Advice on creating micro SD (Android)
In hindsight, I suspect my username reveals my frustration. Received my 1Gb board today and hurried off to download, via the Wiki, the latest Android version, WinRar and Phoenix.  I unpacked the Android Image into it's own folder and likewise Phoenix. Opened the Phoenix application and went off to select my Android image file 'android-ver5.1.1-20160428-pine64-8GB'  (7,569,408 KB). I immediately got the Phoenix error message "Script not found. Please use new image version".
I've tried deleting the downloaded Android file and re-downloaded (incase it had become corrupt in download) and unpacked, this time using Winzip. Same result when I try to select that image file with Phoenix  ( "Script not found. Please use new image version")
I've tried downloading different Android versions (all via Wiki) with the same results.
Any idea what I might be doing wrong here people?
(05-03-2016, 12:13 PM)phoenixcrap Wrote: I've tried downloading different Android versions (all via Wiki) with the same results.
You missed the right one. MD5 sum is 0aca1b9cc94babdb9313ce8c33a154f2. Isn't that funny how you lost you are only since the responsible guys don't care about documentation?
Guess what? You should use Rufus with DD images and Phoenix Card with Phoenix Card images. But why should this be pointed out? Why should information be added to the Wiki that you will fail booting when you connect an Ethernet cable on 1st boot? Why should you like so many others NOT WASTE HOURS OF YOUR LIVE since the responsible persons simple don't give a shit about adding a few sentences to the download links?
Star
Thanks very much tkaiser...that worked!  You are correct, I should not have to waste so much time and rely on helpful people like you when better information could be provided in the Wiki. Thanks again.
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 381,837 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,169 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,532 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 6,866 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 6,936 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,520 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,291 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 253,839 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,495 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 103,805 02-10-2019, 07:44 PM
Last Post: mmmarcus
