Is it possible to power the phone without a battery?
I'd like to be able to power a smartphone device without the battery installed. Is this possible with the pinephone? Assuming by default it won't work (no phone after the galaxy S2 ever supported this), can the presence of a battery be faked such that it will work without damaging the device?
In case you're curious why: Intended application is to have it continuously powered near the head end of my bed where I will mainly use this device as a white noise generator and an alarm clock. I have currently gone through great trouble to rig up an LG Volt to do exactly this, but it relies on a questionable LineageOS build on the software end to work, and even more questionable methods to install said OS onto the phone. All in all it's a pain, and an open platform phone would be far more preferable.
The S8 I was using as a home phone with a DeX dock and 24" touchscreen just about exploded. You definitely don't want to leave them plugged in 24/7! I tried getting it to work without the battery too BTW (great minds think alike.)
Another solution is limiting the amount of charging to somewhere between 40% and 80%. The MyASUS app on my laptop does this as do some custom Android builds.
  Link USB power strips for a cluster? shanefe 1 203 04-02-2024, 11:11 PM
Last Post: evilbunny
  pine vacuum cleaner and door phone norayr 3 553 01-16-2024, 02:31 AM
Last Post: hanajijang
  New Phone, Laptop and Tablet based on RK3588 Zotax 6 4,414 09-28-2023, 12:43 AM
Last Post: faultyforelimb
  [Article] Star64 JH7110: Power Up the Display Controller with U-Boot Bootloader lupyuen 0 665 09-02-2023, 10:13 AM
Last Post: lupyuen
  Pine Desktop PowerSupply wont power on BSharp 5 1,771 08-29-2023, 08:06 AM
Last Post: chickenplusone
  power/battery usage on risc-v vs arm64? zetabeta 1 769 08-28-2023, 01:23 AM
Last Post: alphonso
  Link USB power strips for a cluster? DevonBirch 4 3,429 08-10-2023, 09:11 PM
Last Post: halibutdreary
  Plans for higher Power PinePowers PMARC14 0 532 07-14-2023, 03:03 PM
Last Post: PMARC14
  The power of the Star64 vs Pinebook Pro/RockPro64 Starfall 1 1,136 04-17-2023, 05:00 AM
Last Post: lkoini
  Possible Uninterruptible power supply for Pine64's SBC's GreyLinux 10 5,250 02-11-2023, 03:15 AM
Last Post: ToryRutter
