USB-C charging
@zaius
I read mostly specs or datasheets ...
For max. "real" current, which can draw PBP while loading, I must check schematics and do some math.
IOW currently not ...
@fpex73
maybe there is some delay here.
Currently I'm searching for the USB-C PD protocol datasheet.
They are also other USB charger in the wild with are not compatible with USB-C PD
know candidate is Qualcom
Photo P{inebook Pro not charging Ome Ko 6 1,966 11-09-2023, 03:29 PM
Last Post: tomekdev
  Pine Book Pro Charging Problems balin 7 6,880 12-15-2022, 02:15 PM
Last Post: tomasgreenro
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,494 02-22-2022, 11:20 AM
  Pinebook Pro Stopped Charging via USB-C MickTheGeek 4 4,270 08-25-2021, 02:51 PM
Last Post: MickTheGeek
  HArdware issues while charging user18130814200115 2 2,810 05-01-2021, 04:13 AM
Last Post: gabeeg
  PineBookPro does not charging floppy_rofling 0 1,637 02-03-2021, 05:29 AM
Last Post: floppy_rofling
  Screen flicker with USB-C charging bchenlee609 5 5,834 01-25-2021, 08:48 PM
Last Post: bchenlee609
  USB-C Charging on the PBP? Paulie420 33 35,622 12-12-2020, 02:20 PM
Last Post: wrzomar
  Charging via USB-C Port tyha 15 20,036 07-22-2020, 08:15 PM
Last Post: iscmob
  Battery not charging via AC Adapter laissezfarrell 1 3,117 05-30-2020, 06:05 PM
