Pine Phone no power up or just somtimes
Hello
I have receive my pinephone but i can't to power up (no led no lcd)
What is the problem, if i use lsusb command on ubuntu i can see :
Bus 001 Device 004: ID 1f3a:efe8 Onda (unverified) V972 tablet in flashing mode
Can i reflash postmarketos (bootloader) ?
Thanks in advance
exactly the same problem here...
Advice appreciated  Smile
Thanks!
https://wiki.pine64.org/index.php/PinePh...nformation
A slight possibility, loose battery connection?
(02-02-2020, 06:31 PM)dukla2000 Wrote: https://wiki.pine64.org/index.php/PinePh...nformation
Thank you for your suggestion. The same happens when the phone is connected with a USB cable, so I don't think it's a loose battery connection...
Remove the little tab between the battery and mainboard pins.
(02-03-2020, 05:03 AM)Luke Wrote: Remove the little tab between the battery and mainboard pins.
Thanks, tab is already removed.
Shot in the dark here, but do you press and hold the power button for >10 seconds? Mine requires 10 seconds.
"- is there already a tool for overclocking it desperately?"
(02-03-2020, 07:52 AM)murak Wrote: Shot in the dark here, but do you press and hold the power button for >10 seconds?  Mine requires 10 seconds.
Thanks for the suggestion murak, but that I tried already...
Do you have the original firmware for factory test ? to flash it please, i think this is the electronic card
pretty sure it's the loose battery. im having the same issues, I haven't managed to power it on without putting on the battery cover and pressing it very tightly to make sure the battery is in place. Put the phone in my backpack and went for a ride, that seems to have moved the battery and the phone was powered off until I could re-seat the battery properly.
  Looking for the "non-phone" OS wakyct 7 1,193 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 4,979 03-11-2024, 10:42 PM
Last Post: Emelia525
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 908 01-09-2024, 07:02 PM
Last Post: britelite
  control power management aular 0 485 12-16-2023, 12:16 PM
Last Post: aular
  Pine company idea aular 9 1,815 12-07-2023, 12:32 AM
  Can the Pine Phone be serviced and updated remotely? profileyourcity 3 1,073 10-02-2023, 05:19 PM
  UBports on pine phone? robb777 16 3,703 09-01-2023, 04:26 AM
Last Post: gregb49
  US Cell Phone Service Providers with prices and phone numbers - UPDATED jovval 0 722 07-01-2023, 01:25 AM
Last Post: jovval
  Loving my pine phone after about a year of not undata 0 700 05-11-2023, 02:23 PM
Last Post: undata
  New Phone Opening Issues LuluFrance 5 2,153 03-15-2023, 05:33 AM
Last Post: anonymous
