Servers ( Teamspeak 3 )
Hey guys,
I was wondring if pine could run teamspeak3 server because it's ARM based CPU.
Someone have knowledge about this?
Kind Regards
Glen
(12-10-2015, 03:03 AM)xxbutheadxx Wrote: Hey guys,
Kind Regards
Glen
From hardware capability point of view, should be possible. However, there is no developer contact us on teamspeak3 porting yet.
Kind Regards
Glen
Hardware is very well, i hope u guys can test it asap because it uses ARM based cpu.
Can u pls update me asap , installation for teamsepak server in done in 5m for newbies Smile
Ubuntu guide:
Step 1:
Login to SSH as root
Step 2:
Run the below commands:
Note: During the
sudo apt-get upgrade
command, you maybe asked about the grub load. Press Enter
sudo apt-get update
sudo apt-get dist-upgrade
Step 5 – 64 bit:
Teamspeak 3 server 64 bit (3.0.11.4) this is the newest version
wget "here u downlink"
tar xzf "the downloaded file"
cd "to the unpacked file map"
Step 9:
Now we start the TS3 server
./ts3server_startscript.sh start
Use this for a quick test, normally u shouln't tun this as root but for quick testing it's fine Smile
Kind Regards
xxbutheadxx
(12-10-2015, 03:03 AM)xxbutheadxx Wrote: I was wondring if pine could run teamspeak3 server because it's ARM based CPU.
Sure, you need at least http://eltechs.com/product/exagear-desktop/ since you've to emulate an x86 environment.
xxbutheadxx
wget needs a link to the location of the file that you need to download(you never provided it)
Yes correct :> google teamspeak and to downloads for the server package
or special for i post here a link: https://www.teamspeak.com/downloads#
(12-10-2015, 03:29 AM)xxbutheadxx Wrote: Step 5 – 64 bit:
You'll need the 32-bit version. As I already outlined: Without an x86 emulation you're lost on ARM when you want to run x86 software. And if you want it performant you'll have to spend a few bucks on top (the product you need already mentioned).
http://forum.lemaker.org/thread-15481-1-1.html
You should ask the Exagear people about ARMv8/Cortex-A53 support.
