WARNING: do not install manjaro-arm-qemu-static
If you install this package on Manjaro as required by some qemu+wine x86 tutorials on rpi, you will break your system and have to recover through chroot.
If you tend to follow RPI tutorials, or attempt to, to accomplish things, this one can have some bad consequences.
I'm not familiar with it so obviously as a rule don't run stuff if you don't know what it does, but I have been doing that a lot on PBP. It somehow made the system act like every binary was the wrong architecture, so not even basic commands like ls, cd, etc worked immediately after install.
(01-30-2020, 02:20 PM)aaspectre Wrote: If you install this package on Manjaro as required by some qemu+wine x86 tutorials on rpi, you will break your system and have to recover through chroot.
Always compile qemu from source
(01-30-2020, 02:25 PM)astr0baby Wrote: Always compile qemu from source
I had done, but I wasn't exactly sure what a particular wine x86 on rpi tutorial was calling for when it wanted me to cp a qemu-static binary from /usr/bin/ into a debootstrap, so I figured what could be the harm? Apparently, the immediate ceasing of literally all functionality. I guess this package will actually somehow get your system to run everything through qemu such that they are the wrong architecture despite being the right architecture? I'm still not sure what even happened,
If you want to take a look:
https://www.novaspirit.com/2019/04/15/run-x86-arm/
I'm still very keen on the idea of running x86 wine for some basic windows stuff on my PBP in more seamless way than a KVM, so if you have any suggestions or input, that'd be appreciated.
Let me tell you a little secret Smile Windows 10 arm64 is big part x86 (32bit) code and arm64 .. so it natively runs most apps that are x86 32bit .... Windows 10 arm64 runs quite well under accelerated qemu-system-aarch64 via KVM, all you need for good work is a USB network card for Qemu passthrough and connect to the VM over network with RDP ...
If you want to run Wine x86 stuff have a look at this project called Hangover https://github.com/AndreRH/hangover its designed for arm64
So this is what Microsoft is doing with its latest Surface Pro X. It works, but terribly slow.
  Manjaro Sway Theme Broken Eighty8 1 258 03-08-2024, 08:41 AM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 309 02-18-2024, 08:54 AM
Last Post: 9a3eedi
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,717 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 304 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,067 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,140 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 383 12-07-2023, 03:11 PM
  install debian on pbp jsch 7 3,965 11-22-2023, 04:22 PM
Last Post: TRS-80
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 855 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 1,991 08-21-2023, 09:10 PM
Last Post: vanessadonald
