Only powers on with previous SD Card installed
Hi All,
Strange solution occurred this morning.
I've been trying out different OS on my PBP to see which I may stick with. So far have Mate Bionic image on the Emmc (from the tutorial instrcutions) and have SD cards with mate, chromium, manjaro.
Strangely I just shutdown from manjaro sd card and now the PBP will only power on with that specific SD Card in the slot.
i.e. I get 0 response (not even an orange LED) when pressing and holding the power button with any of the following attempts:
  1. No SD Card boot - Ubuntu Mate from EMMC  (worked last night)
  2. SD Card with Bootable Bionic Mate image
  3. SD Card with Chromium Image
Where as
     4. Replacing the SD card with the same Manjaro image - boots straight away. Very strange.
Can anyone point me towards a reason for this so I can figure out what to do?
Thanks,
Pete
OK - I appear to be back to booting from eMMC by dd'ing the Manjaro installer image straight to the hard drive and installing from there as per this guide:
https://forum.manjaro.org/t/manjaro-arm-...c/115599/9
I'm even back to being able to boot from SD cards as well!
Pinbook Pro is new this week and it reminds me soooo much of playing with computers nad taking them apart when I was a kid Smile All exploration and messing things up!
Hi Guys, I've now had this twice.
Went back to Bionic Mate booting from the pinebook eMMC as per this guide https://forum.pine64.org/showthread.php?tid=8119
Went as far as step 6 to get the boot loader fix As soon as i then tried to boot into a Chromium Build on an SD card (strangely this failed) then I could no longer load the eMMC build.
Recovered from a bioinc mate SD Card by re-flashing, but really strange that I can't boot an alternate OS on SD card without corrupting anything. Has anyone got any ideas on this?
Pete
If you are booting ayufan's Linux images, you should be advised that his images use the BSP u-boot. This u-boot places eMMC as first boot priority, with SD as the second. You will need to use a u-boot like mrfixit's to boot SDs first again (you can find links in the wiki.)
OK thank you Smile
It was an ayufan image. I did reload the mrfixit image after, but this is good to know!
  uboot wont boot to SD card after upgrade jbradley419 7 630 01-19-2024, 02:29 PM
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,068 09-19-2023, 08:48 AM
Last Post: dachalife
  Cannot Boot From SD Card xp19375 4 2,671 11-12-2022, 11:26 AM
  Can't boot when SD card inserted 0daysfordays 3 1,682 09-17-2022, 06:59 PM
  Problem SD card willahughes 1 1,503 03-22-2022, 09:27 AM
Last Post: jiyong
  Kali Linux on SD card boot wils91 5 4,148 03-08-2022, 04:39 AM
Last Post: Tazdevl
  cannot boot SD card : "unable to select a mode" alchemist 0 2,080 06-18-2021, 02:03 AM
Last Post: alchemist
Video Problem Booting from SD card ezryder324r 0 1,428 05-19-2021, 02:42 PM
Last Post: ezryder324r
  broken sd card reader? kratti 13 13,861 03-06-2021, 01:20 AM
Last Post: kratti
  I/O errors from SD card slot? (Manjaro, kernel 5.7) zackw 5 8,322 10-28-2020, 01:16 AM
Last Post: 25519
