Virtualization on the PinebookPro
#21
(05-24-2020, 03:35 PM)jiyong Wrote: I installed QEMU and VirtManager through the package manager.
But now I'm stuck with a missing firmware.
How do I get a firmware to start a VM?
You need to download QEMU_EFI firmware blob like this one
https://releases.linaro.org/components/kernel/uefi-linaro/latest/release/qemu64/QEMU_EFI.fd
Thanks for putting together the guide on this, very helpful!
Do you know if anyone is working on using QEMU without toggling some of the cores off? Is there maybe a GitHub issue I could follow? I'm running into this issue on NixOS, kernel 5.6.0 and QEMU 4.2.0.
(07-06-2020, 08:12 PM)_hg_ Wrote: Thanks for putting together the guide on this, very helpful!
You can probably raise this question on Qemu forums - check the aarch64 specific forum.
Thanks, I will check. I think first I should try building 5.x.
Manjaro with the 5.7.19-1 kernel:  I was able to use QEMU without KVM and without LIBVIRT - command line only, and get a few things working.  Not fast, and it is not pretty, but FreeDOS 1.3 <beta>  worked.  If you can live without the gui you might make things work that would fail under Virt-Manager.  I am not even TRYING to track down why!
PS: this was WITHOUT disabling any cores!
And running a couple of other things at the same time.  This is much better behavior than I expected.
Ancient teacher (Secondary Field Science/Math), Warrior (USARNG- RET SSG), and IT warrior (30+ years Coder, Network/Systems Administrator, general house geek).
Pinebook Pro user (Debian, Manjaro)
On Debian I was able to get Windows 95 to run under libvirt+QEMU on my PBP. It was pretty slow, and mouse was not very nice, but it worked. Until I figured out how to run Wine (see my post in Tutorials) and abandoned the whole VM idea.
This message was created with 100% recycled electrons
  PinebookPro Display Corrupts/Cuts Out Twig 5 2,115 06-11-2023, 07:59 AM
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 4,526 01-22-2023, 10:05 PM
Last Post: rfm83
  PinebookPro CPU Speed setting therosery 0 643 09-07-2022, 05:02 AM
Last Post: therosery
  PinebookPro Build Errors mexsudo 3 2,824 01-30-2022, 08:36 AM
Last Post: mexsudo
  PineBookPro does not charging floppy_rofling 0 1,610 02-03-2021, 05:29 AM
Last Post: floppy_rofling
Heart Zandronum 3.1 on PinebookPro PixelPaintbrush 0 1,725 12-08-2020, 09:59 AM
Last Post: PixelPaintbrush
  Running Libgdx sdk on pinebookpro Nick_dnepr 2 3,151 10-02-2020, 07:56 AM
Last Post: Nick_dnepr
Photo My PineBookPro Dead voodooman 2 3,150 09-14-2020, 09:10 AM
Last Post: Tharadash
