Void Linux is probably possible.
Currently, working Void images with kernel 5.6 can be found here: https://github.com/void-linux/void-mkliv...-589158795
Kernel 5.7 will be installed from repo when you update, and works as well
The 20200317 images boot up nicely from both microSD and eMMC
As illustrated in this comment, we will need updated u-boot before mainline/5.8 kernel can be booted
A couple questions, but 1st my impressions
login, took a bit of searching, I've changed, IIRR root:voidLinux
startx,, nope
ifconfig,, nope (just what is wrong with ifconfig??)
up arrow ,, nope Oh ... sh
bash,, yes!
At least there are the normal vt's, unlike bsd that maybe you can get working somehow
I guess i remember how ,, wpa_supplicant, that's all there is
So, update, install, more install and again and again and again
sddm,, yes! ,, all a bit plain, lots of customization still needed
BUT,,BUT the cube WORKS, this is the 1st time I have seen that on arm!
That impresses me
Sleep really matters to me, for a few reasons
from /etc/acpi/handler.sh,, dbus has to be running?
Probably in runit?
I know how to set up with systemd, not runit
How/where to increase terminal font size? ,, these old eyes have trouble with microscopic fonts
(08-30-2020, 10:22 PM)wdt Wrote: A couple questions, but 1st my impressions
startx,, nope
bash,, yes!
That impresses me
Probably in runit?
startx won't work until you install (at least) xorg-minimal and create ~/.xinitrc
ifconfig is deprecated, use `ip addr`
root's default shell is /bin/sh, create an unprivileged user to enjoy the comforts of the bash shell
wpa_supplicant is there by default, NetworkManager in repos
`wifish` is a good tool to control wpa_supplicant without mucking about in wpa_cli
sleep currently doesn't work on rk3399 (in any distro I believe, not supported in mainline kernel yet)
acpid is installed by default (enable with `ln -s /etc/sv/acpid /var/service/acpid`) and then you will be able to handle power events with /etc/acpi/handler.sh
sleep still won't work though
not actually sure how to increase font size in tty, I believe it's baked into the kernel/initramfs somehow
You are correct, not in mainline
I misspoke, tsy kernel has suspend 3 (manjaro), works fine, ~ 6-8%/day
uname -r 5.8.3-2-MANJARO-ARM
suspend to ram
This, of course, makes running off SD much more feasible.
Still need a good one, at least, for updates
The boot is indeed slow, but wake is ~10s, wifi another ~12s
Thanks for answers
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 327 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,458 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 653 07-13-2023, 05:21 PM
Last Post: owaspfap
  Kali Linux for Pinebook Pro Luke 100 158,871 05-03-2023, 06:10 AM
Last Post: dachalife
  DiY - Installing Void Linux ARM On The Pinebook Pro vincele 1 1,188 11-28-2022, 05:03 PM
  Arch Linux ARM root filesystem SKiljan 24 20,720 09-24-2022, 03:11 AM
Last Post: alexandre
Information Install Void Linux with near-full-disk encryption dumetrulo 3 3,057 09-05-2022, 12:00 PM
Last Post: petersen77
  Help with Kali Linux wifi not working but works with Manjaro PineSupporter 2 2,362 08-25-2022, 02:15 PM
Last Post: Niko
  Problems installing/ booting a different Linux on PinebookPro v-man 3 3,061 03-22-2022, 06:37 PM
Last Post: pentamassiv
Sad 1080p60 video on PBP Linux chewie 2 3,004 08-03-2021, 09:43 AM
Last Post: chewie
