB device number 4 using ehci-platform
[    2.075586] usb 1-1.2: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[    2.076335] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.076984] usb 1-1.2: Product: USB Audio Device
[    2.077398] usb 1-1.2: Manufacturer: C-Media Electronics Inc.
[    2.081956] input: C-Media Electronics Inc. USB Audio Device as /devices/platform/fe380000.usb/usb1/1-1/1-1.2/1-1.2:1.3/0003:0D8C:0014.0004/input/input4
[    2.152447] hid-generic 0003:0D8C:0014.0004: input,hidraw3: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-fe380000.usb-1.2/input3
[    7.580926] phy phy-ff770000.syscon:usb2-phy@e450.2: charger = USB_DCP_CHARGER
[   82.120874] random: crng init done
That's very odd/interesting!
However, when I check the image in GParted, there is no error regarding a GPT header that's not correct...
  CrOS boot from sd, now pinebook doesn't boot anymore qdoy55d9wkn8zw 7 10,944 06-22-2020, 06:23 AM
  Panfrost and CrOS tophneal 2 4,469 04-20-2020, 12:23 PM
