[GUIDE] ArchLinuxARM on Pinebook Pro
Any reason to use linux 5.5 and an outdated uboot ?
I mean manjaro repo does have a fully working linux-pinebookpro 5.7 with cdn-dp enabled and a newer uboot package.
And if you don't use usb dp for external screen, you can use manjaro's mainline kernel.
(currently still has some stability problem regarding usb dp so they disable the cdn-dp for 5.10).
by the way, nadiaholmquist's repo also provides a quite vanilla kernel with only the minimal patch set needed for pinebook pro.
(I guess she only pulls the relevant patches from manjaro)
https://github.com/nadiaholmquist/pbp-packages
  Pinebook Pro Recovery with Void Linux (xbps) bds 0 367 01-14-2024, 10:21 PM
Last Post: bds
  Write SD cards with Etcher for Pinebook Pro futurejones 17 29,404 03-19-2021, 12:52 AM
Last Post: Alex007
  Program SPI NOR Flash on Pinebook Pro with u-boot on micro SD Card hmuller 0 3,393 09-21-2020, 10:02 AM
Last Post: hmuller
  Installing Docker on Pinebook Pro - update 1/18/20 SuperXkoodA 4 7,450 03-24-2020, 03:19 PM
Last Post: chaoskampf
  Swaywm on Pinebook Pro anjanmomi 10 13,650 02-06-2020, 11:47 AM
Last Post: xmixahlx
  Quick Guide to installing Ubuntu Unity on your Pinebook Pro andybleaden@gmail.com 19 23,019 02-03-2020, 11:17 AM
Last Post: MIchael
  Installing Wine i386 on Pinebook Pro wrzomar 0 3,211 01-31-2020, 03:52 PM
Last Post: wrzomar
  Hardening your Pinebook Pro software Arwen 4 7,326 12-11-2019, 09:53 AM
Last Post: hdk
