Gentoo on Pinebook Pro RELEASE
#51
Hi!
I've tried to install Gentoo following this guide https://github.com/Jannik2099/gentoo-pinebookpro to sd card with LVM and encrypted root. I can't boot it and it says nothing. I also see nothing in debug tty. How can I find what is going wrong?
(01-15-2020, 05:34 PM)VoxUnius Wrote: Hmm. Interesting. I've been playing with Gentoo on PBP for months but it still has the same issues it had in the beginning. The biggest ones would be: freezing LibreOffice that uses 100% CPU, and flickering widgets (checkboxes, in particular). Also, not sure if it uses video acceleration, looks like it is not. I used Manjaro kernel too, even tried the same config. I was hoping the problem lied in kernel/mesa/drm, but newer version didn't help.
I have the same issues.
Add `-gles2` to your `profile/use.mask. This will fix the issue.
Hello! I'd like to post that using Gentoo in 2023 with Megi's kernel is wonderful now! Hoping to post a guide soon, but in the meantime, my advice would be to /not/ use the patches anymore, but instead follow the guide and use the proper USE flags as suggested, and otherwise install like normal (as in just normally following the x86 handbook). When it comes to the kernel, https://forum.pine64.org/showthread.php?tid=18540 this thread sort of details how to use Megi's kernel. This way, you don't have to do kernel compilation or worry about juggling different sources, patches, etc. I also personally use tow-boot on my PBP because I put it on there long ago and it was an easy install and I'm personally terrified of bricking my bootloader as I don't think I have the tools or capability to fix it. But it is working perfectly well with hibernation, sleep, HDMI out, etc.
(11-26-2023, 06:36 PM)kebab Wrote: Hello! I'd like to post that using Gentoo in 2023 with Megi's kernel is wonderful now! Hoping to post a guide soon, but in the meantime, my advice would be to /not/ use the patches anymore, but instead follow the guide and use the proper USE flags as suggested, and otherwise install like normal (as in just normally following the x86 handbook). When it comes to the kernel, https://forum.pine64.org/showthread.php?tid=18540 this thread sort of details how to use Megi's kernel. This way, you don't have to do kernel compilation or worry about juggling different sources, patches, etc. I also personally use tow-boot on my PBP because I put it on there long ago and it was an easy install and I'm personally terrified of bricking my bootloader as I don't think I have the tools or capability to fix it. But it is working perfectly well with hibernation, sleep, HDMI out, etc.
Looking forward on your post guide.
  Debian on Pinebook Pro u974615 8 444 03-22-2024, 03:57 PM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,119 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 1,917 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 1,979 12-11-2023, 03:47 AM
Last Post: calinb
  Boot Order in Pinebook Pro food 8 993 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 4,926 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,325 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,425 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 607 07-13-2023, 05:21 PM
Last Post: owaspfap
  OpenCL on pinebook Pro Bram 2 907 06-30-2023, 08:50 PM
Last Post: scurrvy2020
