PDF reader for PBP
Hi all,
I just received my PBP yesterday, and I'm very excited.
I started to use it and all wroks well and fine, but I have a question; is there any PDF reader? By default I didn't find one in the apps installed in the PBP, is there any way I can install one?
Thanks very much in advance!
Best Regards and Happy New Year!
(12-31-2019, 12:06 PM)gimy16 Wrote: is there any PDF reader?
sudo apt-get install evince
You can also use the browser, chromium. In the address bar, type:
Quote:file:///home/rock
Then navigate to the document and click on it in the browser. The only downside to using the browser is that it does not keep a history of where you are in the document. Meaning it will not reopen where you were previously, but at the beginning of the document.
(12-31-2019, 12:06 PM)gimy16 Wrote: Hi all,
  Perhaps the Debian repo/software store,  or synaptic pkg. manager,  ether would likely include any needed dependencies.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Perfect! Thanks so much!!
There's also okular you can get it from flatpak, they have an arm64 version.
apt-get install xpdf
It's a little old but it comes with utilities for pdfs like:
pdfdetach(1), pdffonts(1), pdfimages(1), pdfinfo(1), pdftocairo(1), pdftoppm(1), pdftops(1), pdftotext(1) pdfseparate(1), pdfsig(1), pdfunite(1)
  UK Pinebook Pro for sale (UK buyers only, 64GB, eMMC reader, NVME add-on) Z0rua 0 1,803 06-01-2021, 12:51 PM
Last Post: Z0rua
  broken sd card reader? kratti 13 14,175 03-06-2021, 01:20 AM
Last Post: kratti
