Help broke my pcie connector on the mother board.
Thanks man!
I go searching the internet [emoji12]
In the meantime i'm hoping that pine64 come with the original bom.
Verzonden vanaf mijn iPhone met Tapatalk
Definitely. I'll check around some more too. Sometimes it is possible to find some more unique stuff on TaoBao or eBay.
(Noticed you're a fellow Dutchman, succes met de zoektocht!)
I found a connector that I believe is compatible, the XF3C-3545-41A:
https://www.digikey.nl/product-detail/en...ND/2002626
The problem is finding it. Here's some sites that seem to sell it:
https://www.radwell.com/en-US/Buy/OMRON/...-3545-41A/
https://www.chip1stop.com/USA/en/view/di...RO-0073888
https://www.e-sonic.com/product-detail/o...C-3545-41A
https://www.aliexpress.com/item/32359830...b201603_53
It unfortunately seems to be discontinued, but you should be able to source it from somewhere. It's dual-sided, so it will work with the ribbon. Here's the datasheet for more info:
https://omronfs.omron.com/en_US/ecb/prod...j-069k.pdf
Can't guarantee it will work, but I think it's a good shot!
Thanks man!
I go search the links you gave.
And i let you know the results [emoji4]
I ordered it from aliexpress. So over a few weeks i can begin testing [emoji16].
Als je ooit een nodig heb. Je weet me te vinden.[emoji120]
Verzonden vanaf mijn iPad met Tapatalk
(02-06-2020, 04:55 AM)roncromberge Wrote: I ordered it from aliexpress. So over a few weeks i can begin testing [emoji16].
Good news! I hope it works out.
Ik houd het in gedachte. Smile
Response on my request.
Unfortunately the found partnr is not ok. It's shorter than the original part. Zo the flatcable does not fit.
I hav ordered a new nvme board so i can hopefully desolder the part and resolder it on the mainboard. On the other hand, the pbp is fast enough with the emmc. And th need of super much gigabytes is not there. I don't know if i ever go to a ssd.
To be continued
  pbp replacement board altacus 0 895 01-10-2022, 11:27 AM
Last Post: altacus
  Did I kill my PBP's board? overlisted 7 7,288 11-12-2020, 03:28 PM
Last Post: overlisted
  Pinebook Pro PCIe init issue R32Fanboy 4 5,158 11-05-2020, 09:59 AM
Last Post: vssz
  PCIe 12v power issue dlan17 1 2,000 05-12-2020, 05:25 AM
Last Post: Arwen
  PineBook Pro Stemma QT connector for Hardware Hacking ssfrfr@ 2 3,258 03-30-2020, 10:35 AM
Last Post: xmixahlx
  Last update broke netflix fpex73 2 3,475 02-25-2020, 06:32 AM
Last Post: fpex73
