Rebooting my clusterboard
Greetings all,
It's been almost a year since I spent any serious time working with my Clusterboard.  I'm wondering what developments have been made in the meantime, if there is a "go-to" distribution, etc.
Specifically, I'm interested in network booting the SOPINE modules from a single head node (A separate PINE64 board connected via Ethernet that will serve as a gateway between the Clusterboard network and the LAN).  Previously I had installed SD cards and O/S images on each SOPINE and I'd like to avoid doing that again if possible.
Has anyone successfully set this up, and/or can point me in the right direction?
Thanks!
(01-17-2020, 11:21 AM)jgullickson Wrote: Greetings all,
Thanks!
Hi jgullickson,
I have it running  4 sopines with archlinux using pxeboot and nfsroot.
It works very well moreover I cannot reboot the sopine yet.
If you need I can make available a simple how to and a basic rootfs based on archlinux for aarch64
Thanks!
Hi jgullickson,
I would like that very much!
Thanks!
I'm currently working on a Fedora 32 aarch64 based cluster.  booting of each board is not 100% reliable (might be something with my sdcards), and the realtek NIC has a known bug that requires a bit of extra work.
Here's some of the knowledge I've collected if you are interested.
https://forum.pine64.org/showthread.php?tid=9902
  Managed Ethernet switch on the Clusterboard dsimic 6 5,447 01-16-2024, 02:05 AM
Last Post: hazcam
  Selling Clusterboard + 4 sopine xblack86 7 5,889 09-26-2022, 03:09 AM
Last Post: poVoq
  clusterboard availability? linear 1 1,638 07-17-2022, 06:44 AM
Last Post: poVoq
  Clusterboard not getting IP address after network fix Norlark 14 12,609 08-30-2021, 05:00 PM
Last Post: poVoq
  When would be the Clusterboard back on stock? __kzl__ 5 5,268 08-16-2021, 03:52 AM
Last Post: poVoq
  Schematics for customising the Clusterboard TechDragon 0 2,088 05-25-2021, 10:28 AM
Last Post: TechDragon
Information Clusterboard Guide AZClusterboard 9 23,435 04-06-2021, 06:32 AM
Last Post: poVoq
Brick Clusterboard CAD drawings TeaPack 1 3,837 03-31-2021, 01:38 PM
Last Post: Pine
  New Clusterboard Setup wargfn 5 7,354 01-01-2021, 10:10 AM
Last Post: poVoq
  Clusterboard does not even turn on? poVoq 3 6,230 08-15-2020, 07:31 AM
Last Post: poVoq
